martin3444
Problem running script(s)
Tue Jul 24, 2018 2:25 am
I have quite a weird problem with running my scripts.
Problem:
I have a script, that basically runs every day at 3AM and takes a backup from my router.
It works perfectly fine, but after some time (1 day or more) the script stops working. With error message: script error: action failed (6).
I've found a temporary solution for that. If I restart my router, then this script works fine again. But I really don't want to restart my router every day.
Script:
:global getDateTime do={
  :local thisdate [/system clock get date];
  :local year [:pick $thisdate 7 11];
  :local month [:pick $thisdate 0 3];
  :if ($month="jan") do={[:set $month "01"]};
  :if ($month="feb") do={[:set $month "02"]};
  :if ($month="mar") do={[:set $month "03"]};
  :if ($month="apr") do={[:set $month "04"]};
  :if ($month="may") do={[:set $month "05"]};
  :if ($month="jun") do={[:set $month "06"]};
  :if ($month="jul") do={[:set $month "07"]};
  :if ($month="aug") do={[:set $month "08"]};
  :if ($month="sep") do={[:set $month "09"]};
  :if ($month="oct") do={[:set $month "10"]};
  :if ($month="nov") do={[:set $month "11"]};
  :if ($month="dec") do={[:set $month "12"]};
  :local day [:pick $thisdate 4 6];
  :local datetimestring ([$day] . "." . [$month] . "." . [$year]);
  :return ($datetimestring)
/system backup save name=("disk1/backups/" . [$getDateTime] . ".backup")
/export file=("disk1/backups/" . [$getDateTime] . ".rsc")
Router information:
Model: 951G-2HnD
Firmware: 6.42.6
RouterOS: 6.42.6
PS: I've only added one script, because other scripts have the same problem.
martin3444
Re: Problem running script(s)
Tue Jul 24, 2018 11:00 pm
Anyone?
dasiu
Trainer
Trainer
Wed Jul 25, 2018 9:20 pm
Tried using local instead of global? Not ":global getDateTime" but ":local getDateTime"? If you have few scripts and they all have this function - they overwrite it and maybe it's causing the problem if they are doing it in the same time?
ADahi
Wed Jul 25, 2018 10:40 pm
+1
Try
:do {
:local getDateTime do={
:do {/system backup save name=("disk1/backups/" . [$getDateTime] . ".backup")} on-error={:log warning message="Backup failed..."}
:do {/export file=("disk1/backups/" . [$getDateTime] . ".rsc")} on-error={:log warning message="Export failed..."}
} on-error={:log warning message="Script failed..."}
and see log for error report
martin3444
Thu Jul 26, 2018 1:57 am
+1
Try
:do {
Hello and thank you for your answers. I'll test your modified script and replay after some days.
martin3444
Thu Jul 26, 2018 4:59 pm
+1
Try
:do {
Hello!
The script works BUT after some time it does not work again. But I accidentally stumbled upon a problem that my flash drive, where these backups go, is read only.
When I restart my router, then the flash drive is perfectly fine but after some time it is read only again. Can't even delete files from there.
I'm trying a different flash drive, maybe it's dying.
Thank you.
martin3444
Re: Problem running script(s)  [SOLVED]
Thu Aug 02, 2018 10:08 pm
New flash drive solved the problem.
Thank you all!
mtssolution
Sun May 17, 2020 4:08 am
Hi, I have a same problem with RB3011 router, coud you tell me how to chhange the flash memory? please.
Regards
Users browsing this forum: No registered users and 22 guests
