dasiu
Trainer
Trainer
PUSHOVER - ready MikroTik script to send messages
Fri Jun 29, 2018 12:19 am
I've just written a script (function) to send the Pushover messages directly from MikroTik, not using e-mail but direct API (faster). Just run once on bootup to "install" the functions:
:global urlEncode do={
  :local output ""
  :local input [:toarray $1]
  :if ([:len $input] > 0) do={
    :local input1 [:tostr [:pick $input 0]]
    :local conversion {" "="%20";"!"="%21";"\""="%22";"#"="%23";"\$"="%24";"%"="%25";"&"="%26";"'"="%27";"-"="%2D";"("="%28";")"="%29";"*"="%2A";"+"="%2B";","="%2C";"/"="%2F";":"="%3A";";"="%3B";"<"="%3C";">"="%3E";"="="%3D";"?"="%3F";"@"="%40";"["="%5B";"]"="%5D";"{"="%7B";"}"="%7D"};
    :for i from=0 to=([:len $input1] - 1) do={
      :local char [:pick $input1 $i]
      :if ([:typeof ($conversion->[:tostr $char])]!="nothing") do={:set $char ($conversion->[:tostr $char]);}
      :set output ($output . $char)
    :set output [:tostr $output]
    :set output [:toarray $output]
  :return $output
:global pushover do={
:global urlEncode;
  :if ([:typeof $message]!="nothing") do={
    :local api "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
    :local user "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
    :local urlmessage [$urlEncode $message];
    :local string "token=$api&user=$user&message=$urlmessage";
    :if ([:typeof $title]!="nothing") do={:set $string ($string . "&title=$[$urlEncode $title]");}
    :if ([:typeof $priority]!="nothing") do={:set $string ($string . "&priority=$priority");}
    :if ([:typeof $sound]!="nothing") do={:set $string ($string . "&sound=$sound");}
    /tool fetch mode=https url="https://api.pushover.net/1/messages.json" http-method=post http-data="$string";
Of course, in "api" and "user" variables I have my keys from Pushover (you need to create application in the Pushover panel). Then I can just do:
$pushover message="This is a simple Pushover message."
Or more advanced:
:local title "Important message from router $[/system identity get name]";
:local message "Just writing to inform you that my temperature is $[/system health get temperature] degrees Celsius!"
$pushover title=$title message=$message priority=1 sound="tugboat"
I used the urlEncode function written by few people in this thread.
cantanko
Re: PUSHOVER - ready MikroTik script to send messages
Wed Apr 03, 2019 9:12 pm
Thank you for this - it's proven to be a very helpful chunk of code!
danielcada
Tue Mar 03, 2020 7:16 pm
Works well on FW 6.45.5 including getting PUSHOVER from NETWATCH.
On FW 6.46.4 works only to send PUSHOVER manualy runing script, but doesn't work to send PUSHOVER from NETWATCH.
Any suggestion?
dreamind
Wed Apr 15, 2020 2:15 am
If you set keep-result=no on the fetch command in the script it works.
Also make sure you set the policy to something like policy=read,write,test on scripts that you want to run from netwatch.
Belikearu
Wed Apr 15, 2020 2:37 am
How do you exactly do this? pasting the script on the winbox terminal? and what about the API Keys?
Would you mind elaborating this one? thankyou
lacibsd
Sun May 02, 2021 3:43 am
@Belikearu, In Winbox or webintraface you can place it under System->Scripts
@dasiu, awesome script, I was looking for a pushover integration
tmiklas
Mon May 03, 2021 1:04 pm
Amazing - thank you!
Lilarcor
Fri May 21, 2021 9:06 am
I tried to use it in net watch, but it didn't work even I add keep-result=no in script
anav
Sat May 22, 2021 4:33 am
I use telegram to send me messages from my router.
Is pushover easier/better to use??
Lilarcor
Thu Oct 14, 2021 8:35 am
$pushover message="xyz" does work in terminal, but it doesn't work in scripts
update:
add
:global pushover
and I can use $pushover now
RandyRiver88
Thu May 26, 2022 11:52 pm
update:
add
:global pushover
Where did you fix this? I am able to send using terminal but not in from inside of scripts….
Can you tell me which line to changed?
Thanks.
rextended
Fri May 27, 2022 12:02 am
Simply READ carefully pervious post...
RandyRiver88
Fri May 27, 2022 5:03 am
The post is not clear. It does not state where to add it.
The correct answer would have been:
Add :global pushover in the script you are calling $pushover in.
No need to be a dick.
rextended
Fri May 27, 2022 10:29 am
I was helpful, seen? Now you have read it carefully...
esj
Mon Jul 01, 2024 3:41 pm
Thank you for the script.
Working perfectly. To test I run the script below
:global pushover
Amm0
Mon Jul 01, 2024 11:47 pm
Pushover also support JSON as an input. And in 5 years since the OP, Mikrotik added JSON support RouterOS scripting (7.13+).
While I'm sure the existing script is fine, I re-wrote to take an RouterOS array with ANY of the allowed by pushover's API. Since new [:serialize] will deal with types and escaping when converting the RouterOS array into JSON needed by pushover... the code gets dramatically simplier:
npushover code
:global npushover do={
    :local url "https://api.pushover.net/1/messages.json"
    :local headers "Content-Type: application/json"
    :local reqdata [:toarray ""]
    :if ([:typeof $1]="array") do={:set reqdata $1} else={
        :error "\$$0 requires an array of values to set, see https://pushover.net/api"
    :local json [:serialize to=json $reqdata]
    :local resp [/tool/fetch url=$url http-data=$json http-header-field=$headers output=user as-value]
    :local respdata [:deserialize from=json ($resp->"data")]
    :if (($respdata->"status")=1) do={
        /log/debug "$0 $[:put "successfully sent request $($respdata->"request")"]"
    } else={
        /log/warning "$0 failed, got: $[:tostr $resp]"
        :error $resp
To send a message using pushover using the $npushover <array> above, and using an array allows any of the attributes supports like url or priority:
$npushover ({
        user="u8xxxxxxxxxxx"
        token="acyqxxxxxxxxxxxxxxx"
        message="Perhaps some <b>HTML</b>"
        title="Test Message"
        html=1
        sound="magic"
        priority=0
        url="https://router.lan/rest/system/resource"
        "url_title"="/system/resources"
See https://pushover.net/api for possible/allowed values. No validation is provided, kinda by design. Errors should be output and logged, likely giving a clue as the right values. And stuff like "priority" has additional allowed attributes like "retry", so validation might block that (or get very complex).
davorjs
Sat Jul 06, 2024 4:28 am
Thank you very much Ammo, your script is very timely as I only discovered Pushover two days ago.
Much simpler than Telegram
Cheers Dave.
esj
Sun Jul 07, 2024 7:50 pm
$npushover ({
        html=1
        sound="magic"
        priority=0
Thank you Amm0. one question. How can I add info from RouterOS in the message. e.g. interface/lte/monitor lte1
I've tried
:global npushover
$npushover ({
        user="private"
        token="private"
        message="Mikrotik SXT Rebooted <b>nPushover</b> $[interface/lte/monitor lte1 duration=2]"
        title="MikroTik SXTR"
        html=1
        sound="magic"
        priority=0
        url="https://192.168.x.1"
        "url_title"="MikroTik"
.. and it executes, but no info from the LTE is included in the message. Any pointers appreciated.
Amm0
Tue Jul 09, 2024 4:02 am
:global npushover
$npushover ({
        user="private"
        token="private"
        html=1
        sound="magic"
        priority=0
All of the commands with "monitor" are tricky, since it's like a "for loop"... So you need to remove "duration" and use "once" instead.
:global npushover
$npushover ({
        user="private"
        token="private"
        message="Mikrotik SXT Rebooted <b>nPushover</b> $[interface/lte/monitor lte1 once as-value]"
        html=1
        sound="magic"
        priority=0
The "once" cause the /interface/lte/monitor to only return one set of value to insert into the message. You could use a duration, but that requires collecting the LTE monitor data into a new variable, and then using the new variable in the message.
esj
Tue Jul 09, 2024 12:57 pm
:global npushover
$npushover ({
        user="private"
        token="private"
        message="Mikrotik SXT Rebooted <b>nPushover</b> $[interface/lte/monitor lte1 once]"
        html=1
        sound="magic"
        priority=0
Thank you for this. Either version of the code $[interface/lte/monitor lte1 once] doesn't add data/content at all to the message (not even the code is included). It this the correct way to pull MikroTik data into the message that is sent?
The received message is as attached (sorry can't seem to attach message)
https://imgur.com/xlI5yVq
UPDATE: This works though
message="Mikrotik SXT Rebooted <b>nPushover</b> $[/system clock get time] $[/system clock get time] $[/system identity get name]"
Amm0
Tue Jul 09, 2024 10:40 pm
My bad. I forgot to add the "as-value" — that's critical to returning the data for the string. So it should be "$[/interface/lte/monitor lte1 once as-value]".
esj
Sat Jul 13, 2024 8:12 pm
Hey Ammo, many thanks for changing this, but unfortunately this doesn't work and I get no message at all. The clock and system names work, as I said in my previous examples. These are 1 line results, though.
e.g.
message="Mikrotik SXT Rebooted <b>nPushover</b> $[/system clock get time] $[/system identity get name]"
I'm wondering if it is because the output of LTE monitor has many line of info ... that it is not escaping or processing the lines properly :?
Does this code work on your device pushover? or is there a multi-line output we could check?
Amm0
Sat Jul 13, 2024 9:42 pm
It's not the multi-line output per se. It the data type returned by "monitor" is a RouterOS array type. And one rule (which I forgot in my quick example of LTE monitor) is array cannot be interpolated, so a ":tostr" is needed. This will get rather ugly output, but should work:
$npushover ({
        user="private"
        token="private"
        message="Mikrotik SXT Rebooted <b>nPushover</b><br><pre> $[:tostr [/interface/lte/monitor lte1 once as-value]]</pre>"
        html=1
        sound="magic"
        priority=0
Alternatively, you can collect the LTE monitor BEFORE build the PUSHOVER message, and use invidudual data items from LTE monitor in the string, like this:
:global npushover
:local mdata [/interface/lte/monitor lte1 once as-value]
$npushover ({
        user="private"
        token="private"
        message="Mikrotik SXT Rebooted <b>nPushover</b><br><pre>$($mdata->"primary-band") sinr: $($mdata->"sinr") rsrq: $($mdata->"rsrq") rsrp: $($mdata->"rsrp")</pre>"
        html=1
        sound="magic"
        priority=0
esj
Sun Jul 14, 2024 2:49 am
Ammo. You really are a very clever person. Both work for me :D
Users browsing this forum: No registered users and 18 guests
