rememberme
Re: v6.42.5 [current]
Fri Jun 29, 2018 4:34 pm
Thank you very much for the reports about issues with space, next RouterOS version will fix the issue.
Meanwhile this package can be used to clear space on your router,
https://www.mikrotik.com/download/share/fix_space.npk
- upload package to your router;
- run /system reboot
It works on every board and does not depend on version.
Guys, be careful with this patch!!!
I uploaded it to a test CCR1016 and it doesn't come up after reboot!
Test it first!
sindy
Fri Jun 29, 2018 4:40 pm
Thanks, but I'm getting values like 4294967228 from the OID above.
That's a matter of interpretation, if you interpret it as a signed 32-bit integer, this value means -68 which looks like a plausible one for RSSI. You seem to be interpreting it as a 32-bit unsigned integer so you get this.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Cha0s
Fri Jun 29, 2018 4:41 pm
Cha0s - Is it possible that you added EoIP tunnels from old Winbox version?
I created the tunnels via CLI. Upgrading or rebooting the router loses the hostname in the remote address field and leaves an old/previously resolved IP.
Never mind. It was my mistake. :oops:
A combination of a forgotten custom dyndns script with a wrong/outdated dyndns configured that resolved to the wrong IP.
The "issue" appeared only during reboot/upgrade because only then the public IP actually changed causing the script to run and overwrite the EoIP remote addresses.
Lesson learned: When installing new routerboards (as replacements to old ones) I shouldn't blindly copy/paste the export from the old device that has ancient scripts that are no longer needed :P
rememberme
Fri Jun 29, 2018 4:42 pm
Fair enough :)
Thanks!
Cha0s
Fri Jun 29, 2018 4:52 pm
Test it first!
I tested it on a Groove and worked. I haven't tried it on any other device.
@Mikrotik: will this patch be included automatically on next ROS updates so we can avoid the extra reboots?
sergejs
Fri Jun 29, 2018 4:53 pm
Yes, patch will be included into the next RouterOS versions.
rememberme
Fri Jun 29, 2018 6:19 pm
Tested on 2 CCRs in the lab, both go into kernel panic.
Seems that this script is killing devices that don't have the space issue, ones that have only one boot image.
  • CCR1016-12S-1S+
  • CCR1009-8G-1S-1S+
RouterBOOT booter 3.33
CCR1016-12S-1S+
CPU frequency: 1200 MHz
Memory size: 2048 MiB
NAND size: 128 MiB
Press any key within 2 seconds to enter setup..
loading kernel... OK
setting up elf image... OK
jumping to kernel code
Pid: 1, comm: init, CPU: 15
r0 : 0xfffffe403e535c00 r1 : 0xfffffe0004940e40 r2 : 0xfffffe003c397500
r3 : 0xfffffe403feffb20 r4 : 0xfffffe403feffb68 r5 : 0x0000000000000060
r6 : 0x0000000000000001 r7 : 0x0000000000000000 r8 : 0x0000000000000000
r9 : 0x0000000000000000 r10: 0x0000000000000000 r11: 0x0000000000000001
r12: 0xfffffff5001f21c0 r13: 0xfffffffcffffffff r14: 0x0000000000000001
r15: 0x000000000000013e r16: 0xfffffe003c020420 r17: 0xfffffff5001e0100
r18: 0x0000000000000000 r19: 0x000000000000013d r20: 0xfffffe003c397700
r21: 0xfffffe003c397528 r22: 0x0002000000000000 r23: 0xfffffe003c397520
r24: 0xfffffe403feff950 r25: 0xfffffe403feffb90 r26: 0xfffffe403feffbc0
r27: 0xfffffe403feffbc8 r28: 0xfffffe403feffbb8 r29: 0xfffffe403feffbd0
r30: 0xfffffe403e535ea8 r31: 0xfffffe403e535c00 r32: 0x0000000000000001
r33: 0xfffffff70023df48 r34: 0xfffffe003caa39c0 r35: 0x0000000000000000
r36: 0x0000000000000001 r37: 0x0000000000000000 r38: 0xfffffe003caa3980
r39: 0x0000000000000003 r40: 0x0000000007fc0000 r41: 0x00000000000f3f38
r42: 0x00000000000f4170 r43: 0x00000000000f4370 r44: 0x00000000000f3f10
r45: 0x000000007ffbfb10 r46: 0x000000000014a0b4 r47: 0x00000000000f4768
r48: 0x000000007ffbfb10 r49: 0x000000000014a09c r50: 0x000000000014a0b4
r51: 0x000000000014a0b4 r52: 0xfffffe403feffcc0 tp : 0x000001f4ffc70000
sp : 0xfffffe403feffbb0 lr : 0xfffffff70015bb10
pc : 0xfffffff70023dd38 ex1: 2 faultnum: 18
Instruction dump:
c6e886cd05c18d9b defe400055bbf01f 2862f340102a801e 9e56400035ec3000
<9e06400034ac3000> 23ff1ce051483000 23ff1d9fd107f7c0 8600c6ce05e20d9d
Starting stack dump of tid 1, pid 1 (init) on cpu 15 at cycle 22038278009
frame 0: 0xfffffff70023dd38 squashfs_kill_sb+0x30/0x70 (sp 0xfffffe403feffbb0)
frame 1: 0xfffffff70015bb10 deactivate_locked_super+0x70/0xd8 (sp 0xfffffe403feffbd0)
frame 2: 0xfffffff70015cfb0 mount_nodev+0x90/0x158 (sp 0xfffffe403feffbf0)
frame 3: 0xfffffff70015e690 mount_fs+0x48/0x1e0 (sp 0xfffffe403feffc28)
frame 4: 0xfffffff70018ac60 vfs_kern_mount+0xa8/0x1a0 (sp 0xfffffe403feffc58)
frame 5: 0xfffffff70018baa8 do_kern_mount+0x70/0x1c0 (sp 0xfffffe403feffc98)
frame 6: 0xfffffff70018ead8 do_mount+0x898/0xac0 (sp 0xfffffe403feffcd0)
frame 7: 0xfffffff7001cbb98 compat_sys_mount+0x2c8/0x370 (sp 0xfffffe403feffd60)
frame 8: 0xfffffff700520198 handle_syscall+0x210/0x2d0 (sp 0xfffffe403feffdc0)
<syscall while in user mode>
frame 9: 0x94618 0x94618 (sp 0x7ffbf9e0)
frame 10: 0x13810 0x13810 (sp 0x7ffbf9e0)
frame 11: 0x12338 0x12338 (sp 0x7ffbfa88)
frame 12: 0x4fd30 0x4fd30 (sp 0x7ffbfd30)
frame 13: 0x12670 0x12670 (sp 0x7ffbfe80)
Stack dump complete
---[ end trace a26cf30f1b6cd5ff ]---
Kernel panic - not syncing: Kernel page fault running init!
Starting stack dump of tid 1, pid 1 (init) on cpu 15 at cycle 22173885595
frame 0: 0xfffffff70051f448 dump_stack+0x0/0x20 (sp 0xfffffe403feff808)
frame 1: 0xfffffff7005183e0 panic+0x168/0x398 (sp 0xfffffe403feff808)
frame 2: 0xfffffff7000394f0 do_page_fault+0xa60/0xc48 (sp 0xfffffe403feff8b0)
frame 3: 0xfffffff70051f7a8 handle_interrupt+0x288/0x2a0 (sp 0xfffffe403feff940)
<interrupt 18 while in kernel mode>
frame 4: 0xfffffff70023dd38 squashfs_kill_sb+0x30/0x70 (sp 0xfffffe403feffbb0)
frame 5: 0xfffffff70015bb10 deactivate_locked_super+0x70/0xd8 (sp 0xfffffe403feffbd0)
frame 6: 0xfffffff70015cfb0 mount_nodev+0x90/0x158 (sp 0xfffffe403feffbf0)
frame 7: 0xfffffff70015e690 mount_fs+0x48/0x1e0 (sp 0xfffffe403feffc28)
frame 8: 0xfffffff70018ac60 vfs_kern_mount+0xa8/0x1a0 (sp 0xfffffe403feffc58)
frame 9: 0xfffffff70018baa8 do_kern_mount+0x70/0x1c0 (sp 0xfffffe403feffc98)
frame 10: 0xfffffff70018ead8 do_mount+0x898/0xac0 (sp 0xfffffe403feffcd0)
frame 11: 0xfffffff7001cbb98 compat_sys_mount+0x2c8/0x370 (sp 0xfffffe403feffd60)
frame 12: 0xfffffff700520198 handle_syscall+0x210/0x2d0 (sp 0xfffffe403feffdc0)
frame 13: 0x94618 0x94618 (sp 0x7ffbf9e0)
frame 14: 0x13810 0x13810 (sp 0x7ffbf9e0)
frame 15: 0x12338 0x12338 (sp 0x7ffbfa88)
frame 16: 0x4fd30 0x4fd30 (sp 0x7ffbfd30)
frame 17: 0x12670 0x12670 (sp 0x7ffbfe80)
Stack dump complete
Rebooting in 1 seconds..Resetting chip and restarting.
CCR1009-8G-1S-1S+
NAND size: 128 MiB
Pid: 1, comm: init, CPU: 8
r0 : 0xfffffe007dea5c00 r1 : 0xfffffe0004a35640 r2 : 0xfffffe007d597680
r3 : 0xfffffe007eedfb20 r4 : 0xfffffe007eedfb68 r5 : 0x0000000000000060
r12: 0xfffffff5001121c0 r13: 0xfffffffcffffffff r14: 0x0000000000000001
r15: 0x000000000000013a r16: 0xfffffe007d020420 r17: 0xfffffff500100100
r18: 0x0000000000000000 r19: 0x0000000000000139 r20: 0xfffffe007d597880
r21: 0xfffffe007d5976a8 r22: 0x0002000000000000 r23: 0xfffffe007d5976a0
r24: 0xfffffe007eedf950 r25: 0xfffffe007eedfb90 r26: 0xfffffe007eedfbc0
r27: 0xfffffe007eedfbc8 r28: 0xfffffe007eedfbb8 r29: 0xfffffe007eedfbd0
r30: 0xfffffe007dea5ea8 r31: 0xfffffe007dea5c00 r32: 0x0000000000000001
r33: 0xfffffff70023df48 r34: 0xfffffe007de62580 r35: 0x0000000000000000
r36: 0x0000000000000001 r37: 0x0000000000000000 r38: 0xfffffe007de62540
r45: 0x000000007fe2fb10 r46: 0x000000000014a0b4 r47: 0x00000000000f4768
r48: 0x000000007fe2fb10 r49: 0x000000000014a09c r50: 0x000000000014a0b4
r51: 0x000000000014a0b4 r52: 0xfffffe007eedfcc0 tp : 0x000001f4ffb90000
sp : 0xfffffe007eedfbb0 lr : 0xfffffff70015bb10
Instruction dump:
Starting stack dump of tid 1, pid 1 (init) on cpu 8 at cycle 21745015076
frame 0: 0xfffffff70023dd38 squashfs_kill_sb+0x30/0x70 (sp 0xfffffe007eedfbb0)
frame 1: 0xfffffff70015bb10 deactivate_locked_super+0x70/0xd8 (sp 0xfffffe007eedfbd0)
frame 2: 0xfffffff70015cfb0 mount_nodev+0x90/0x158 (sp 0xfffffe007eedfbf0)
frame 3: 0xfffffff70015e690 mount_fs+0x48/0x1e0 (sp 0xfffffe007eedfc28)
frame 4: 0xfffffff70018ac60 vfs_kern_mount+0xa8/0x1a0 (sp 0xfffffe007eedfc58)
frame 5: 0xfffffff70018baa8 do_kern_mount+0x70/0x1c0 (sp 0xfffffe007eedfc98)
frame 6: 0xfffffff70018ead8 do_mount+0x898/0xac0 (sp 0xfffffe007eedfcd0)
frame 7: 0xfffffff7001cbb98 compat_sys_mount+0x2c8/0x370 (sp 0xfffffe007eedfd60)
frame 8: 0xfffffff700520198 handle_syscall+0x210/0x2d0 (sp 0xfffffe007eedfdc0)
frame 9: 0x94618 0x94618 (sp 0x7fe2f9e0)
frame 10: 0x13810 0x13810 (sp 0x7fe2f9e0)
frame 11: 0x12338 0x12338 (sp 0x7fe2fa88)
frame 12: 0x4fd30 0x4fd30 (sp 0x7fe2fd30)
frame 13: 0x12670 0x12670 (sp 0x7fe2fe80)
Stack dump complete
---[ end trace 9b1a353c28c3b544 ]---
Starting stack dump of tid 1, pid 1 (init) on cpu 8 at cycle 21880507611
frame 0: 0xfffffff70051f448 dump_stack+0x0/0x20 (sp 0xfffffe007eedf808)
frame 1: 0xfffffff7005183e0 panic+0x168/0x398 (sp 0xfffffe007eedf808)
frame 2: 0xfffffff7000394f0 do_page_fault+0xa60/0xc48 (sp 0xfffffe007eedf8b0)
frame 3: 0xfffffff70051f7a8 handle_interrupt+0x288/0x2a0 (sp 0xfffffe007eedf940)
frame 4: 0xfffffff70023dd38 squashfs_kill_sb+0x30/0x70 (sp 0xfffffe007eedfbb0)
frame 5: 0xfffffff70015bb10 deactivate_locked_super+0x70/0xd8 (sp 0xfffffe007eedfbd0)
frame 6: 0xfffffff70015cfb0 mount_nodev+0x90/0x158 (sp 0xfffffe007eedfbf0)
frame 7: 0xfffffff70015e690 mount_fs+0x48/0x1e0 (sp 0xfffffe007eedfc28)
frame 8: 0xfffffff70018ac60 vfs_kern_mount+0xa8/0x1a0 (sp 0xfffffe007eedfc58)
frame 9: 0xfffffff70018baa8 do_kern_mount+0x70/0x1c0 (sp 0xfffffe007eedfc98)
frame 10: 0xfffffff70018ead8 do_mount+0x898/0xac0 (sp 0xfffffe007eedfcd0)
frame 11: 0xfffffff7001cbb98 compat_sys_mount+0x2c8/0x370 (sp 0xfffffe007eedfd60)
frame 12: 0xfffffff700520198 handle_syscall+0x210/0x2d0 (sp 0xfffffe007eedfdc0)
frame 13: 0x94618 0x94618 (sp 0x7fe2f9e0)
frame 14: 0x13810 0x13810 (sp 0x7fe2f9e0)
frame 15: 0x12338 0x12338 (sp 0x7fe2fa88)
frame 16: 0x4fd30 0x4fd30 (sp 0x7fe2fd30)
frame 17: 0x12670 0x12670 (sp 0x7fe2fe80)
Stack dump complete
ac6529
Fri Jun 29, 2018 6:46 pm
  • CCR1016-12S-1S+
  • CCR1009-8G-1S-1S+
can confirm, killed a CCR1009 here.
how does one recover from this? i was able to do a netinstall, router boots up but for some reason I can't connect to 192.168.88.1 on eth1 per the default configuration.
EDIT: got access, it put the default IP on the combo interface and not ETH1
pe1chl
Fri Jun 29, 2018 7:49 pm
Indeed the patch does not work!
I tried it on a 2-partition CCR1009 (before reading other remarks).
First copied partition containing 6.42.1, updated it to 6.42.5 which resulted in lost space issue as usual,
then uploaded patch and rebooted, router came back but it has switched active partition back to the 6.42.1 copy!
That explains why routers with only one partition fail completely. They don't have the second partition to fall back to.
telepro
Fri Jun 29, 2018 9:42 pm
Fix_Space.npk script did not work successfully on a RB750r2 after executing the following procedure:
Device operational running ROS 6.42.5
Placed update procedure on flash partition using winbox
Use winbox to execute reboot to run the Fix_Space.npk script.
Device did reboot but not come up successfully.
Waited about 10 minutes, but device never became accessible.
Cycled power.
After power cycle, device did start up and respond to winbox, but entire configuration was lost and all files previously on flash disk were gone.
Sob
Fri Jun 29, 2018 11:10 pm
For the record, fix_space.npk did work well with my testing CHR. It did survive and successfully reclaimed missing space.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
LeftyTs
Sat Jun 30, 2018 2:32 am
As for the HDD problem - we are currently trying to find out how to reproduce this problem. If anyone can share such information (step-by-step), then please send in an e-mail to support@mikrotik.com. Is it possible that all of the affected devices had partitions?
No, I am very certain partitioning has nothing to do with it. Actually I have send MT info as well as supout. Most devices I upgraded from bugfix release to the current one had this issue as backup stopped from working right after the upgrade. None of them had partitioning. I will repost the steps I did.
1) Upgraded from v5.26 to bugfix.
2) Right after bugfix I upgraded again to current
Almost all devices I upgraded could not get a valid backup right after the above two steps (system backup save). The backup file that was created was extremely large in size and ROS was always reporting an error.
strods
Sat Jun 30, 2018 1:25 pm
We are very sorry for any inconvenience caused. Fix package for missing storage space has been temporary removed and will soon be updated to patched version.
Cha0s
Sat Jun 30, 2018 3:55 pm
I only tried it on one (non-critical) device (an old Groove) that has two partitions to test if it works.
It worked ok without breaking the first partition so I thought it's ok in general.
I guess I was just lucky with this one (and more lucky I didn't start running it on more critical equipment).
pe1chl
Sat Jun 30, 2018 5:51 pm
Did that Groove have the lost space issue?
The patch does this:
#!/bin/bash
if [ "$bootimage" != "1" ]; then rm -f /flash/bootimage; fi
mv /var/pdb/fix-space/image /tmp
rm -rf /var/pdb/fix-space
I think it is a bit confusing, I would expect to see a mv to /flash/bootimage. Or the ln -f method I
posted before.
It looks like after the above the bootimage might be gone. But I have no knowledge of the RouterOS
filesystem and boot code, only general Linux experience.
Cha0s
Sat Jun 30, 2018 6:03 pm
Obviously. Why would I try it on a device that has no problem?
Redmor
Sat Jun 30, 2018 6:12 pm
I have to admit that Nv2 has been improved, but are you going to implement a madder TDMA protocol?
I have co-workers that say "If you have 100Mbps on an AP and 100 clients connected, with TDMA you can give 100Mbps to them all simultaneously, slowing latency", I know that this is pure theory, but in some cases I don't see any difference between Nv2 and 802.11 even with 20 clients and 500Mbps on AP.
Cha0s
Sat Jun 30, 2018 6:37 pm
NV2 is a TDMA implemenation of MikroTik's.
I don't see how you can give 100Mbps * 100 times (clients) at the same time when your physical interface cannot do 10gbit (that's how much 100*100 is!). Not even in theory. Your co-workers don't seem to know what they are talking about.
TDMA divides the signal into different time slots. That does not multiply the available traffic times the connected clients. That doesn't make any sense whatsoever.
TDMA allows for multiple clients to use the AP without any client overtaking any other (for example due to the hidden node problem).
Each client has its own time slot on when to talk to the AP, so no two clients can talk at the same time (which would be pretty much noise as far as the AP is concerned).
https://en.wikipedia.org/wiki/Time-divi ... ple_access
benoga
Sat Jun 30, 2018 9:01 pm
This Package on the first Page kill my CCR Router....
Edit 06.29.2018
To fix storage issue on your router, use package from the link,
[/quote]
marekm
Sat Jun 30, 2018 9:53 pm
*) w60g - general stability and performance improvements;
Ticket#2018062622003837
For me, 6.42.5 made w60g less stable (6.43rc34 has the same issues too) than 6.42.4. Wireless Wire Dish kit, 208 m PtP link, testing with UDP 300Mbps/600Mbps btest for many hours, new versions randomly disconnect about 100 times in 24 hours, 6.42.4 - not a single disconnect and only about 0.07% packet loss (probably not all of it in that link, I have a few switches passing a lot of other traffic in between). Support gives various recommendations that don't help (change alignment, reduce Tx power, change channel). Only downgrade helps, the issue is easy to reproduce reliably (the disconnects happen even with no traffic, and take long enough for winbox to close), so I'm a bit surprised the changes were rushed from RC to current without more internal testing. I'm fine with running 6.42.4 for now, but it's missing one important thing (channel 4 support - BTW, why CLI only and winbox shows "auto" instead of 64800?).
Xymox
Sun Jul 01, 2018 6:01 am
UPDATE: (package removed, will be updated very soon)
AWESOME !!!!!
Xymox
Sun Jul 01, 2018 6:15 am
Thank you Mikrotik for addressing the space bug. Thank you for also working up a way to recover a router.
A bit late for me as I flew to 4 sites to recover devices :( As I was the first to report this issue and I suffered a lot of expenses related, I think I deserve a Mikrotik T-Shirt, hahaha...
antonsb
Sun Jul 01, 2018 11:10 pm
At what power output are you right now?
You will need to lower power output even more to something in range from 1 to 5 should be fine for such close distance
bda
Mon Jul 02, 2018 9:21 am
Sorry for disturbing.
When we can download fix for missing storage space?
God bless UNIX!
Babujnik
Mon Jul 02, 2018 11:34 am
is it only me, or wireless performance on 6.42.5 is really bad ?
today I couldn't even work from home, was disconnected every few minutes. speed between workstation and NAS (laptop--WIFI->RB--LAN->NAS) was runing around 800kbs (5Ghz Network !).
when downgraded to 6.42.4 - works like a charm
(RouterBOARD 962UiGS-5HacT2HnT)
sergejs
Mon Jul 02, 2018 1:56 pm
We are sorry for any issues caused by the previous package, we uploaded new packages, that will work fine on any router.
Package updated 07/02/2018
vecernik87
Forum Veteran
Forum Veteran
Mon Jul 02, 2018 2:07 pm
is it only me, or wireless performance on 6.42.5 is really bad ? (RouterBOARD 962UiGS-5HacT2HnT)
Maybe it is device specific? No disconnection or slow network with RBD52G-5HacD2HnD running 6.42.5
lesnikov
Mon Jul 02, 2018 2:23 pm
Package updated 07.02.2018
we updated to 6.42.5 about 20 hours ago and when we do check for updates it says up to date. so new patched version is not getting fetched. should we manually upgrade?
Babujnik
Mon Jul 02, 2018 2:33 pm
maybe it is as you mentioned. haven't changed anything else in environment, except update to 6.42.5. got few other devices, but didn't go with that version there yet. one problematic device is enough ;)
eworm
Forum Veteran
Forum Veteran
Mon Jul 02, 2018 2:40 pm
This is not an update but just a fix. You are up-to-date, no action required.
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
sindy
Mon Jul 02, 2018 2:41 pm
fix_space.npk is a standalone package used to resolve the missing space issue, not related to any particular release. So the "check for updates" function is not relevant to it.
Jotne
Mon Jul 02, 2018 3:00 pm
7 February 2018??
Use correct format on date please.
02.07.2018
or us format
07/02/2018
How to use Splunk to monitor your MikroTik Router(s)
MikroTik->Splunk
marekm
Mon Jul 02, 2018 6:13 pm
Default, which is stable in 6.42.4. I have already tried different tx-power values (as suggested by support), there was no link at all with power 1 or 2, RSSI was about -67 at power 3, -60 at power 4, -54 at power 5, little change at higher settings or default. So it seems tx-power is in ~6dB units, but reducing it didn't make it more stable. If acceptable RSSI range is so narrow, it would be nice to adjust tx-power automatically (especially in PtMP where stations can be at very different distances).
anuser
Mon Jul 02, 2018 6:15 pm
Is ANI enabled?
/interface wireless set adaptive-noise-immunity=ap-and-client-mode wlan2
/interface wireless set adaptive-noise-immunity=ap-and-client-mode wlan1
bda
Mon Jul 02, 2018 10:25 pm
Script do nothing on hEX PoE:
[bda@hme16-08ra] > system resource print
uptime: 1m58s
version: 6.42.4 (stable)
build-time: Jun/15/2018 14:14:17
factory-software: 6.36
free-memory: 106.0MiB
total-memory: 128.0MiB
cpu: MIPS 74Kc V5.0
cpu-count: 1
cpu-frequency: 800MHz
cpu-load: 12%
free-hdd-space: 4.8MiB
total-hdd-space: 16.0MiB
write-sect-since-reboot: 67
write-sect-total: 9870
bad-blocks: 0%
architecture-name: mipsbe
board-name: hEX PoE
platform: MikroTik
Why?
God bless UNIX!
pe1chl
Mon Jul 02, 2018 10:32 pm
Why?
Of course not!
It is for devices with 128MB flash. They have to store the updates in the same partition as the running firmware.
You have a 16MB flash device which puts updates in the RAM disk. And thus the error that is being fixed here cannot occur
on those devices.
bda
Mon Jul 02, 2018 10:39 pm
Why?
Of course not!
on those devices.
But why this device have only free-hdd-space: 4.8MiB ?!
God bless UNIX!
Sob
Mon Jul 02, 2018 10:58 pm
How much would you expect? It the total space is only 16MB and it has to take whole system, there can be hardly anything left.
pe1chl
Mon Jul 02, 2018 10:59 pm
Because it has only 16MB total and 10-11 MB is required.
The problem we are discussing is on the higher end devices (or better: old devices) that had 128MB.
You could partition this in 2 partitions of 64MB of which some 40MB is used.
you need the remaining 24MB to upload a new version.
In the 16MB devices the new version is loaded into RAM.
bda
Mon Jul 02, 2018 11:07 pm
Why?
Of course not!
on those devices.
Understood about 16 mb devices.. How about CRS ? After 6.42.1-4 - they have low space too...
In a few hours I will test on one of CRS...
And how about old RB800/RB850Gx2/RB493G on so on. Does this patch applicable?
God bless UNIX!
bda
Mon Jul 02, 2018 11:08 pm
And at last.... Before 6.42.1-4, any of hEX has more than 4mb... anyway
God bless UNIX!
Babujnik
Tue Jul 03, 2018 12:34 am
Is ANI enabled?
No, i haven't set this function. I can run upgrade once more and try with ANI functionality
As much as network on it's own I understand, the Wi-Fi settings are a little mistery for me
Xymox
Tue Jul 03, 2018 2:31 am
Awesome.. I will test this shortly..
Thanks again..
krzysztof
Tue Jul 03, 2018 3:08 am
IGMP still has problems with overloading.
PIM for IGMP continues to add multicast streams incorrectly!
I want to show an error in my laboratory
I am writing please and nothing.
I giving my phone number to Poland and nothing
Why do you treat your clients like that?
I like this equipment
And I'm forced to buy huawei, cisco etc.
krzysztof@pawluk.org
Certificate:
Cisco:
CCNA
CCNP
Mikrotik:
MTCNA
MTCWE
MTCRE
MTCTCE
pe1chl
Tue Jul 03, 2018 10:47 am
Did someone already test the new version of the fix on a CCR? I have become a bit more reluctant since the previous version could
have killed out router when we were not saved by the automatic partition fallback...
petertosh
Tue Jul 03, 2018 11:56 am
Used on CCR1009 yesterday, went smooth. Now with hotspot the system uses about 38 MBs. Was able to repartition again. Previously, because of the lost space I repartitioned from 2 to 1 partitions. For all asking if this erases the config: no. You can repartition from two to one partition and at least in my case the router was up and running normally after that. Thanks for the fix.
disik
Tue Jul 03, 2018 1:55 pm
Kid-control should apply to IPv6 too
Cha0s
Tue Jul 03, 2018 2:46 pm
I agree. On my devices that have 16MB flash, they have ~7.5MiB free, not 4.8MiB.
105547111
Tue Jul 03, 2018 6:21 pm
I agree totally - so much is missing from ipv6 in general like routing-marks, etc, etc :-(
Beone
Tue Jul 03, 2018 7:51 pm
18:50:39 system,error can not install fix-space-6.0: system-6.41 is not installed, but is required
juliokato
Tue Jul 03, 2018 8:22 pm
Personal opinion: Use this type of resource to free up space when you do not need is to look for problem where one does not have.
I would prefer for MK to build equipment with more disk space. 16MiB is ridiculous!
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
pe1chl
Tue Jul 03, 2018 8:26 pm
I have just applied the fix to one of the CCR1009 I manage and it worked OK!
I now have 25.9MB free on the 64MB partition so enough space to do a new upgrade.
Thanks! (although IMHO it took far too long until MikroTik acted on this matter)
HzMeister
Tue Jul 03, 2018 10:51 pm
I upgraded to 6.42.5 on my rb750gr3 without any apparent problems.
Does this affect all devices or is it limited to specific ones?
pe1chl
Wed Jul 04, 2018 1:44 am
It was already explained above. Please read entire topic.
LeftyTs
Wed Jul 04, 2018 1:59 am
Would anyone know which versions of ROS are affected by this space problem?
HzMeister
Wed Jul 04, 2018 2:14 am
Where is it "explained" exactly??
pe1chl
Wed Jul 04, 2018 11:02 am
In this topic (other pages) and in the 6.43rc topic.
pe1chl
Wed Jul 04, 2018 11:58 am
Unfortunately kid control was moved from tools (where it of course belonged, if not in system) to ip.
At that time I already remarked that such a feature of course is useless when it works only in ip and not in ipv6...
But such remarks go silently in /dev/null at MikroTik, alongside all the remarks about ipv6 in general.
At one time there sometimes was the "it will all be solved in v7" reply, but now that it becomes less and less likely
there will ever be a v7, it looks like ipv6 is at a dead end. And that is unfortunate as it will limit MikroTik to
the niche market of legacy local networks and NAT routing, while the rest of the world moves on.
panayi
Wed Jul 04, 2018 12:29 pm
Agree with you - in addition it seems kid-control is now broken - start and end times are now set to the same. And trying to change this does not take the change..... really frustrating !!
cohprog
Wed Jul 04, 2018 9:51 pm
I have a 50 meters PtP link with wAP 60G. Before, the signal displayed was always 80 and the mcs 8. Since this update, I saw different values but most of the time, it still display a signal of 80.
What I find really weird is that the tx-sector-info is regularly changing from "center" to various values between +/-27 degree in both horizontal and vertical axis (and no, the wAP aren't spinning around lol). If those wAP were anywhere near 27 degree off-center, I think I would notice it just by looking at them... So what's the deal? Are those numbers randomly generated to fulfill the needs of stats' junkies? ;)
I am a tad worried because I will soon try to replace a 1.2Km 5Ghz link with RBLHGG-60 and I don't see how to align them if those values aren't reliable. (I don't know how the RBLHGG-60 are but I have several 1km+ links with Metrolinq 2.5 60Ghz and they are soo tightbeam that it's very hard to make them see each others by sight. You nearly have to use a scop to point them at each others so they will connect and then you can finish the alignement using the signal strength)
netflow
Wed Jul 04, 2018 10:22 pm
Does anyone else observe higher than usual TX drops with this release on RB760Gr3 ? In fact, I observe TX drops increase even with almost no traffic.
Got >100k packet drops after 48h whereas I used to have only a few over monthes with 6.42.2 before.
This seems to affect only VLAN interfaces below physical interfaces as shown in this image Image
barracuda
Thu Jul 05, 2018 10:00 am
Is ANI enabled?
Nice info @anuser!Now my wifi speed is much better. :)
marcin21
Thu Jul 05, 2018 8:08 pm
I've upgraded WAP60g in ptmp scenario 2xapc - distance 170mtr wap60 and 270mtr - lhg60
before was 43rc17, jitter was quite ugly some ping went to 170ms but more or less stable,
after I've upgraded all to 42.5
I got better MCS, but devices disconnects every few hours, worse is they dont came back in reasonable time.
should I disable beamforming or tweak any features?
as for me 42.5 is UNUSABLE in 60ghz...
weirdest is more disconnection comes with wap60g that has better signal and was stable for weeks.
any advice?
antonsb
Fri Jul 06, 2018 5:48 pm
any advice?
Please contact support@mikrotik.com
netflow
Fri Jul 06, 2018 10:22 pm
I was able to stop the TX drops by changing the physical interfaces to multi-queue. I would absolutely not have expected that such change was required while reading the release notes. The routerOS documentation is also pretty weak in this area since the option 'only-hardware-queue' seems still to be recommended for SMP systems. Apparently this is no longer the case at least on MMIPS arch !
/queue type
set 8 mq-pfifo-limit=2048
/queue interface
set ether1 queue=multi-queue-ethernet-default
steen
Mon Jul 09, 2018 10:23 am
Is ANI enabled?
Hello Folks!
I have same experience, wireless performance on 6.42.5 useless after upgrading from 6.41.X.
Tested devices were wireless protocol 802.11 for office landscape use.
After a terrible experience where speeds were crippled down from 30-40Mbit/s to 20-30Kbit/s with constant interruptions we stopped rolled back all.
The described configuration did not help, further we needed to netinstall the devices to get them back, many problems arrived with this new ros version.
Kuba1301
Mon Jul 09, 2018 2:30 pm
Today, around 9AM CET I upgraded my CRS125‑24G to OS v6.42.5 remotly via Winbox and since that time I cannot:
- ping any external IP address from internal network (although public IP address is properly obtained by my WAN port via ISP DHCP server). I'm testing Google's DNS server with no luck.
- ping my WAN IP from any external network.
Configuration seems to be exactly the same as before the upgrade. I checked it when I was directly connected to my LAN.
Did anyone else encounter the same issue? Any tip or advice?
Chupaka
Mon Jul 09, 2018 2:38 pm
Any tip or advice?
Mention your previous version.
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Kuba1301
Mon Jul 09, 2018 2:47 pm
I think it was 6.41.X
Chupaka
Mon Jul 09, 2018 2:49 pm
Then you need to do basic diagnostics: ping your gateway, check traceroute...
venthyl
Mon Jul 09, 2018 5:38 pm
lhg60 6.42.5
connected: yes
frequency: 58320
remote-address: 04:D6:AA:AA:xxxx
mcs: 8
phy-rate: 2.3Gbps
signal: 70
rssi: -70
tx-sector: 38
tx-sector-info: right 1 degrees, up 0.2 degrees
rx-sector: 96
distance: 1950.1m
:) 750 mbps tcp
signal floating from 60 - 80
nickdwhite
Mon Jul 09, 2018 11:03 pm
I didn't see it listed in the changes or reported anywhere, but it looks like 6.42.5 also adds Temperature readings for RB450Gx4 under System > Health.
LeftyTs
Mon Jul 09, 2018 11:34 pm
Try to disable fasttrack in firewall, if you have it on. I have had a few problems with it in a few installations.
LeftyTs
Mon Jul 09, 2018 11:54 pm
Health problem with a 1100AHx2. Every 10-20 seconds current and power-consumption seem to flash on and off.
system health print interval=1
         fan-mode: auto
          use-fan: main
       active-fan: main
          voltage: 12.1V
      temperature: 32C
  cpu-temperature: 34C
       fan1-speed: 4579RPM
           fan-mode: auto
            use-fan: main
         active-fan: main
            voltage: 12.1V
            current: 936mA
        temperature: 32C
  power-consumption: 11.3W
         fan1-speed: 4591RPM
strods
Thu Jul 12, 2018 12:17 pm
New version 6.42.6 has been released in current RouterOS channel:
viewtopic.php?f=21&t=136731
Users browsing this forum: Agraham01 and 21 guests
