bajanetworks
How to send traffic to the same gateway using a diferent ethernet port?
Fri Jun 22, 2018 3:18 am
Hello guys,
many years ago i did this but now I can not remember how to do it.
What I did before was:
IP > Routes
on the gateway field I put something like this: <IP-Address>~ether2 or <IP-Address>::ether2
Some one knows what is the correct syntax for this? also willing to know how to name this technique.
LCC José Luna
Director de Tecnología
Cel. +52 646 131 6198
http://bajanetworks.com.mx
Alancoma
Re: How to send traffic to the same gateway using a diferent ethernet port?  [SOLVED]
Sat Jun 23, 2018 1:34 am
That's easy
Gatewayip%etherX
bajanetworks
Sun Jun 24, 2018 9:28 pm
haaaa god!! the %
Thank you so much,
you say this is called 'east'? or you meant to say this was easy?
I dont understand you...
how can I find this on the router os documentation?
LCC José Luna
Alancoma
Sun Jun 24, 2018 11:35 pm
Sorry,
I wanted to say easy.
I found It on internet but I don't remeber where.
Sob
Mon Jun 25, 2018 2:18 am
I didn't find detailed description, but it is mentioned in manual:
gateway (IP | interface | IP%interface | IP@table[, IP | string, [..]]; Default: "")
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
bajanetworks
Fri Jun 29, 2018 2:58 am
thanks a lot guys,
where in the manual did you found it.
LCC José Luna
chechito
Fri Jun 29, 2018 3:34 am
thanks a lot guys,
https://wiki.mikrotik.com/wiki/Manual:I ... properties
Users browsing this forum: MSN [Bot] and 114 guests
