I found UDPspeeder on https://github.com/wangyu-/UDPspeeder: "A Tunnel which Improves your Network Quality on a High-latency Lossy Link by using Forward Error Correction."
I would like to suggest a similar feature for EoIP tunnels. What about an addon which you can simply activate/deactivate Forward Error Correction for a connection? Is there anything on the roadmap?
What do you think?
Regards
