MUM Europe 2020
neutronlaser
Sharing Motel WiFi
Sun Aug 19, 2018 1:13 am
Is it possible to connect a MikroTik to a wifi hotspot with login (e.g. motel wifi), and the Mikrotik then make its own wifi network that multiple devices could use? Perhaps with double NATing?
BartoszP
Re: Sharing Motel WiFi
Sun Aug 19, 2018 1:28 am
Yes.
Use any dual band device. Use one WiFi interface as WAN and the second connect to LAN bridge.
Real admins use real keyboards.
neutronlaser
Sun Aug 19, 2018 1:32 am
Can it be done with a single band device? I understand it would be transmitting and receiving on the same channel.
axo
Sun Aug 19, 2018 8:51 pm
I used to do this with plain end home user APs, just set them up as AP client bridges, but if you want to make your own lan i would use a router with the separate channels as previously suggested.
Jotne
Mon Aug 20, 2018 8:06 am
No, you need two radios.
One that is connected to the Hotel WIFI, and one that you do connect to.
If you like to only use 2.4GHz, you need to boxes.
With one dual ban box, you can connect to Hotel Wifi using 2.4GHz and then the 5GHz to connect to your device.
So you can use 2 x hAP Mini (total cost 40USD)
Or one hAP ac lite (2.4 and 5GHz) ( total cost 49USD)
If you do not need to connect your device to wifi, you can connect to an ethernet port on a hAP Mini (total cost 20USD)
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
AlainCasault
Trainer
Trainer
Wed Aug 22, 2018 9:11 pm
Wrong, Wrong, wrong.
It CAN be done with a single radio.
Wlan1 is setup as a WiFi ( and dhcp) client. Then, create a vap that is an AP (with all regular configs).
I do this with a mAP or mAP lite, but all WiFi models will do it also. The mAPs are just very portable.
So yes, it can be done.
Sent from Tapatalk
___________________________
Alain Casault, Eng.
If I helped you, let me know!
Jotne
Wed Aug 22, 2018 9:27 pm
So with one radio you can setup two SSID. One that connects to the network, and one that you connects to?
Could you please post the config?
MikroTik->Splunk
AlainCasault
Trainer
Trainer
Wed Aug 22, 2018 10:02 pm
Most definitely.
I'm not in front of a router right now but look up VAP ( virtual access point) if you're in a hurry.
Real easy once you know (like everything else in life :D ).
I suggest you configure wlan1 as a client first since you'll know right away if you have hotspot connectivity.
The rest is vap. I'll try to post a config asap.
Cheers,
Sent from Tapatalk
Alain Casault, Eng.
neutronlaser
Wed Aug 22, 2018 11:13 pm
AlainCasault, do you know how to make the VAP match the channel of the access point it is connecting to, automatically?
mkx
Wed Aug 22, 2018 11:50 pm
When you configure VAP, there's setting which binds VAP to "master" AP (master-interface=wifi1). VAP essentially inherits "master" AP physical settings (frequency, band, channel width, ...), other settings (such as SSID, security profile, mode of operation, even MAC address) are its own. This means that "master" AP can be set as "station" while VAP can be "ap bridge" ... which is what OP wants to have.
BR,
Metod
AlainCasault
Trainer
Trainer
Thu Aug 23, 2018 9:00 pm
@Jotne
Here's my (partial) config as requested.
/interface wireless
###BASIC WLAN1 SETUP. BOGUS SECURITY PROFILE TO PREVENT ROUTER FROM CONNECTING TO ANY "OPEN" WI-FI. NOTE ALSO EMPTY SSID.
set [ find default-name=wlan1 ] antenna-gain=1 band=2ghz-onlyn country=canada \
    default-forwarding=no disabled=no distance=indoors frequency=auto \
    frequency-mode=regulatory-domain radio-name=mAP-Alain security-profile=\
    Bidon ssid="" wireless-protocol=802.11
###VAP HERE. VAP BROADCASTS HOME SSID WITH SAME SECURITY PROFILE. WE DON'T HAVE TO RECONFIGURE OUR DEVICES WHILE ON THE ROAD.
add disabled=no keepalive-frames=disabled mac-address=4E:5E:0C:6C:64:0C \
    master-interface=wlan1 multicast-buffering=disabled name=[b]wlan2 [/b]\
    security-profile=MAISON ssid=DSWLAN wds-cost-range=0 wds-default-cost=0 \
    wps-mode=disabled
###CONNECT LISTS TO SPECIFY SSIDs TO CONNECT AND SECURITY PROFILES TO USE
/interface wireless connect-list
add comment="Park Lane Inn & Suites" interface=wlan1 security-profile=default ssid=Park_Lane_Guest_WiFi wireless-protocol=802.11
add comment="Country Inn Lexington VA" interface=wlan1 security-profile=default ssid=country wireless-protocol=802.11
add comment="Grand Times Hotel" interface=wlan1 security-profile=times ssid=Times wireless-protocol=802.11
ETC.
###VAP AND ONE ETHERNET ARE ON LAN BRIDGE. PRETTY STANDARD SETUP FROM THERE
add admin-mac=4C:5E:0C:6C:64:0B auto-mac=no name=LAN
add bridge=LAN interface=ether2
add bridge=LAN interface=wlan2
add address=192.168.255.1/24 comment=LAN interface=LAN network=192.168.255.0
/ip dhcp-client
add comment="default configuration" default-route-distance=5 dhcp-options= hostname,clientid disabled=no interface=wlan1
add comment="default configuration" default-route-distance=5 dhcp-options=hostname,clientid disabled=no interface=ether1
add name=pool-LAN ranges=192.168.255.10-192.168.255.254
add address-pool=pool-LAN disabled=no interface=LAN name=dhcp-LAN
add address=192.168.255.0/24 comment=LAN dns-server=192.168.255.1 gateway=192.168.255.1
FIREWAL FILTERS, NAT, ROUTING AND OTHER PARAMETERS OMITTED FOR SIMPLICITY'S SAKE
With this setup, I can now connect all my devices as if I was at home from any hotel, Starbucks or McDonald's. I also benefit from a firewall as I don't trust public hotspots. I also configured L2TP/IPSec to home so that I can manage my home network while I'm away.
Hope this helps.
Cheers!
Alain Casault, Eng.
Jotne
Thu Aug 23, 2018 10:22 pm
Thanks. I will test it out.
All time I am connected to a public WIFI, I always user L2TP/IPSEC to my MT at home. Do not trust any open site. :)
How do I setup the security profile?
security-profile=Bidon
MikroTik->Splunk
AlainCasault
Trainer
Trainer
Fri Aug 24, 2018 3:50 pm
Same as you would for any non-VAP setup. That's the beauty of it, it seems hard, but it's not :)
Wireless --> Security profile
Alain Casault, Eng.
Users browsing this forum: No registered users and 17 guests
