yuriadmin
How can I install dude in MIPSBE?
Fri Aug 03, 2018 6:33 am
Hello everyone,
1- is there a way to install the dude package in Mikrotik Router that currently has MIPSBE package?
2- Can I change Mikrotik Router Package from MIPSBE to X86 and how?
normis
Re: How can I install dude in MIPSBE?  [SOLVED]
Fri Aug 03, 2018 1:42 pm
No.
Dude only works on the following systems:
Tile - CCR series hardware
ARM - RB3011, RB1100AHx4 Dude Edition (RB1100Dx4), hAP AC2*
mmips - hEX (RB750Gr3)*, M33*
RouterOS x86 installations
RouterOS CHR environment
You can't change packages. The CPU is the one that determines what packages you need. You need to change hardware, use a different router model.
deadManN
Sat Dec 22, 2018 11:36 am
then how can we install MMIPS inside such router that already has MIPSBE? how to change OS? And does this architect, support wireless? i own RB951G-2hnd
Users browsing this forum: No registered users and 2 guests
