Pietist
DNSdynamic script for RouterOS v6
Fri Jun 15, 2018 6:23 pm
I want to use script to inform DNSdynamic about my ip.
https://www.dnsdynamic.org/compatibility.php
I has changed example for No-IP and composed this script for DNSdynamic:
# DNSdynamic update
#User account info
:local dnsdynamicuser "amuliar@protonmail.ch"
:local dnsdynamicpass "YL6a1##DynaPietist"
:local dnsdynamichost "pietist.ssh22.net"
# Change to the name of interface that gets the dynamic IP address
:local inetinterface "pppoe-out-langate"
:global previousIP
:if ([/interface get $inetinterface value-name=running]) do={
# Get the current IP on the interfacea
   :local currentIP [/ip address get [find interface="$inetinterface" disabled=no] address]
# Strip the net mask off the IP address
   :for i from=( [:len $currentIP] - 1) to=0 do={
       :if ( [:pick $currentIP $i] = "/") do={
           :set currentIP [:pick $currentIP 0 $i]
   :if ($currentIP != $previousIP) do={
       :log info "IP: Current IP $currentIP is not equal to previous IP, update needed"
       :set previousIP $currentIP
# The update dnsdynamic URL. Note the "\3F" is hex for question mark (?). Required since ? is a special character in commands.
       :local url "https://www.dnsdynamic.org/api/\3Fhostname=$dnsdynamichost&myip=$currentIP"
       :log info "dnsdynamic: $url"
       :local dnsdynamichostarray
       :set dnsdynamichostarray [:toarray $dnsdynamichost]
       :foreach host in=$dnsdynamichostarray do={
           :log info "dnsdynamic: Sending update for $host"
           /tool fetch url=$url user=$dnsdynamicuser password=$dnsdynamicpass mode=https dst-path=("dnsdynamic_ddns_update-" . $host . ".txt")
           :log info "dnsdynamic: Host $host updated on dnsdynamic with IP $currentIP"
   }  else={
       :log info "IP: Previous IP $previousIP is equal to current IP, no update needed"
} else={
   :log info "IP: $inetinterface is not currently running, so therefore will not update."
I suppose, something is not correct here because "dnsdynamic: Host $host updated on dnsdynamic with IP $currentIP" doesn't appear in log.
Could you please help me to figure out what is incorrect?
RouterOS v6.40.4
MSandoval
Re: DNSdynamic script for RouterOS v6
Tue Jul 17, 2018 7:28 pm
if you want you can use the DNS options that the mikrotik brings.
IP > Cloud - DNS Enable
And then use the DNS name that give you. I hope can help you.
And very important. I recommend you delete your information about your loggin in the dnsdynamic.org. because any can loggin and use that information against you.
http://subirimagen.me/uploads/20180717112726.jpg
dasiu
Trainer
Trainer
Tue Jul 17, 2018 7:38 pm
OMG, MSandoval! I didn't notice, that he included his real login information in the script! Thanks for pointing it out loud, so all of us now can notice it! :)
gotsprings
Forum Veteran
Forum Veteran
Tue Jul 17, 2018 11:40 pm
I have resorted to using a script that writes all the user/pass/hostname to global variables at start up. Then my dyndns updater calls that info... so i don't make that mistake right there.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
Users browsing this forum: No registered users and 13 guests
