tejendragurung
Juniper - Mikrotik LDP/BGP based VPLS
Wed Aug 15, 2018 2:37 pm
Query:
the BGP/LDP/VPLS/OSPF all protocols are UP and established but still the client_A to client_C can't ping in vlan_800(configured the BGP VPLS).
But within client_A to client_B (both connected to JUniper PE) can ping .
Please help to verify the configuration for establishing the VPLS connectivity between clients.
Any support would be thankfull.
Ping from Client A to client B and Client C
[admin@SITE-A-CLIENT] > ping 192.168.108.2
SEQ HOST SIZE TTL TIME STATUS
0 192.168.108.2 56 64 0ms
1 192.168.108.2 56 64 0ms
2 192.168.108.2 56 64 0ms
sent=3 received=3 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
[admin@SITE-A-CLIENT] > ping 192.168.108.3
0 192.168.108.3 timeout
1 192.168.108.3 timeout
2 192.168.108.3 timeout
sent=3 received=0 packet-loss=100%
Ping from Client B to client A and Client C
[admin@SITE-B-CLIENT] > ping 192.168.108.1
0 192.168.108.1 56 64 0ms
1 192.168.108.1 56 64 0ms
2 192.168.108.1 56 64 0ms
[admin@SITE-B-CLIENT] > ping 192.168.108.3
vianoc@SITE-A> show vpls connections instance Juniper-Mikrotik
Layer-2 VPN connections:
Instance: Juniper-Mikrotik
Edge protection: Not-Primary
Local site: CLIENT-A (96)
connection-site Type St Time last up # Up trans
97 rmt Up Aug 14 15:36:49 2018 1
Remote PE: 103.10.30.97, Negotiated control-word: No
Incoming label: 47, Outgoing label: 51
Local interface: lsi.1048834, Status: Up, Encapsulation: VPLS
Description: Intf - vpls Juniper-Mikrotik local site 96 remote site 97
Flow Label Transmit: No, Flow Label Receive: No
98 rmt Up Aug 14 14:05:34 2018 1
Remote PE: 103.10.30.98, Negotiated control-word: No
Incoming label: 48, Outgoing label: 36
Local interface: lsi.1048832, Status: Up, Encapsulation: VPLS
Description: Intf - vpls Juniper-Mikrotik local site 96 remote site 98
vianoc@SITE-B> show vpls connections instance Juniper-Mikrotik
Local site: CLIENT-B (97)
96 rmt Up Aug 14 15:37:13 2018 1
Remote PE: 103.10.30.96, Negotiated control-word: No
Incoming label: 51, Outgoing label: 47
Local interface: lsi.1048833, Status: Up, Encapsulation: VPLS
Description: Intf - vpls Juniper-Mikrotik local site 97 remote site 96
98 rmt Up Aug 14 15:39:14 2018 1
Incoming label: 37, Outgoing label: 37
Description: Intf - vpls Juniper-Mikrotik local site 97 remote site 98
[admin@SITE-C] > interface vpls print
Flags: X - disabled, R - running, D - dynamic, B - bgp-signaled, C - cisco-bgp-signaled
0 RDB name="vpls11" mtu=1500 l2mtu=1500 mac-address=02:3C:B1:FC:43:D2 arp=enabled arp-timeout=auto disable-running-check=no remote-peer=103.10.30.96
cisco-style=no cisco-style-id=0 advertised-l2mtu=1500 pw-type=raw-ethernet use-control-word=no vpls=Juniper-Mikrotik
1 RDB name="vpls12" mtu=1500 l2mtu=1500 mac-address=02:3C:B1:42:A5:DC arp=enabled arp-timeout=auto disable-running-check=no remote-peer=103.10.30.97
2 RDB name="vpls13" mtu=1500 l2mtu=1500 mac-address=02:89:F0:C0:B4:B0 arp=enabled arp-timeout=auto disable-running-check=no remote-peer=103.10.30.96
cisco-style=no cisco-style-id=0 advertised-l2mtu=1500 pw-type=raw-ethernet use-control-word=no vpls=Juniper-Mikrotik-BGP
3 RDB name="vpls14" mtu=1500 l2mtu=1500 mac-address=02:92:C5:34:A7:B6 arp=enabled arp-timeout=auto disable-running-check=no remote-peer=103.10.30.97
[admin@SITE-C] >
Topology :
client_A(Mikrotik) ----- SITE_A(Juniper)------------------SITE_C(Mikrotik)-----client_C(Mikrotik)
-------------------SITE-A JUNIPER----------------------------
vianoc@SITE-A> show configuration | display set
set version 17.4R1.16
set system host-name SITE-A
set interfaces xe-0/1/0 description "Uplink Provision"
set interfaces xe-0/1/1 description C_To:Site-B
set interfaces xe-0/1/1 vlan-tagging
set interfaces xe-0/1/1 unit 150 vlan-id 150
set interfaces xe-0/1/1 unit 150 family inet address 103.10.30.73/30
set interfaces xe-0/1/1 unit 150 family mpls
set interfaces xe-0/1/2 description "Provision for Site-3"
set interfaces xe-0/1/2 vlan-tagging
set interfaces xe-0/1/2 mtu 1600
set interfaces xe-0/1/2 unit 151 vlan-id 151
set interfaces xe-0/1/2 unit 151 family inet address 103.10.30.82/30
set interfaces xe-0/1/2 unit 151 family mpls
set interfaces xe-0/1/3 description "Provision for Client"
set interfaces xe-0/1/3 vlan-tagging
set interfaces xe-0/1/3 encapsulation vlan-vpls
set interfaces xe-0/1/3 unit 800 encapsulation vlan-vpls
set interfaces xe-0/1/3 unit 800 vlan-id 800
set interfaces xe-0/1/3 unit 800 family vpls
set interfaces xe-0/1/3 unit 1000 encapsulation vlan-vpls
set interfaces xe-0/1/3 unit 1000 vlan-id 1000
set interfaces xe-0/1/3 unit 1000 family vpls
set interfaces lo0 unit 0 family inet address 103.10.30.96/32
set routing-options router-id 103.10.30.96
set routing-options autonomous-system 65500
set routing-options forwarding-table export exp-to-fwd
set protocols rsvp interface all
set protocols rsvp interface xe-0/1/2.151
set protocols rsvp interface xe-0/1/1.150
set protocols mpls label-switched-path clientA-to-clientB to 103.10.30.97
set protocols mpls label-switched-path clientA-to-clientB primary path-AB
set protocols mpls label-switched-path siteA-siteC to 103.10.30.98
set protocols mpls label-switched-path siteA-siteC primary path-AC
set protocols mpls path path-AB 103.10.30.73
set protocols mpls path path-AB 103.10.30.97
set protocols mpls path path-AC 103.10.30.82
set protocols mpls path path-AC 103.10.30.98
set protocols mpls interface xe-0/1/1.150
set protocols mpls interface lo0.0
set protocols mpls interface xe-0/1/2.151
set protocols mpls interface all
set protocols bgp log-updown
set protocols bgp group Juniper-Mikrotik type internal
set protocols bgp group Juniper-Mikrotik local-address 103.10.30.96
set protocols bgp group Juniper-Mikrotik import match-all
set protocols bgp group Juniper-Mikrotik family l2vpn signaling
set protocols bgp group Juniper-Mikrotik neighbor 103.10.30.98
set protocols bgp group Juniper-Mikrotik neighbor 103.10.30.97
set protocols ospf traffic-engineering
set protocols ospf area 0.0.0.0 interface xe-0/1/1.150
set protocols ospf area 0.0.0.0 interface xe-0/1/2.151
set protocols ospf area 0.0.0.0 interface lo0.0 passive
set protocols ldp egress-policy connected-only
set protocols ldp interface xe-0/1/1.150
set protocols ldp interface xe-0/1/2.151
set protocols ldp interface lo0.0
set policy-options prefix-list loopback-prefix 103.10.30.96/32
set policy-options policy-statement connected-only from prefix-list loopback-prefix
set policy-options policy-statement connected-only then accept
set policy-options policy-statement exp-to-fwd term a from protocol bgp
set policy-options policy-statement exp-to-fwd term a from community grn-com
set policy-options policy-statement exp-to-fwd term a then install-nexthop lsp siteA-siteC
set policy-options policy-statement exp-to-fwd term a then install-nexthop lsp clientA-to-clientB
set policy-options policy-statement exp-to-fwd term a then accept
set policy-options policy-statement match-all term acceptable then accept
set policy-options community grn-com members target:65500:5000
set routing-instances Juniper-Mikrotik instance-type vpls
set routing-instances Juniper-Mikrotik interface xe-0/1/3.800
set routing-instances Juniper-Mikrotik route-distinguisher 103.10.30.96:5000
set routing-instances Juniper-Mikrotik vrf-target target:65500:5000
set routing-instances Juniper-Mikrotik vrf-target import target:65500:5000
set routing-instances Juniper-Mikrotik vrf-target export target:65500:5000
set routing-instances Juniper-Mikrotik protocols vpls no-tunnel-services
set routing-instances Juniper-Mikrotik protocols vpls site CLIENT-A site-identifier 96
set vlans vlan-800 vlan-id 800
set vlans vlan-150 vlan-id 150
set vlans vlan-151 vlan-id 151
------------SITE-B JUNIPER ---------------------
vianoc@SITE-B> show configuration | display set
set system host-name SITE-B
set interfaces xe-0/0/0 vlan-tagging
set interfaces xe-0/1/0 description C_To:Site-A
set interfaces xe-0/1/0 vlan-tagging
set interfaces xe-0/1/0 unit 150 vlan-id 150
set interfaces xe-0/1/0 unit 150 family inet address 103.10.30.74/30
set interfaces xe-0/1/0 unit 150 family mpls
set interfaces xe-0/1/1 description "Provision for SITE-C"
set interfaces xe-0/1/1 unit 152 vlan-id 152
set interfaces xe-0/1/1 unit 152 family inet address 103.10.30.77/30
set interfaces xe-0/1/1 unit 152 family mpls
set interfaces xe-0/1/2 description "C_To:Client RTR"
set interfaces xe-0/1/2 encapsulation vlan-vpls
set interfaces xe-0/1/2 unit 600 encapsulation vlan-vpls
set interfaces xe-0/1/2 unit 600 vlan-id 600
set interfaces xe-0/1/2 unit 600 family vpls
set interfaces xe-0/1/2 unit 800 encapsulation vlan-vpls
set interfaces xe-0/1/2 unit 800 vlan-id 800
set interfaces xe-0/1/2 unit 800 family vpls
set interfaces xe-0/1/2 unit 1000 encapsulation vlan-vpls
set interfaces xe-0/1/2 unit 1000 vlan-id 1000
set interfaces xe-0/1/2 unit 1000 family vpls
set interfaces lo0 unit 0 family inet address 103.10.30.97/32
set routing-options router-id 103.10.30.97
set protocols rsvp interface lo0.0
set protocols rsvp interface xe-0/1/0.150
set protocols mpls label-switched-path clientB-to-clientA to 103.10.30.96
set protocols mpls label-switched-path clientB-to-clientC to 103.10.30.98
set protocols mpls interface xe-0/1/0.150
set protocols mpls interface xe-0/1/1.151
set protocols bgp group Juniper-Mikrotik local-address 103.10.30.97
set protocols bgp group Juniper-Mikrotik neighbor 103.10.30.96
set protocols ospf area 0.0.0.0 interface xe-0/1/0.150
set protocols ospf area 0.0.0.0 interface xe-0/1/1.152
set protocols ldp interface xe-0/1/0.150
set protocols ldp interface xe-0/1/1.152
set policy-options policy-statement exp-to-fwd then install-nexthop lsp clientB-to-clientA
set policy-options policy-statement exp-to-fwd then install-nexthop lsp clientB-to-clientC
set policy-options policy-statement exp-to-fwd then accept
set routing-instances Juniper-Mikrotik interface xe-0/1/2.800
set routing-instances Juniper-Mikrotik route-distinguisher 103.10.30.97:5000
set routing-instances Juniper-Mikrotik protocols vpls site CLIENT-B site-identifier 97
-----------------------SITE-C MIKROTIK ----------------------
[admin@SITE-C] > export
# jan/12/1970 01:14:55 by RouterOS 6.40.4
# software id = 8315-513I
# model = CCR1072-1G-8S+
# serial number = 72730849B987
add name=Juniper-Mikrotik protocol-mode=none
add name=loopback protocol-mode=none
set [ find default-name=sfp-sfpplus1 ] comment="C_To:Site-A xe-0/1/2" l2mtu=1632
set [ find default-name=sfp-sfpplus2 ] comment="C_To:Site-B xe-0/1/1"
set [ find default-name=sfp-sfpplus3 ] arp=disabled comment="C_To:SITE-C-CLIENT; SFP-1" mtu=1514
/interface vlan
add interface=sfp-sfpplus1 name=vlan151 vlan-id=151
add interface=sfp-sfpplus2 name=vlan152 vlan-id=152
add interface=sfp-sfpplus3 name=vlan800 vlan-id=800
/mpls traffic-eng tunnel-path
add name=dyn
/interface traffic-eng
add disabled=no from-address=103.10.30.98 name=CtoA primary-path=dyn record-route=yes to-address=103.10.30.96
add disabled=no from-address=103.10.30.98 name=CtoB primary-path=dyn record-route=yes to-address=103.10.30.97
/routing bgp instance
set default as=65500 client-to-client-reflection=no router-id=103.10.30.98
/routing ospf instance
set [ find default=yes ] metric-other-ospf=20 mpls-te-area=backbone mpls-te-router-id=loopback redistribute-connected=as-type-1 redistribute-static=as-type-1 \
add bridge=Juniper-Mikrotik interface=vlan800
/interface vpls bgp-vpls
add bridge=Juniper-Mikrotik bridge-cost=0 bridge-horizon=1 export-route-targets=65500:5000 import-route-targets=65500:5000 name=Juniper-Mikrotik \
route-distinguisher=103.10.30.98:5000 site-id=98 use-control-word=no
add bridge=BGP-VPLS bridge-cost=0 bridge-horizon=1 export-route-targets=65500:1 import-route-targets=65500:1 name=Juniper-Mikrotik-BGP route-distinguisher=\
103.10.30.98:1 site-id=98 use-control-word=no
add address=192.168.9.4/24 interface=ether1 network=192.168.9.0
add address=103.10.30.81/30 interface=vlan151 network=103.10.30.80
add address=103.10.30.78/30 interface=vlan152 network=103.10.30.76
add address=103.10.30.98 interface=loopback network=103.10.30.98
add distance=1 dst-address=110.44.127.9/32 gateway=192.168.9.1
/lcd
set time-interval=hour
/lcd interface pages
set 0 interfaces=sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,sfp-sfpplus5,sfp-sfpplus6,sfp-sfpplus7,sfp-sfpplus8
/mpls
set propagate-ttl=no
/mpls interface
set [ find default=yes ] mpls-mtu=1526
add interface=vlan151
add interface=vlan152
/mpls ldp
set enabled=yes lsr-id=103.10.30.98 transport-address=103.10.30.98
/mpls ldp advertise-filter
add prefix=103.10.30.0/24
add advertise=no
/mpls ldp interface
add interface=loopback
/mpls traffic-eng interface
add bandwidth=100kbps interface=vlan151
add bandwidth=100kbps interface=vlan152
/routing bgp peer
add address-families=l2vpn name=Juniper-Mikrotik remote-address=103.10.30.96 remote-as=65500 ttl=default update-source=loopback
add address-families=l2vpn name=Juniper-Mikrotik remote-address=103.10.30.97 remote-as=65500 ttl=default update-source=loopback
/routing ospf interface
add passive=yes
add interface=vlan151 network-type=broadcast
add interface=vlan152 network-type=broadcast
add interface=loopback network-type=point-to-point
/routing ospf network
add area=backbone network=103.10.30.76/30
add area=backbone network=103.10.30.80/30
add area=backbone network=103.10.30.98/32
/system identity
set name=SITE-C
Vooray
Re: Juniper - Mikrotik LDP/BGP based VPLS
Wed Aug 15, 2018 9:05 pm
Tested both Martini and Kompella between Jun, cisco and Mikrotik some months ago and it worked fine.
There is a good book on subject :this week mpls from day one and good article on mikrotik wiki.
tejendragurung
Thu Aug 16, 2018 7:06 am
Dear Vooray,
Thanks for reply.
I would be thankful if u could provide the config script for Kompella and martini VPLS for juniper-mikrotik .
IPANetEngineer
Trainer
Trainer
Thu Aug 16, 2018 10:50 pm
Have you tired setting explicit null?
In the topology you have it looks like the PHP routers would be MikroTik and Juniper. We've seen issues before when the PHP routers are different vendors.
Global - MikroTik Support & Consulting - English | Español | Serbian | Danish +1 855-645-7684
https://iparchitechs.com/ecosystem/mikr ... consulting mikrotiksupport@iparchitechs.com
tejendragurung
Sun Aug 19, 2018 9:00 am
### Thanks for reply and suggestion .
I tried with enabling the explicit null on mikrotik and juniper for CE connected Node, but still Client could not ping eachother.
Also i can see the both routers could learn the MAC for each client and vice-versa .
What could be the issue ? as both routers learn the MAC .
MIKROTIK
/mpls ldp
set enabled=yes lsr-id=103.10.30.98 transport-address=103.10.30.98 use-explicit-null=yes
vianoc@SITE-A> show configuration protocols mpls
explicit-null;
JUNIPER
vianoc@SITE-A> show vpls mac-table instance Juniper-Mikrotik
MAC flags (S -static MAC, D -dynamic MAC, L -locally learned, C -Control MAC
O -OVSDB MAC, SE -Statistics enabled, NM -Non configured MAC, R -Remote PE MAC, P -Pinned MAC)
Routing instance : Juniper-Mikrotik
Bridging domain : __Juniper-Mikrotik__, VLAN : NA
MAC MAC Logical NH MAC active
address flags interface Index property source
00:12:c0:80:3f:74 D lsi.1048853
cc:2d:e0:1c:45:59 D lsi.1048858
cc:2d:e0:c2:55:a5 D lsi.1048858
e4:8d:8c:3c:26:be D xe-0/1/3.800
[admin@SITE-C] > interface bridge host print
Flags: L - local, E - external-fdb
BRIDGE MAC-ADDRESS ON-INTERFACE AGE
Juniper-Mikrotik 00:12:C0:80:3F:74 vpls12 24s
L Juniper-Mikrotik 02:8E:A0:2F:42:D7 vpls12 0s
L Juniper-Mikrotik 02:AD:10:95:07:8A vpls11 0s
Juniper-Mikrotik CC:2D:E0:1C:45:59 vlan800 7s
L Juniper-Mikrotik CC:2D:E0:C2:55:A5 vlan800 0s
Juniper-Mikrotik E4:8D:8C:3C:26:BE vpls11 30s
[admin@SITE-A-CLIENT] > interface ethernet print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP
0 R ;;; SITE-A Uplink xe-0/1/3
ether1 1500 00:12:C0:80:3F:74 enabled
[admin@SITE-C-CLIENT] > interface ethernet print
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
1 R ;;; C_To:SITE-C Uplink
sfp-sfpplus1 1500 CC:2D:E0:1C:45:59 enabled none
tejendragurung
Wed Sep 05, 2018 7:42 am
Dear Mikrotik Support team / Friends,
Please help to provide the solution for configuring the Juniper-Mikrotik LDP/BGP based VPLS .. I had send the below config for analysis .
tejendragurung
Thu Sep 13, 2018 2:06 pm
Dear Friends/Support team.
Currently i faced the issue: Can't ping the mpls ldp lsp from Juniper to Mikrotik Vice-versa, As from Juniper and Mikrotik we could learn the LSP for each path.
Please help to suggest .
[admin@SITE-C] /mpls ldp neighbor> print
Flags: X - disabled, D - dynamic, O - operational, T - sending-targeted-hello,
V - vpls
# TRANSPORT LOCAL-TRANSPORT PEER SEN
0 DO 103.10.30.97 103.10.30.98 103.10.30.97:0 no
1 DOTV 103.10.30.96 103.10.30.98 103.10.30.96:0 yes
[admin@SITE-C] /mpls ldp> interface print
# INTERFACE HELLO-INTERVAL HOLD-TIME
0 vlan151 5s 15s
1 vlan152 5s 15s
vianoc@SITE-A# run ping mpls ldp 103.10.30.97 detail
Request for seq 1, to interface 338, no label stack., packet size 80
Reply for seq 1, return code: Egress-ok, time: 8228334.309 ms
Local transmit time: 2018-09-13 16:14:41 UTC 722.479 ms
Remote receive time: 2018-09-13 18:31:50 UTC 56.788 ms
Request for seq 2, to interface 338, no label stack., packet size 80
Reply for seq 2, return code: Egress-ok, time: 8228333.140 ms
Local transmit time: 2018-09-13 16:14:42 UTC 721.995 ms
Remote receive time: 2018-09-13 18:31:51 UTC 55.135 ms
Request for seq 3, to interface 338, no label stack., packet size 80
Reply for seq 3, return code: Egress-ok, time: 8228333.439 ms
Local transmit time: 2018-09-13 16:14:43 UTC 728.908 ms
Remote receive time: 2018-09-13 18:31:52 UTC 62.347 ms
Request for seq 4, to interface 338, no label stack., packet size 80
Reply for seq 4, return code: Egress-ok, time: 8228333.153 ms
Local transmit time: 2018-09-13 16:14:44 UTC 721.443 ms
Remote receive time: 2018-09-13 18:31:53 UTC 54.596 ms
Request for seq 5, to interface 338, no label stack., packet size 80
Reply for seq 5, return code: Egress-ok, time: 8228333.506 ms
Local transmit time: 2018-09-13 16:14:45 UTC 720.444 ms
Remote receive time: 2018-09-13 18:31:54 UTC 53.950 ms
--- lsping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
[edit routing-instances LDPVPLS protocols vpls]
vianoc@SITE-A# run ping mpls ldp 103.10.30.98 detail
Request for seq 1, to interface 333, no label stack., packet size 80
Request for seq 2, to interface 333, no label stack., packet size 80
Request for seq 3, to interface 333, no label stack., packet size 80
Timeout for seq 1
Request for seq 4, to interface 333, no label stack., packet size 80
Timeout for seq 2
Request for seq 5, to interface 333, no label stack., packet size 80
Timeout for seq 3
Timeout for seq 4
Timeout for seq 5
5 packets transmitted, 0 packets received, 100% packet loss
vianoc@SITE-B# run ping mpls ldp 103.10.30.96 detail
Request for seq 1, to interface 346, no label stack., packet size 80
Reply for seq 1, return code: Egress-ok, time: -8228331.732 ms
Local transmit time: 2018-09-13 18:33:08 UTC 367.860 ms
Remote receive time: 2018-09-13 16:16:00 UTC 36.128 ms
Request for seq 2, to interface 346, no label stack., packet size 80
Reply for seq 2, return code: Egress-ok, time: -8228331.778 ms
Local transmit time: 2018-09-13 18:33:09 UTC 365.077 ms
Remote receive time: 2018-09-13 16:16:01 UTC 33.299 ms
Request for seq 3, to interface 346, no label stack., packet size 80
Reply for seq 3, return code: Egress-ok, time: -8228331.871 ms
Local transmit time: 2018-09-13 18:33:10 UTC 359.834 ms
Remote receive time: 2018-09-13 16:16:02 UTC 27.963 ms
Request for seq 4, to interface 346, no label stack., packet size 80
Reply for seq 4, return code: Egress-ok, time: -8228331.212 ms
Local transmit time: 2018-09-13 18:33:11 UTC 365.091 ms
Remote receive time: 2018-09-13 16:16:03 UTC 33.879 ms
Request for seq 5, to interface 346, no label stack., packet size 80
Reply for seq 5, return code: Egress-ok, time: -8228331.917 ms
Local transmit time: 2018-09-13 18:33:12 UTC 359.838 ms
Remote receive time: 2018-09-13 16:16:04 UTC 27.921 ms
vianoc@SITE-B# run ping mpls ldp 103.10.30.98 detail
Request for seq 1, to interface 335, no label stack., packet size 80
Request for seq 2, to interface 335, no label stack., packet size 80
Request for seq 3, to interface 335, no label stack., packet size 80
Timeout for seq 1
Request for seq 4, to interface 335, no label stack., packet size 80
Timeout for seq 2
Request for seq 5, to interface 335, no label stack., packet size 80
Timeout for seq 3
Timeout for seq 4
Timeout for seq 5
IPANetEngineer
Trainer
Trainer
Sat Sep 15, 2018 5:30 pm
Can you post the output of the MPLS forwarding tables for the Juniper and MIkroTIk routers?
tejendragurung
Tue Dec 04, 2018 1:02 pm
Currently we are not able to ping the point to point mikrotik clients and mikrotik to juniper clients.
tejendragurung
Tue Dec 04, 2018 1:07 pm
Please find the below outputs for Mikrotik and Juniper Routers:
#[admin@SITE-C-PE1] > interface vpls print
#Flags: X - disabled, R - running, D - dynamic, B - bgp-signaled, C - cisco-bgp-signaled
# 0 X name="junos-l2circuit" mtu=1500 mac-address=02:0E:E9:4B:06:65 arp=enabled arp-timeout=auto disable-running-check=no
# remote-peer=103.10.30.100 cisco-style=yes cisco-style-id=5 advertised-l2mtu=1526 pw-type=tagged-ethernet
# use-control-word=default
# 1 RDB name="vpls26" mtu=1500 l2mtu=1500 mac-address=02:04:4F:DA:07:3D arp=enabled arp-timeout=auto disable-running-check=no
# remote-peer=103.10.30.101 cisco-style=no cisco-style-id=0 advertised-l2mtu=1500 pw-type=raw-ethernet use-control-word=no
# vpls=BGP_VPLS
# 2 RDB name="vpls27" mtu=1500 l2mtu=1500 mac-address=02:18:E8:3B:D5:D8 arp=enabled arp-timeout=auto disable-running-check=no
# remote-peer=103.10.30.100 cisco-style=no cisco-style-id=0 advertised-l2mtu=1500 pw-type=raw-ethernet use-control-word=no
# vpls=BGP_VPLS
#[admin@SITE-C-PE1] > interface bridge host print
#Flags: L - local, E - external-fdb
# BRIDGE MAC-ADDRESS ON-INTERFACE AGE
#L vpn 02:04:4F:DA:07:3D vpls26 0s
#L vpn 02:18:E8:3B:D5:D8 vpls27 0s
# vpn 4C:5E:0C:14:3B:6F vpls27 27s
# vpn CC:2D:E0:1C:45:59 vlan-600 51s
#L vpn CC:2D:E0:C2:55:A5 vlan-600 0s
#vianoc@SITE-E-PE2> show vpls connections
#Layer-2 VPN connections:
#Legend for connection status (St)
#EI -- encapsulation invalid NC -- interface encapsulation not CCC/TCC/VPLS
#EM -- encapsulation mismatch WE -- interface and instance encaps not same
#VC-Dn -- Virtual circuit down NP -- interface hardware not present
#CM -- control-word mismatch -> -- only outbound connection is up
#CN -- circuit not provisioned <- -- only inbound connection is up
#OR -- out of range Up -- operational
#OL -- no outgoing label Dn -- down
#LD -- local site signaled down CF -- call admission control failure
#RD -- remote site signaled down SC -- local and remote site ID collision
#LN -- local site not designated LM -- local site ID not minimum designated
#RN -- remote site not designated RM -- remote site ID not minimum designated
#XX -- unknown connection status IL -- no incoming label
#MM -- MTU mismatch MI -- Mesh-Group ID not available
#BK -- Backup connection ST -- Standby connection
#PF -- Profile parse failure PB -- Profile busy
#RS -- remote site standby SN -- Static Neighbor
#LB -- Local site not best-site RB -- Remote site not best-site
#VM -- VLAN ID mismatch HS -- Hot-standby Connection
#Legend for interface status
#Up -- operational
#Dn -- down
#Instance: vpls1
#Edge protection: Not-Primary
# Local site: CLIENT-E (125)
# connection-site Type St Time last up # Up trans
# 41 rmt Up Dec 3 11:42:58 2018 1
# Remote PE: 103.10.30.98, Negotiated control-word: No
# Incoming label: 37240, Outgoing label: 3015
# Local interface: lsi.1051649, Status: Up, Encapsulation: VPLS
# Description: Intf - vpls vpls1 local site 125 remote site 41
# Flow Label Transmit: No, Flow Label Receive: No
# 42 rmt Up Dec 3 11:42:51 2018 1
# Remote PE: 103.10.30.101, Negotiated control-word: No
# Incoming label: 37241, Outgoing label: 61
# Local interface: lsi.1051648, Status: Up, Encapsulation: VPLS
# Description: Intf - vpls vpls1 local site 125 remote site 42
#vianoc@SITE-E-PE2> show vpls mac-table instance vpls1
#MAC flags (S -static MAC, D -dynamic MAC, L -locally learned, C -Control MAC
# O -OVSDB MAC, SE -Statistics enabled, NM -Non configured MAC, R -Remote PE MAC, P -Pinned MAC)
#Routing instance : vpls1
# Bridging domain : __vpls1__, VLAN : 600
# MAC MAC Logical NH MAC active
# address flags interface Index property source
# 02:04:4f:da:07:3d D lsi.1051649
# 02:ac:89:60:01:7b D lsi.1051648
# 4c:5e:0c:14:3b:6f D xe-0/1/2.600
# cc:2d:e0:1c:45:59 D lsi.1051649
#[admin@SITE-F-P] > interface vpls print
# 0 RDB name="vpls7" mtu=1500 l2mtu=1500 mac-address=02:AC:89:60:01:7B arp=enabled arp-timeout=auto disable-running-check=no
# vpls=BGP_VPLS
# 1 RDB name="vpls8" mtu=1500 l2mtu=1500 mac-address=02:C9:4C:C9:DE:A9 arp=enabled arp-timeout=auto disable-running-check=no
# remote-peer=103.10.30.98 cisco-style=no cisco-style-id=0 advertised-l2mtu=1500 pw-type=raw-ethernet use-control-word=no
# vpls=BGP_VPLS
#[admin@SITE-F-P] > interface bridge host print
# vpn 02:04:4F:DA:07:3D vpls8 5s
#L vpn 02:AC:89:60:01:7B vpls7 0s
#L vpn 02:C9:4C:C9:DE:A9 vpls8 0s
# vpn 4C:5E:0C:14:3B:6F vpls7 35s
#L vpn 4C:5E:0C:C9:13:19 vlan-600 0s
# vpn CC:2D:E0:1C:45:59 vpls8 59s
gbhawishaya
Wed Feb 26, 2020 10:05 am
Have tried configuring same scenario and issue is same. LDP is exchanging labels but unable to reach P2P between client A and and client B. Have you found any possible solution for this?
IPANetEngineer
Trainer
Trainer
Sat Mar 07, 2020 3:16 pm
I have not tried to replicate this exact issue, but I did publish an article a few months ago about Juniper to MIkroTik MPLS with VPNv4 which works well.
You can at least use it to verify MPLS between MikroTIk and Juniper.
https://stubarea51.net/2020/01/22/junip ... 4-interop/
Users browsing this forum: No registered users and 8 guests
