MUM Europe 2020
maniraj4143
Beginner for BGP implemantation
Tue Jun 19, 2018 2:20 pm
Hi, I'm new with the BGP implementation with mikrotik. I need some help in fine tuning the configuration. I've done some work on configuration part and I'm posting here it for checking purposes as we are facing some issues with website browsing. Kindly have a look on our configuration and reply if anything found wrong.
Our upstream provider is AirTel - 182.X.Y.186/30
For Bandwidth & User Management we use Smartguard running on CentOS6 - 103.X.Y.2/29
RouterOS 6.41.1
model = RouterBOARD 3011UiAS
set [ find default-name=ether2 ] comment=AirTel-WAN
set [ find default-name=ether3 ] comment=SERVER-LAN
set [ find default-name=ether4 ] comment=LOCAL
/queue simple
add max-limit=20M/20M name=queue1 target=192.168.45.10/32
/routing bgp instance
set default as=1XXXX8 client-to-client-reflection=no comment=My-AS
add address=182.X.Y.186/30 comment=AirTel-WAN interface=ether2 network=182.X.Y.184
add address=103.X.Y.1/29 comment=SERVER-LAN interface=ether3 network=103.X.Y.0
add address=192.168.45.1/24 comment=LOCAL interface=ether4 network=192.168.45.0
set cache-size=50000KiB servers=8.8.8.8,8.8.4.4,4.2.2.2
/ip firewall address-list
add address=0.0.0.0/8 list=NotPublic
add address=10.0.0.0/8 list=NotPublic
add address=100.64.0.0/10 list=NotPublic
add address=127.0.0.0/8 list=NotPublic
add address=169.254.0.0/16 list=NotPublic
add address=172.16.0.0/12 list=NotPublic
add address=192.0.0.0/24 list=NotPublic
add address=192.0.2.0/24 list=NotPublic
add address=192.168.0.0/16 list=NotPublic
add address=192.88.99.0/24 list=NotPublic
add address=198.18.0.0/15 list=NotPublic
add address=198.51.100.0/24 list=NotPublic
add address=203.0.113.0/24 list=NotPublic
add address=224.0.0.0/4 list=NotPublic
add address=240.0.0.0/4 list=NotPublic
add action=drop chain=input comment="drop ssh brute forcers" dst-port=22 protocol=tcp src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist address-list-timeout=1w3d chain=input connection-state=new dst-port=22 protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 address-list-timeout=1m chain=input connection-state=new dst-port=22 protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 address-list-timeout=1m chain=input connection-state=new dst-port=22 protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 address-list-timeout=1m chain=input connection-state=new dst-port=22 protocol=tcp
add action=drop chain=forward comment="drop ssh brute downstream" dst-port=22 protocol=tcp src-address-list=ssh_blacklist
add action=jump chain=forward connection-state=new disabled=yes jump-target=detect-ddos
add action=return chain=detect-ddos disabled=yes dst-limit=32,32,src-and-dst-addresses/10s
add action=add-dst-to-address-list address-list=ddosed address-list-timeout=10m chain=detect-ddos disabled=yes
add action=add-src-to-address-list address-list=ddoser address-list-timeout=10m chain=detect-ddos disabled=yes
add action=drop chain=forward connection-state=new disabled=yes src-address-list=ddoser
add action=drop chain=input comment="Drop all Input from WAN NotPublic" in-interface=ether2 src-address-list=NotPublic
add action=drop chain=output comment="Drop all Output from LAN NotPublic" out-interface=ether3 src-address-list=NotPublic
add action=add-src-to-address-list address-list="From WAN Not Public" address-list-timeout=1d chain=forward comment="Drop all Forward from WAN NotPublic" in-interface=ether2 log-prefix=FWD_WAN_NOT_PUBLIC src-address-list=NotPublic
add action=drop chain=forward comment="Drop all Forward from WAN NotPublic" in-interface=ether2 log-prefix=FWD_WAN_NOT_PUBLIC src-address-list=NotPublic
add action=masquerade chain=srcnat out-interface=ether2 src-address=192.168.45.0/24
/ip firewall service-port
set sip disabled=yes
add distance=1 gateway=182.X.Y.185
add distance=1 dst-address=103.X.Y.32/27 gateway=103.X.Y.2 (Direct IP addresses given to customer)
add distance=1 dst-address=103.X.Y.64/27 gateway=103.X.Y.2 (Direct IP addresses given to customer)
add distance=1 dst-address=103.X.Y.128/26 gateway=103.X.Y.2 (Direct IP addresses given to customer)
add distance=1 dst-address=103.X.Y.192/26 gateway=103.X.Y.2 (One IP pool for SNAT)
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
/lcd
set backlight-timeout=1h color-scheme=light default-screen=stats
/lcd interface
set ether1 disabled=yes
set ether4 disabled=yes
set ether5 disabled=yes
set sfp1 disabled=yes
set ether6 disabled=yes
set ether7 disabled=yes
set ether8 disabled=yes
set ether9 disabled=yes
set ether10 disabled=yes
/routing bgp network
add network=103.X.Y.0/24 synchronize=no
/routing bgp peer
add in-filter=AirTel-IN name=AirTel out-filter=AirTel-OUT remote-address=182.X.Y.185 remote-as=9498 ttl=default update-source=ether2
/routing filter
add action=accept chain=AirTel-OUT prefix=103.X.Y.0/24 set-bgp-prepend=8
add action=discard chain=AirTel-OUT
add action=discard chain=AirTel-IN prefix=0.0.0.0/8
add action=discard chain=AirTel-IN prefix=10.0.0.0/8
add action=discard chain=AirTel-IN prefix=100.64.0.0/10
add action=discard chain=AirTel-IN prefix=127.0.0.0/8
add action=discard chain=AirTel-IN prefix=169.254.0.0/16
add action=discard chain=AirTel-IN prefix=172.16.0.0/12
add action=discard chain=AirTel-IN prefix=192.0.0.0/24
add action=discard chain=AirTel-IN prefix=192.0.2.0/24
add action=discard chain=AirTel-IN prefix=192.88.99.0/24
add action=discard chain=AirTel-IN prefix=192.168.0.0/16
add action=discard chain=AirTel-IN prefix=192.18.0.0/15
add action=discard chain=AirTel-IN prefix=192.51.100.0/24
add action=discard chain=AirTel-IN prefix=203.0.113.0/24
add action=discard chain=AirTel-IN prefix=224.0.0.0/4
add action=discard chain=AirTel-IN prefix=240.0.0.0/4
add action=accept chain=AirTel-IN distance=2 prefix=0.0.0.0/0
/system clock
set time-zone-name=Asia/Kolkata
/system identity
set name=My BGP Router
/system ntp client
set enabled=yes server-dns-names=in.pool.ntp.org,pool.ntp.org
/tool bandwidth-server
set enabled=no
/tool graphing interface
add
Anumrak
Re: Beginner for BGP implemantation
Tue Jun 19, 2018 3:15 pm
Probably you don't need to caching dns queries.
maniraj4143
Tue Jun 19, 2018 4:34 pm
I've checked it dns caching is not storing anything, even the Allow Remote Request is unchecked.
Anumrak
Tue Jun 19, 2018 5:05 pm
What issues exactly you have with browsing?
maniraj4143
Tue Jun 19, 2018 5:58 pm
There is a particular website on which we're facing the issue, it is http://amazesms.in/. We are able to access the home page of this website from our network. It asks username & password credentials for further access. When we input the username & password on this website, then instead of login success it always returns to the same login home page. We have cross - checked it the account with the same username & password credentials are working successfully on other networks.
common browsing response is little late, I expect it to be snappier on a 155Mbps link consuming only 50% of it during the peak hours.
Anumrak
Thu Jun 21, 2018 10:57 am
What other networks?
maniraj4143
Thu Jun 21, 2018 12:35 pm
Other Networks means Other ISP Network or Mobile data.
Anumrak
Thu Jun 21, 2018 12:54 pm
Then maybe your upstream ISP blocking this resource?
Users browsing this forum: No registered users and 5 guests
