victorsoares
BGP Failover issues
Fri Aug 10, 2018 5:44 pm
Hello everyone.
Let me try to explain my scenario. I have two BGP sessions from two different AS coming to my CCR1072-1G-8S+. Both of them are active and working. They both have the same speeds (3Gbps full).
I want to make BGP 1 (superimagem) primary and BGP 2 (nip) secondary. I have set BGP weight, local preference and MED on filters for both iBGP's. I'm going to post my filters and my BGP configurations below. What am I doing wrong?
Filters:
# aug/10/2018 11:27:40 by RouterOS 6.42.6
# software id = SLL9-BT75
# model = CCR1072-1G-8S+
# serial number = --------------
/routing filter
add action=accept chain=ebgp_superimagem_v4_in prefix=0.0.0.0/0 \
    set-bgp-local-pref=200 set-bgp-med=10 set-bgp-weight=300
add action=discard chain=ebgp_superimagem_v4_in set-bgp-local-pref=200 \
    set-bgp-weight=300
add action=accept chain=ebgp_superimagem_v4_out disabled=yes prefix=\
    XXX.XXX.XXX.X/24 set-bgp-local-pref=100 set-bgp-weight=300
add action=accept chain=ebgp_superimagem_v4_out prefix=XXX.XXX.XXX.X/24 \
add action=accept chain=ebgp_superimagem_v4_out prefix=XXX.XXX.XXX.X/23 \
add action=accept bgp-communities="" chain=ebgp_superimagem_v4_out prefix=\
    XXX.XXX.XXX.X/24 set-bgp-local-pref=200 set-bgp-med=10 set-bgp-weight=300
add action=reject chain=ebgp_superimagem_v4_out prefix=XXX.XXX.XXX.X/30
add action=discard chain=ebgp_superimagem_v4_out set-bgp-local-pref=200 \
add action=accept chain=ebgp_nip_v4_in prefix=0.0.0.0/0 set-bgp-local-pref=0 \
    set-bgp-med=50 set-bgp-weight=100
add action=discard chain=ebgp_nip_v4_in set-bgp-local-pref=0 set-bgp-med=50 \
    set-bgp-weight=100
add action=accept chain=ebgp_nip_v4_out prefix=XXX.XXX.XXX.X/24 \
    set-bgp-local-pref=0 set-bgp-med=50 set-bgp-weight=100
add action=accept chain=ebgp_nip_v4_out prefix=XXX.XXX.XXX.X/23 \
add action=discard chain=ebgp_nip_v4_out set-bgp-local-pref=0 set-bgp-med=50 \
    set-bgp-weight=100
add action=accept chain=ibgp-mpv-in prefix=0.0.0.0/0 set-bgp-local-pref=0 \
    set-bgp-med=20 set-bgp-prepend=3 set-bgp-weight=100
add action=accept chain=ibgp-mpv-in prefix=XXX.XXX.XXX.X/24 set-bgp-local-pref=\
    0 set-bgp-med=20 set-bgp-prepend=3 set-bgp-weight=100
add action=accept chain=ibgp-mpv-in prefix=XXX.XXX.XXX.X/23 set-bgp-local-pref=\
add action=discard chain=ibgp-mpv-in set-bgp-local-pref=0 set-bgp-prepend=3 \
    set-bgp-weight=100
add action=accept chain=ibgp-mpv-out prefix=XXX.XXX.XXX.X/24 \
    set-bgp-local-pref=0 set-bgp-med=20 set-bgp-prepend=3 set-bgp-weight=100
add action=accept chain=ibgp-mpv-out disabled=yes prefix=XXX.XXX.XXX.X/24 \
    set-bgp-weight=100
    set-bgp-weight=100
add action=accept chain=ibgp-mpv-out disabled=yes prefix=XXX.XXX.XXX.X/23 \
    set-bgp-weight=100
add action=accept chain=ibgp-mpv-out prefix=XXX.XXX.XXX.X/23 \
    set-bgp-weight=100
    set-bgp-weight=100
    set-bgp-weight=100
    set-bgp-weight=100
    set-bgp-weight=100
    set-bgp-weight=100
    set-bgp-weight=100
    set-bgp-weight=100
add action=accept chain=ibgp-mpv-out disabled=yes prefix=0.0.0.0/0 \
    set-bgp-weight=100
add action=discard chain=ibgp-mpv-out set-bgp-weight=100
BGP:
# aug/10/2018 11:28:00 by RouterOS 6.42.6
/routing bgp instance
set default as=XXXXX client-to-client-reflection=no router-id=X.X.X.X
add as=XXXXX ignore-as-path-len=yes name=superimagem router-id=\
    X.X.X.X
add as=1 client-to-client-reflection=no name=interno redistribute-connected=\
    yes router-id=X.X.X.X
add as=XXXXX ignore-as-path-len=yes name=nip router-id=X.X.X.X
/routing bgp network
add network=XXX.X.XXX.0/24 synchronize=no
add network=XXX.X.XXX.0/23 synchronize=no
/routing bgp peer
add in-filter=ebgp_nip_v4_in instance=nip multihop=yes name=BGP-NIP \
    nexthop-choice=force-self out-filter=ebgp_nip_v4_out remote-address=\
    XXX.XXX.XXX.X remote-as=XXXXX ttl=default update-source=vlan_nip_ubatuba
add in-filter=ebgp_superimagem_v4_in instance=superimagem multihop=yes name=\
    BGP-SUPERIMAGEM-V4 out-filter=ebgp_superimagem_v4_out remote-address=\
    XXX.XXX.XXX.X remote-as=XXXXX ttl=default update-source=\
    vlan_super_ubatuba
add in-filter=ibgp-mpv-in instance=interno multihop=yes name=BGP-INTERNO \
    nexthop-choice=force-self out-filter=ibgp-mpv-out remote-address=\
    XXX.XXX.XXX.X remote-as=1 ttl=default update-source=vlan_caragua
add disabled=yes in-filter=ibgp-mpv-in name=BGP-CARAGUA out-filter=\
    ibgp-mpv-out remote-address=191.7.144.1 remote-as=263320 ttl=default
MTCNA MTCRE
paulct
Re: BGP Failover issues
Fri Aug 10, 2018 6:00 pm
What is the issue?
victorsoares
Fri Aug 10, 2018 6:05 pm
I'm sorry, completely forgot to talk about the issue itself. The thing is that when both sessions are up, BGP 2 (NIP) gets more traffic that BGP 1, and it should be the opposite.
MTCNA MTCRE
IPANetEngineer
Trainer
Trainer
Fri Aug 10, 2018 8:43 pm
So we need to understand whether you're trying to influence traffic coming in from your upstream (normally a "download" for a user) or traffic from your network going outbound (normally an "upload" for a user)
There are different ways to influence BGP depending on what you're trying to do.
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
victorsoares
Sun Aug 12, 2018 12:34 am
Traffic coming upstream, downstream is pretty much sorted at this point. I just want that RX on my links goes to BGP 1 (superimagem)
MTCNA MTCRE
TFyre
Sun Aug 12, 2018 12:06 pm
What you are trying to achieve is close to impossible (50/50 equal balance).
Your inbound traffic is not as much affected by yourself as by your upstream peers & their peers.
Referring to: https://wiki.mikrotik.com/wiki/Manual:B ... _Algorithm
Generally trying to force traffic flow in a certain path is not advised since you can sometimes introduce latency or other adverse effects.
Possible solutions (to affect how the rest of the world sees your network):
  • BGP Prepends to either upstream peer. This will let your network LOOK like its X hops further, so the another path might be selected as the best path
  • Route de-aggregation. You can advertise more specific prefixes to either of the 2 upstreams
Route de-aggregation:
Lets assume you have 155.155.0.0/22 as your assigned prefix
You advertise 155.155.0.0/22 to superimagem & nip
You advertise 155.155.0.0/23 to superimagem
You advertise 155.155.2.0/23 to nip
Depending on what sits behind either of the 2x /23's traffic would be somewhat more balanced. You also get the full fail over in case either upstream goes down since you advertise your full prefix to both
victorsoares
Mon Aug 13, 2018 3:47 pm
Thank you for your help. I already tried prepending, and it got me to a certain point, but I think that the de-aggregation might be the best way. I'll try this and see how it works. Thanks again for the help!
MTCNA MTCRE
Users browsing this forum: Baidu [Spider] and 12 guests
