Equis
Forum Veteran
Forum Veteran
GRE Tunnel
Mon Feb 12, 2007 6:35 am
Hello
I have been asked to setup a GRE tunnel.
Is this L2tp, or PPTP or none of the above?
ashish
Long time Member
Long time Member
Mon Feb 12, 2007 6:39 am
What is exact Requirement..??
- AP - ASHISH PATEL - 757 309 0236 -
Equis
Forum Veteran
Forum Veteran
Mon Feb 12, 2007 6:45 am
To create a tunnel to their BGP router
Thay have asked if my router supports GRE
ashish
Long time Member
Long time Member
Mon Feb 12, 2007 6:52 am
I Think u can't Via PPTp and L2TP...I am NOT Sure
Ashish.
sergejs
Mon Feb 12, 2007 8:00 am
RouterOS does not have GRE tunnel, IPIP might be used to create unencrypted tunnel between RouterOS and Cisco.
(PPTP uses GRE to form the actual tunnel)
fatonk
Mon Feb 12, 2007 10:37 am
Right, RouterOS does support only IPIP tunnel, but Cisco supports both GRE and IPIP tunnels. So, if you need to create an unencrypted tunnel between RouterOS and any other OS use IPIP tunnel.
Regards.
Faton
Users browsing this forum: andriys, Frost93 and 139 guests
