german77
Groove no boot Fix
Mon Aug 13, 2018 8:11 pm
I have many faulty groove's. But I found a way to fix 40% of the devices. When 2 lights are on all the time or the first four are on and the other two are kind of blinking. The solution is to remove the heat-sink. As funny as it sounds the heat-sink causes those problems. Of course you need the heat-sink otherwise it will over heat. The only problem is that how you will fix this problem permanently and why happens now and not when it's new.
I tried cleaning the termal paste and replacing it with a non-conductive termal paste. Even used a thick layer to ensure that the heat-sink doesn't make a short of some kind. They all still are faulty when I put back the heat-sink. The only semi-permanent solution I found is to remove the screw that is closest to the capacitor c32, if I tighten that screw the groove starts to fail.
Is this a know design problem? Or what else could it be? All the thermal pads/screws are ground so even if the heat-sink makes continuity, it shouldn't matter. The most posible problem it's a cracked solder point or component that when the heat-sink presses against the PCB causes it to fail open.
vaniz
Re: Groove no boot Fix
Tue Dec 11, 2018 2:46 am
Hi bro, me to same as your problem. Loose some screw these normal. Other way it happen again.
What exactly trouble. I don't no
KSharon
Tue Dec 11, 2018 8:37 am
we can try some methods to correct faulty grooves like by using wood strip filler or applying rope filler method.
Users browsing this forum: No registered users and 26 guests
