MUM Europe 2020
becs
SwOS version 2.8 released!
Wed Jul 25, 2018 11:26 am
http://www.mikrotik.com/download
What's new in v2.8:
*) CRS317: fixed links not coming up after power failure;
*) CRS317: added extra information about FAN & PSU health;
*) CRS317: fixed load balancing over aggregated links;
*) CRS317: increased per port queue size;
*) CRS328-24P-4S+: make FAN work;
*) CRS328-24P-4S+: added extra information about health;
*) CRS328-24P-4S+: do not power cycle PoE outputs on reboot;
*) CRS328-24P-4S+: added voltage-level setting;
*) CRS328-24P-4S+: make SFP3 port work;
*) CRS328-24P-4S+: expose PoE port status via SNMP;
*) CRS328-4C-20S-4S+: make FAN work;
*) CRS328-4C-20S-4S+: added extra information about health;
*) CSS106: expose PoE port status via SNMP;
*) CSS106: always strip VLAN header on ports with disabled VLAN mode;
*) CSS106: make access to SwOS work over VLAN 1, put vlan header in replies;
*) CSS106: do not vlan tag RSTP BPDU packets, makes RSTP work with RouterOS;
*) CSS106: forward IGMP query messages even when IGMP snooping is disabled;
*) make PPPoE & DHCP snooping work on CRS326 & CRS328;
*) CRS326 & CRS328: make removed ACL rule stop working;
*) CRS326 & CRS328: learn MAC addresses even redirecting packets from ACL;
*) CRS326 & CRS328 & CRS317: added strict VLAN mode;
*) if "Allow From VLAN" is specified, make discovery packets use it;
*) make DHCP client work with RFC non compliant DHCP servers;
*) do not allow to create multiple VLANs with the same id;
*) provide health information (temperature, fan speed, psu state) via SNMP;
*) provide SFP port healt information via SNMP;
*) use 64bit counters under Stats tab for byte accounting;
Simono
Re: SwOS version 2.8 released!
Wed Jul 25, 2018 8:16 pm
My CSS106-1G-4P-1S don't see this upgrade.
nicoguido
Wed Jul 25, 2018 8:39 pm
Upgrade flawlessly on my CRS317, with manual update, because only version 2.7 is available yet on the upgrade page.
Good points :
- fans are managed correctly !! 8)
- sfp page gives more informations on FS sfp ethernet 1G.
Good job guys :D
Simono
Wed Jul 25, 2018 11:39 pm
For me manual upgrade don't work. I only see "don't interrupt", switch reboted (I see it uptime on router in neigbord)
k6ccc
Thu Jul 26, 2018 12:11 am
None of my switches see it as an available upgrade. Have not the time at the moment to try a manual upgrade yet.
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Jim
k6ccc
Thu Jul 26, 2018 12:30 am
Are you sure? I did take the time to do a manual update on my CSS106-5G-1S. Prior to the upgrade, I started a continuous ping to the switch from this PC. After starting the upgrade, i missed exactly one ping and the only indication was the top section of the page now says:
Current Installed Version 2.8 (built at Fri Jul 13 2018 04:37:01 GMT-0700 (Pacific Daylight Time))
Latest Available Version 2.7 (built at Fri Dec 15 2017 00:42:48 GMT-0800 (Pacific Standard Time))
Jim
indnti
Thu Jul 26, 2018 12:46 am
CSS326-24G-2S+ v 2.7 doesn't see the upgrade on the upgrade page.
After upgrading manually from 2.7 to 2.8 the switch boots into 2.0p - from that version I can upgrade manually to 2.8 ...
Storycrafter
Sun Jul 29, 2018 3:21 am
I had a mixed result. One switch mirrored your experience, and the other went from 2.7 to 2.8 without the intermediate 2.0p version. I had to upgrade both manually.
I think RSTP is still broken, though.
Simono
Sun Jul 29, 2018 2:56 pm
For me first manual upgrade caused dowbgrade to 2.4p then after second manual upgrade I've get version 2.8 on switch.
anuser
Sun Jul 29, 2018 11:18 pm
CRS+CSS: How many ports can be aggregated concurrently with LACP at maximum?
shanefletch
Mon Jul 30, 2018 8:03 am
Does anyone else run SwOS v2.8 on a CSS326-24G, monitoring with Observium?
I see a line in the changelog that says "provide SFP port healt information via SNMP" - should I expect DOM (tx/rx power) to be made available via SNMP as a result of this?
k6ccc
Tue Jul 31, 2018 7:01 pm
Suggestion. If you are going to ask a question that is totally unrelated to the current topic, start a new post rather than ask in an unrelated thread. For one thing it makes finding the question and answer far easier when the subject relates to the question.
Jim
nuffrespect
Fri Aug 03, 2018 3:58 pm
@becs
Hi we have some problems with CRS328-24P after 2.8 update
First of all, while downloading files - we have swos-css328p-2.8.bin - why CSS328??
It updates normally, but some devices - has that bug, see below link to SWOs topic
viewtopic.php?f=17&t=137372
nuffrespect
Sat Aug 04, 2018 3:56 pm
@becs
Hi, again
Another bugs with POE tab & SFP+ tab in SWos 2.8
SFP+ tab
Until force reboot - i saw empty excels in table with (Temp. Voltage, Tx bias
Force reboot (System --> reboot) - SOLVED this
POE tab
Port 22 - do not "waiting for load"
ScreenShots - here
viewtopic.php?f=17&t=137659
PigLover
Sat Aug 04, 2018 8:50 pm
Same with mine.
Also, switch was configured for "static" for the management IP but after upgrade came back as "DHCP with fallback" - which resulted in an address change. Took me a while to find the switch. Easily set back to static but if I had more than 1 of these these I'd be irritated by this.
nuffrespect
Sun Aug 05, 2018 11:22 am
@becs
UPD
The bug with wrong values of temp & rpm
still here.
Well, few hours later, after forced update or reboot, on some switches we have the same issue:
- 62C CPU temp
- 0С board temp
- 0 RPM
- 0 RPM
- Empty value parameters, in some SFP+ tab excels
Of coarse, forced reboot, can solve the issue, but it repeats again.
What’s wrong with this 2.8 update?
RobertF
Sun Aug 05, 2018 10:41 pm
German IPTV (Entertain TV, MR401/201) still not working at all with this SwOS version (CSS326). No IGMP v3.
Picture freezes after a few seconds.
Latest usable version is 2.4 (with packet flood on all ports due to missing IGMP)
Please implement IGMP v3 in next update.
Thanks.
Robert
nuffrespect
Wed Aug 08, 2018 3:30 pm
@Mikrotik team
Hi!
Say us where i can find firmware 2.7p for CRS328PoE to make downgrade until some bugs in 2.8 will be solved?
becs
Thu Aug 09, 2018 3:31 pm
We are investigating your reported issues about missing information in CRS328-24P-4S+ SFP and PoE menus.
Meanwhile, you can load primary SwOS v2.7p from Serial Console in the same way as on CRS326-24G-2S+
https://wiki.mikrotik.com/wiki/SwOS/CSS ... _Reinstall
onur
Thu Aug 09, 2018 3:59 pm
on my CSS326-24G-2S+ manual upgrade dont works.
switch not accessible(web) after manual upgrade.
to access the switch again, i had to boot backup SwOS.
i tried upgrade from backup SwOS(2.0p) to 2.8, and reset configuration - but no success.
williankevenis
Wed Aug 15, 2018 5:49 pm
Please, Mikrotik team. Verify that the latest versions of SwOS are causing problems in IPTV services. Forcing even us users and network administrators to downgrade to versions like 2.4 and 2.0b of SwOs.
Ps. I am use RB260GS
This is very important to us. I would like you to have an answer and to deal with it urgently. Since it has already been mentioned in other posts, as follows list of links below.
viewtopic.php?t=126752&sid=85f2c8e78199 ... b4e4db6b3b
viewtopic.php?f=21&t=128917
k6ccc
Wed Aug 15, 2018 6:11 pm
Most likely the switch changed from a static IP to DHCP. Check your DHCP server to find out IP what it was assigned. Then connect to that address and change it back to static on the desired address. Other option would be to set a DHCP reservation in the DHCP server so the switch always gets the same address.
Jim
RedM
Sun Aug 26, 2018 6:03 pm
CRS317-1G-16S+ on 2.8 seems to lose LAGs after a while.
I've tried a reboot but it comes back.
I did not know about the fan issue however mine should be cooled enough anyway, but I'd prefer the fix.
I've reverted to 2.7 until this showstopping bug is fixed.
dapilori90
Tue Aug 28, 2018 5:23 pm
What is the difference between this new "strict" VLAN mode and the enabled mode, described in https://wiki.mikrotik.com/wiki/SwOS/CSS326?
Mario606
Fri Aug 31, 2018 4:39 pm
Hi all. I have been using these switches in switch mode since they have been released. One continuous issue is that when you probe the device via SNMP for a few days it suddenly starts acting up. Seems like its just the management interface as traffic flows smoothly via the device but ICMP responds at 2000+ms and you struggle to access the gui. Is there anyway I can get a support output on the device whilst this is happening? The only fix is a physical reboot. Current F/W is 2.8
andriys
Fri Aug 31, 2018 7:02 pm
What switches? Please specify exact model(s).
Some small switches (like the RB260 series) are known to have a rather weak CPU which can easily be maxed out when being constantly monitored via ICMP.
eider
Tue Sep 11, 2018 10:09 pm
There seems to be some issue with CSS106 and 64-bit counter - either both SNMP and JavaScript are not updated to support it or internally this switch still uses 32-bit counters despite SNMP and JavaScript expecting 64-bit. Either way, this causes bogus values to be printed, despite switch actually properly counting packets (as seen by direct request to !stats.b). More details here: viewtopic.php?f=17&t=139046
In addition, it looks like CSS106 tries to fetch update from https://upgrade.mikrotik.com/swos2/css1 ... 06-2.8.bin however correct URI is https://upgrade.mikrotik.com/swos2/css1 ... 1s-2.8.bin. To top this up, LATEST returns "2.8.1531481837" and CHANGELOG simply returns "2.8.1531481821". Switch reports it's ready to update from "2.8 (built at Fri Jul 13 2018 13:37:01 GMT+0200 (Central European Summer Time))" to "2.8 (built at Fri Jul 13 2018 13:37:17 GMT+0200 (Central European Summer Time))".
Paternot
Long time Member
Long time Member
Wed Sep 12, 2018 3:57 am
I can confirm port22 without "waiting for load". CRS328-24P-4S+, SwOS 2.8
Buckeye
Fri Sep 14, 2018 1:45 am
I have only CSS106, but the documentation for it has the following:
"strict - Same as enable, but also checks VLAN support for inbound interface (drop packets with VLAN tag ID and ingress port that are not present in VLAN table)"
From https://wiki.mikrotik.com/wiki/SwOS/CSS106
nuffrespect
Fri Sep 14, 2018 10:10 am
@Mikrotik team
How soon you will send us update of the SWOs 2.8 version without bugs, with Poe info, Fans, SFP+ Values, RPM, etc. ?
deltoro
Sun Sep 16, 2018 12:20 pm
CSS106-5G-1S
SNMP not working. V1
work on v.2 only
Paternot
Long time Member
Long time Member
Sun Sep 16, 2018 2:47 pm
CRS328-24P-4S+ have problems with SFP+: high count of Rx MAC Errors and Rx FCS Errors. Using fiber and S+85DLC03D modules.
viewtopic.php?f=17&t=139155
williankevenis
Fri Oct 19, 2018 2:57 pm
Becs You have reply?
Alestrix
Sat Oct 27, 2018 10:51 pm
I always thought this is what "enabled" does. Does this mean that "enabled" always lets tagged packets in on a port if that VLAN is merely configured on the switch, even if there is no tick in the checkbox for this particular port in the "VLANS" tab? In other words the selections in the "VLANS" tab only apply to outbound packets? This is quite unexpected and a security issue IMHO.
BR
Alex
Mario606
Wed Nov 07, 2018 8:25 am
Hi Andriys, Im using the CRS317model, I have 4 in production at peak they switch around 7Gbps without any issues but accessing the gui is just a pain. If we reboot the device its flawless for a few days.
rofrigo2
Sat Nov 10, 2018 5:08 pm
After one year still multicast doesn't work.
Have to use 2.4.
Disappointed.
anav
Sun Nov 11, 2018 6:30 pm
Why does my switch revert back to software 2.0 with a reset?
It should switch back TO THE DEFAULT settings for the latest firmware installed.
Or at least have a two image setup. (last good working vers and latest version added).
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
becs
Mon Jan 14, 2019 5:34 pm
Version 2.9 of SwOS has been released with many v2.8 issues addressed:
viewtopic.php?f=21&t=144031
Users browsing this forum: LeftyTs and 9 guests
