uncleVALERA
Re: RB4011
Thu Dec 13, 2018 3:25 pm
I have instaled SFP module S-53LC20D in SFP+ port of the router. The port has the following settings:
Where is issue?
What's the cable length between those SingleMode transceivers? Rough estimate works. 500m? 1km? 2km? 5km? 10km? 15? 20km?
I'm pretty sure we're looking at a dampening issue here.
I think it is between 2-5 km
But i forgot notice that transceiver work as normal in a switch CSS106-5G-1S from my side. So the link has not issues.
psannz
Re: RB4011
Thu Dec 13, 2018 6:32 pm
Weird... maybe try a 2 dB damper anyways? Then again, pretty sure you already tried that.
Then again, I try to avoid SFP Modules in SFP+ slots. Always likely to cause issues, even when "supported".
Could you try a pair of S+2332LC10D?
nereith
Re: RB4011
Sat Dec 15, 2018 6:54 am
Just got the wireless version of the RB4011 with 10Gtek Copper SFP 1G for UBNT.
I initially encountered flapping when the SFP+ port was configured as LAN with autonegotiation enabled and connected to the laptop. The issue was resolved by disabling the port's autonegotiation and setting the speed to 1G, even though autonegotiation was still enabled on the laptop.
With that change on the RB4011, I've not seen flapping when the port is configured as WAN and connected to Arris SBG6580 or Linksys E4200 even though autonegotiation is enabled on the Arris/Linksys.
anschluss
Re: RB4011
Sun Dec 16, 2018 4:05 pm
https://wiki.mikrotik.com/wiki/MikroTik ... ansceivers
[..] settings are needed to be set on both linked devices for required interfaces
Disable auto negotiation on both ends of link and the flapping will stop (tested and confirmed S-53LC20D @ RB4011)
Same goes for me - I could only get the link to work with an SFP module after asking the provider to turn off autonegotiation on their end as well.
Can this issue be avoided in a future RouterOS update or is it due to a hardware limitation?
codruts
Re: RB4011
Sun Dec 16, 2018 10:09 pm
so - is the 160mhz channels option working?
just tested with a killer 1550 client, intel-based, capable of 160mhz, no success
doesn't matter which client i'm using, ap isn't available anymore, until is set back to 20/40/80.
offtopic a bit - could someone point me to a topic discussing LACP? i haven't succeeded to obtain more than 1gbps ... one of lacp members stays relaxed, doing nothing :)
also, wins server / master browser? thanks in advance!
uncleVALERA
Re: RB4011
Mon Dec 17, 2018 11:03 am
You could try different Transmit Hash Policy
codruts
Re: RB4011
Mon Dec 17, 2018 11:07 am
tested layer 2 and layer2+layer3, same result.
mkx
Re: RB4011
Mon Dec 17, 2018 1:53 pm
There's no hashing algorithm that would allow all bonded interfaces to be used by a single connection (e.g. single TCP or UDP stream running, say, iperf). However, different hashing algorithms mean different probability that two connections will use distinct bond members. The only standard hash algorithm that makes probable use of distinct bond members for connections between same server and client (i.e. multi-stream iperf test) is layer-3-and-4.
BR,
Metod
codruts
Re: RB4011
Tue Dec 18, 2018 12:28 pm
so which will be the appropriate choice in case of smb (i'll say smbv3 with multichannel enabled by default)?
on the other hand, not every client [i.e. NAS] will accept layer-3-and-4
mkx
Re: RB4011
Tue Dec 18, 2018 5:58 pm
The highest layer acceptable for both sides. You might want to experiment with settings not being the same on both sides. After all, receiver will probably accept whatever arrives at any bond interfaces, most of the time all of them use same MAC address. The hash algorithm is important when transmiting to spread utilization of all interfaces as evenly as possible.
The high-level protocol doesn't matter. If smbv3 uses different tcp ports on either side (server or client), then layer4 hashing algorithm will distribute separate streams for single client evenly across interfaces while l3 or l2 will not..
BR,
Metod
WebLuke
Re: RB4011
Tue Dec 18, 2018 11:05 pm
So far the RB4011iGS+RM has been a great replacement for routing from my CRS125-24G-1S-2HnD-IN, I still us the CRS125 as a switch, but wireless is disabled since I use a wAP AC in the middle of my house. I did notice that the RB4011 gets warm even when its not doing anything, I had mine plugged in but not configured and was warm. So far my speedtests are consistently my max speeds. CPU has no problem with my big block lists every 12 hours only tipping the CPU up 5%. I did get a 10Gtek SFP fiber module (https://amzn.to/2BxD0RE) for both devices as an interlink, on the CRS125 it just worked with no additional configuration, on the RB4011 I was getting the disconnection problems others have mentioned, but I just set the SFP+ port to 1G Full Duplex and have no problems after setting that.
The LCD screen was cool on other devices but I never look at it, and USB I don't have a use for, it would be nice if it was able to connect a printer or hard drive as a network shared devices, but I never worried for at home to have backup cell access. I would recommend this as an update for home or small offices for sure. If I didn't have a CCR1009-7G-1C-1S+ at work from the guys who run the WISP who couldn't use it, than I would get one for our small office.
Also the easiest way I found to get one of these was from a dealer through Amazon (https://amzn.to/2UWuXae)
bumbak
Re: RB4011
Thu Dec 20, 2018 3:54 am
So I also have issue with SFP not working in SFP+ port... it was working fine in rb2011 but no luck with rb4011... Im using it to connect to computer that has pcie sfp card in it with mikrotik sfps on both ends... tried turning auto neg. off on both sides but no luck... whatever option I try rb4011 always says its connected but on computer side network card is flaping on/off constantly... damn it mikrotik cant you fix this
edit: on computer side I have Planet gigabit card PLT-ENW-9701 with Mikrotik S-85DLC05D in it, and same Mikrotik SFP modul in RB4011... cant get it to work, and it worked perfectly with RB2011...
thomasnet
Re: RB4011
Thu Dec 20, 2018 10:10 pm
Also got the exact same problem. I unfortunately can't turn off autoneg on my provider's side, so I hope a software-side fix is possible. I received my router a few days ago so it still is under warranty, maybe I could contact support about a potential fix?
ppptran
Re: RB4011
Sun Jan 06, 2019 3:24 pm
Gezz, this flapping issue is getting anyyoying as hek.
I have this same issue and i've spent lot of hours into research , it came up " disable autonegotiation on both end" on every topic. Are you kidding me, i dont have access on that part. ISP stuff work everywhere but Mikrotik.
Im using RB4011.
Moving on to EdgeRouter.
lapsio
Long time Member
Long time Member
Re: RB4011
Mon Jan 07, 2019 9:05 am
Im using RB4011.
CCR1009 works. You just cheaped out xP
RB4011 is bag of disappointment, wasted chances and unfortunate decisions... It's significantly less versatile than average MikroTik
MTCNA, MTCRE, MTCINE
mark2015
Re: RB4011
Mon Jan 07, 2019 2:00 pm
I'm having the exact same issue I have 2 Mikrotik devices. I was upgrading one device RB2011UiAS-2HnD-IN to the RB4011iGS+5HacQ2HnD-IN, and my SFP device ( S-85DLC05D ) can't keep the link/interface up as it does on the original routerboard. It's interfacing with another RB2011UiAS-2HnD-IN with another S-85DLC05D.
Has anyone found a workaround yet?
normis
Re: RB4011
Mon Jan 07, 2019 2:17 pm
Note: The RB4011 does not support Passive DAC modules, 1GB copper SFP modules and SFP GPON modules.
mark2015
Re: RB4011
Mon Jan 07, 2019 2:45 pm
So after reading a bit more through the forum, I was able to get it to stay stable by turning autonegation off and 1G FD... however, I had to set the same setting on the other Mikrotik router also (ie the RB2011UiAS-2HnD-IN #2).
mcskiller
Re: RB4011
Tue Jan 08, 2019 8:41 pm
Today I received my new rb4011 with wifi. Apart from the previously mentioned subjects (usb and lcd) it does not have a beeper either
Enviado desde mi SM-G9600 mediante Tapatalk
yHuKyM
Re: RB4011
Wed Jan 09, 2019 9:44 am
And user LED :(
pe1chl
Re: RB4011
Wed Jan 09, 2019 12:23 pm
But it *does* have the signature MikroTik built-in torch light!
Paternot
Forum Veteran
Forum Veteran
Re: RB4011
Wed Jan 09, 2019 12:39 pm
I'm all for bright leds - sometimes they are a life saver. But it would be great if we got these torches with a "mute" option. Something like "/system leds all dim|bright". THAT would be great. :D
pe1chl
Re: RB4011
Wed Jan 09, 2019 2:07 pm
I use a piece of back tape for that... but it looks ugly.
When you walk in a datacenter you immediately notice where is the MikroTik equipment.... and probably that is the reason for it.
igorpec
Re: RB4011
Sun Jan 13, 2019 11:19 am
I just switch from RB2011 to RB4011 and I do experience some weird things. First is known -> sfp module which I can bring to live by disabling auto negotiation and by repeated switching between 10G and 1G mode. Then at one point it starts to work and it works until the next reboot. Sometimes it connects at 10 sometimes at 1. At least it says so in the logs. Can't prove whether this is true.
Wireless works okeish, but the biggest problem (beside damn sfp) is that it happens all the time that internet connection stalls for a while (wire or wireless), there is nothing in the logs and when I do check speed tests its maxed out. My configuration, which is not that complex, worked flawlessly for years on RB2011 except the box become a bit slow on wireless and could not digest upgraded WAN speeds any more.
The question is: is this occasionally stall happening to you as well? On first glimpse it looked like DNS is not resolving, but I guess the problem is more sinister?
mcskiller
Re: RB4011
Mon Jan 14, 2019 6:42 pm
Does anyone have this problem?
the 5g interface does not show the current tx power table
this are the settings:
skylark
Re: RB4011
Thu Jan 17, 2019 10:41 am
The problem persist with disabled auto negotiation, even between two RB4011 devices.
Issue reproduced between 2x RB4011, will be fixed in upcoming beta versions.
I do not want to promise it, but we will look forward to add 1Gbps transceiver support with
auto-negotiation=on
on both sides. Generally in RouterOS it is necessary to force 1Gbps mode on SFP+(10G) interfaces.
saper2
Re: RB4011
Thu Jan 17, 2019 10:54 am
auto-negotiation=on
Hi, if you manage to make it works this would be terrific Image, not only for 4011 but others RB/CRS/CCRs with 10G SFP+ too.
This might be solution for MediaConverters based on Qualcomm chip who don't want to work with SFP(1G) module when it's plugged in SFP+ cage :( .
Sent from my VTR-L29 using Tapatalk
lapsio
Long time Member
Long time Member
Re: RB4011
Thu Jan 17, 2019 2:23 pm
auto-negotiation=on
It's actually really interesting because this particular 1G module:
https://www.fs.com/de-en/products/29838.html
Works for me with autoneg on in CRS317. So what is deciding factor that makes 1G module work or not? (it's worth to mention that their copper modules don't, so it really is just this particular one that actually works).
And to prove my point here's photo:
I also tested this: https://www.fs.com/de-en/products/16271.html and it works as well. Connecting CRS to non-Mikrotik gear was also successful. Unfortunately I tried their LX modules and it doesn't seem to work (without autoneg off). That said I don't have 2 LX modules made by them so I tried to connect regular 10km LX to SX 1310nm combo MM/SM 2km. Maybe only one of them doesn't work with autoneg on.
So if you need LX modules and want to bite a bullet (not that 14$ sounds like kidney tbh) then I guess you can try it. If you need SX then go on. Here's how it works on CRS. I don't have RB4011 to test tho. This topic intrigued me so much that I'll probably buy another LX and another SX/LX 1310nm combo just to see whether it works. But I need to wait for salary so not this month as I'm broke ._.
I knew it's unusual from very beginning that they worked with autoneg on, so I even asked FS.COM support what's their sorcery but they didn't reveal it xD. Maybe @mikrotik you could ask them how it works to implement such thing in your official SX/LX modules? Or just simply OEM from them lul.
Etz
Re: RB4011
Thu Jan 17, 2019 11:35 pm
By the spec sheet:
DC jack input Voltage 12-57 V
Max power consumption 33 W
Now wondering, when powered on 12V how much Amps should PSU provide?
Spec sheet does not say anything on which voltage that 33W is consumed.
Does anyone has any idea?
pe1chl
Re: RB4011
Thu Jan 17, 2019 11:50 pm
P = U * I (Watts = Voltage * Current)
So when you have 12V at 33W the current is 33/12 = 2.75A.
When you are running it at 24V, current is 33/24 = 1.375A.
(those are probably "maximum" values, not what it will draw all the time)
Why is the current becoming less when the voltage increases? Isn't the current increasing due to Ohms law? (U = I * R)
No, because equipment like this contains a switch-mode regulator, that actually converts power from the input voltage
into the desired output voltage that internally operates the electronics (e.g. 5V or 3.3V). So when the voltage drops,
the current increases to maintain the same power.
marcin21
Re: RB4011
Thu Jan 17, 2019 11:52 pm
"router rebooted because some critical program crashed"
RB4011 doing NAT ~500mbps, cpu 20-30%
reboots every few days. Routeros 6.43.4
What this critical program issue means?
What could be solution ?
Quindor
Re: RB4011
Fri Jan 18, 2019 1:05 am
Try and update to latest stable first, if the problem then still occurs, open a support ticket and run a support out file so they can diagnose the problem. :)
http://www.campzone.nl World's Largest Outdoor LANParty, http://intermit.tech Intermittend Technology blog, My blog about the ESP8266, IP Camera's and other tech related subjects!
Etz
Re: RB4011
Fri Jan 18, 2019 12:44 pm
I know the Ohm's law, just forgot about the Watt to Amp relationship...and switching power supplies related stuff... :D
Actually, my general plan is to use single power source for three devices, all of these can handle 12V input, so...it is simply question about the Amperage.
Seems like 12V 5A powerbrick, wired into UPS is plenty.
d4rkblue
Re: RB4011
Mon Jan 21, 2019 4:34 am
My RB4011 wlan1 disabling itself.
RouterOS version 6.43.8
Is this a software issue or a hardware issue?
dobeerman
Re: RB4011
Mon Jan 21, 2019 3:05 pm
It's a SW issue.
Save config "exp file=current.cfg.rsc", copy to computer
Try flashing 6.43.8 from NetInstall.
Load config "imp file=current.cfg.rsc"
I had the same problem with ether1-ether5 ports: after a few time, ports disabling itself.
lipo
Re: RB4011
Thu Jan 31, 2019 12:09 am
hi..ive got RB4011iGS+5Ha... for 3 weeks and about 2 days ago i figured out that 5GHz wifi "start disapearing" after about 1 day in wifi interfaces i can see its in "running ap" status but i cant scan it on another devices (2phones/1ntb) when i try to disable and enable it again it will never get to "running ap" status agan it stucks in "initializing" phase.. i have to reboot whole RB to get it working again..
problem occurs on ROS 6.43.8(firmware version matching ROS) and 6.44beta61(firmware version matching ROS)
previously ive got CRS125-24G-1S-2HnD i was able to achive uptimes >200days (rebooting mostly due to SW/FW upgrades..)
quite annoying.. anyone else having these problems? any way to solve it? or RMA? thanks for sugestions..
//edit: fixed image link
lebiecki
Re: RB4011
Sun Feb 03, 2019 12:09 pm
I'm having exactly the same issue on my 4011.
2.4GHz WIFI works, but 5GHz wifi disappears every 1-3 days. Interface is up but other clients cannot detect the AP. I need to completely reboot the device to get it back online.
I've opened support case with Mikrotik but so far no luck.
skylark
Re: RB4011
Mon Feb 04, 2019 8:53 am
We are trying to reproduce your mentioned 5ghz wireless issue, currently everything works for us as expected. We will appreciate information which could help us to reproduce the issue, maybe someone can provide us step by step guide how to trigger this glitch?
badconduct
Re: RB4011
Mon Feb 11, 2019 3:55 am
Hello, I just want to report I am having this same issue as well. The 5ghz is dropping frequently. I enabled the logging to echo but didn't see anything of value, the interface just stays in "initializing".
I have been playing with the settings over the week, I was not getting the expected throughput (100Mbps up and down, eventually got it too ~190 down; ~400 up). The ISP provided router was closer to 300 down, 400 up (using the speed test app on my phone); the WAN connection is 1Gbps. I set the Channel Width to 20/40/80mMHz XXXX, frequency to auto, Country to Canada, installation to indoor; Distance to Indoor; disabled WPS; WDS is disable; I tried fixed tx power rates at 17 at well.
a575606
Re: RB4011
Wed Feb 27, 2019 9:25 pm
Hi everyone! I'm new to the forum and to Mikrotik. Just got my RB4011 a few days ago and got the basic configuration complete, and was happy to replace my old tp-link router once and for all. I am certainly no network engineer, but I was finding myself frustrated with consumer network products. A friend of mine runs a wifi internet provider and swears by Mikrotik and recommended them. I also looked at Ubiquiti, but the RB4011 ticked the most boxes for me. RouterOS will take some time to learn, but on the whole it seems really well built and expandable, and I'm really happy with the product so far.
The only thing I was underwhelmed with was the wifi. I was hoping to be impressed, but actually it's been a downgrade from my midrange pre-MIMO tp-link ac router. It has generally seemed a bit slower to connect, range is about the same if not a bit less. Speed is ok, but sometimes it seems like it hangs for a while. I'm on fibre internet, so it's unusual. Also it seems to either drop occasionally or restart a bit more than I'd expect when I touch anything in config. I can't always tell if a page is just loading slow or if it's a router issue, it just generally feels a bit less stable and less solid than I'm used to.
The only thing I can find in the log when the wifi drops and restarts is the error msg below. The strange thing is the admin user is disabled and I'm logged in using a new custom user with admin privileges. It always points to my lan ip, so it's not like I'm being hacked... At first I thought I have a setting wrong, or that a browser plugin was interfering. But I switched to winbox and notice it happened again. So, since I came across this thread, I thought I'd ask to see if that sounds similar to what you guys are seeing, so I don't start tweaking all kinds of settings for nothing.
Thanks for the help.
Time Feb/27/2019 00:00:00
Buffer memory
Topics
system
error
critical
Message login failure for user admin from <<ip>> via web
michael1234
Re: RB4011
Thu Feb 28, 2019 8:11 pm
Hi, i have a problem with my mikrotik 4011
when ethernet cable plug-in in port eth2 or eth7 green leds are not blinking, but connection is working.
If plug-in cable in other ports then i can see the green led
in connection i use the same cable.
anyone know what is it ??
when routers loaded all 10 leds are blinking
CTSsean
Re: RB4011
Fri Mar 01, 2019 12:45 am
To those having bad 5Ghz problems, do not choose auto. It may be that MikroTik is choosing a dFS channel and not all modern devices support DFS channels properly.
a575606
Re: RB4011
Sat Mar 02, 2019 8:25 pm
Thanks for the tip. I found the same out on my own, and things were working better for a while, but today the 5g started acting up again. The router says it's enabled, but it doesn't show up in my list of wifi networks on android. Have you found any other tweaks that work?
dnc74
Re: RB4011
Wed Mar 06, 2019 1:16 pm
I don't believe I did anything to trigger this, other than disconnect leaving nothing connected to the AP. The next time I went to use it, hours later, the AP was gone.
I also was using a virtual AP when I first got this.
lipo
Re: RB4011
Tue Mar 19, 2019 11:25 pm
not using any virtual APs on 5GHz an still have issues.. but its very random right now 8days uptime without problem..
kos
Re: RB4011
Wed May 15, 2019 3:18 pm
Has anyone notice one and the same mac address on sfp+ and wlan1 interfaces???
Just after upgrade and reset-config:
mcskiller
Re: RB4011
Wed May 15, 2019 8:15 pm
Same problem here..
Pericynthion
Re: RB4011
Wed May 15, 2019 9:29 pm
Anyone managed to try the new S+RJ10 with the 4011 yet? (the /r2 hardware revision)
FurfangosFrigyes
Re: RB4011
Thu May 16, 2019 8:39 pm
Yes, i am using S+RJ10 modules between RB4011 and CRS328.
lapsio
Long time Member
Long time Member
Re: RB4011
Thu May 16, 2019 8:52 pm
Ouch. Any particular reason to go with such setup? Existing, long cabling? 10G-SR modules cost like 16$ plus few bucks for LC optical patchcords comparing to 65$ for S+RJ10. 10G copper seems to be insanely expensiive. Especially non-mikrotik modules which go for like 150$.
FurfangosFrigyes
Re: RB4011
Thu May 16, 2019 9:01 pm
I can not use fiber because of my existing cables. The only one problem with RB4011 is the high working temperature of the SFP+ module.
lapsio
Long time Member
Long time Member
Re: RB4011
Thu May 16, 2019 9:04 pm
So I assume you use longer copper cables if replacement would be problematic? What cable length do you use? I was always interested in actual maximum cable length for 10G copper modules. Because declared 30m sounds like rather "better safe than sorry" requirement. Not real limit where transfare rates start to significantly struggle.
FurfangosFrigyes
Re: RB4011
Fri May 17, 2019 7:40 am
It is less than 10 meters CAT5E without shild.
lapsio
Long time Member
Long time Member
Re: RB4011
Fri May 17, 2019 11:00 pm
oh. Well...
10G SR module 15$ x2 : https://www.fs.com/de-en/products/74668.html
10m OM2 LC-LC patchcord 5$ : https://www.fs.com/de-en/products/74394.html
total 35$ (or 42$ incl. VAT)
S+RJ10 65$ x2
cat5 cable 0$
total 130$
actually even using original MikroTik SR modules (60$) it still saves around 5$ xD
Mostly because S+RJ10 is really cheap comparing to other 10G copper modules. With "normal" copper modules for like 150$ optics are ridiculously cheaper, more than 10x cheaper.
That's why I was a bit surprised a bit.
FurfangosFrigyes
Re: RB4011
Sat May 18, 2019 8:16 am
I agree with you! But my tubes in the wall are full and it was a quick and dirty solution :-) If i will have to interconnect my equipments in the rack than the optic modules will be the solution.
dannym
Re: RB4011; 802.11ax
Tue Sep 17, 2019 7:35 am
The 802.11ax standart is knocking on the door.
So Im wondering if its possible to replace the existing rb4011igs+5hacq2hnd-in mpcie card with a newer 802.11ax generation when its available ?
Will it be possible such a feature to be implemented in a near future ?
TimurA
Tue Sep 17, 2019 8:20 am
The 802.11ax is knocking on the door.
Most likely not. Waiting for a new device. I hope it will work immediately without any problems.
dannym
Re: RB4011
Tue Sep 17, 2019 1:24 pm
Thank you !
I bought this router 2 months ago because I prefer that kind of hardware - all in one. I don't want to use router, switch and AP as separate devices.
Most of users like me use this unit for domestic needs .so we prefer to be all in one device.
I waited so long to buy this router because now ROS is much better than before especially in terms of 802.11ac performance. and SFP usage
So I dont want to spend another 2-3 years waiting new device to come (RB 5011 may be .. )
Sob
Re: RB4011
Tue Sep 17, 2019 2:02 pm
I don't see why mPCIe card wouldn't be replaceable, as long as the new one will be supported by RouterOS. You can't just buy first card you see, because RouterOS definitely doesn't support all chipsets, but once some mPCIe ax card from MikroTik comes out, it must work.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
dannym
Re: RB4011
Tue Sep 17, 2019 2:09 pm
Thanks Sob
Yep I mean card from Mikrotik for sure.
That would be very useful despite of this that would run only at 2.4Ghz spectrum because of the antenna .
Jensen567
Re: RB4011
Fri Sep 20, 2019 6:54 pm
Also interested in the flexibility of that m-PCIe slot. If I got the wireless version, could I pull the existing card and put in the R11e-LTE to have an internal LTE modem? Antennas would need to be added but that is fine.
saper2
Re: RB4011
Sat Sep 21, 2019 6:10 pm
If there is a Sim card slot on board then you should be able to insert gsm modem card.
enkoopa
Re: RB4011
Wed Sep 25, 2019 4:16 pm
Would support for GPON ever change (firmware) or is this a hardware issue? If we want GPON should we stick to RB3011?
Mett
Re: RB4011
Mon Sep 30, 2019 4:48 pm
+1
What is the reason for this limitation?
forum.mikrotik@honig.do0.de
saper2
Re: RB4011
Mon Sep 30, 2019 6:54 pm
Natively rb4011 don't support 1G in sfp+ but there are modules that do work when the sfp+ is hard-configured to 1G (1.25). Check topic Usage GPON module SFP in Spain there is one or 2 person's who confirmed that some GPON stick do work (those directly from Chinese manufacturers in which you can change sn/password/etc...).
JeanPierre
Re: RB4011
Tue Oct 01, 2019 7:12 pm
some GPON units work, some don't. it seems to me like QA issue.
nfored
Re: RB4011
Thu Oct 03, 2019 12:44 am
Can anyone tell me what I might expect routing between 10 subnets using just the sfp+ connected to CCS326 might give me? Currently, I have a FortiGate 200b as my Firewall/router and it will remain the firewall to the internet, but when I am running test on some of my esx hosts that are 10G capable its maxing my CPU on my FortiGate. The fortage currently has 22 inter VLAN rules to allow traffic to pass there rules are mostly whole subnet to whole subnet on one port. Some rules are a few ips to a few ips, seems pretty simple.
I don't expect 10gbps and I don't need it, would be nice for the testing but I am realistic person its a 190.00 router. I just want to be able to run my test and not take down my network. If you say I need to save my pennies maybe I just need the 1009.
-Fred
lapsio
Long time Member
Long time Member
Re: RB4011
Thu Oct 03, 2019 4:31 am
-Fred
Depending on load characteristics RB4011 will outperform CCR1009. It will easily pull off 10G, just like CCR1009 (providing you use fasttrack in firewall, otherwise not rly but CCR1009 won't either). RB4011 will be better at handling fewer high throughput connections while CCR1009 will be better at handling thousands of smaller connections saturating 10G interconnect. It makes RB4011 great router if you're streaming or routing storage, hosting big files etc. - scenarios where CCR1009 sometimes struggles to hit 10G. Those devices are similar in overal performance - they're just optimized for different load characteristics.
TL;DR RB4011 is really capable router and my friend uses it for 10G inter VLAN routing with CRS317. It pulls off 10G without a sweat in most scenarios (except large scale with thousands of tiny connections).
Imho as of now RB4011 is no brainer unless you need some specific CCR features like smart card, additional SFP interface, usb, microSD, higher throughput for gigabit interfaces (because RB4011 has 5G aggegated bandwidth to gigabit interfaces - 2.5G per switch, while CCR1009 8G aggregated for 8 interfaces - no switch chip). And I'm saying that as CCR1009 owner. I just keep lying to myself that I totally need this touchscreen LCD so I don't feel like I wasted money...
R1CH
Forum Veteran
Forum Veteran
Re: RB4011
Thu Oct 03, 2019 12:22 pm
Had an odd issue recently, my 4011 seemed to have a thread stuck at 100% CPU. Had to reboot to get it to go away. Anyone else seen this before?
mrz
Re: RB4011
Thu Oct 03, 2019 2:22 pm
If you see unclassified process, generate supout file and send it to support.
nfored
Re: RB4011
Thu Oct 03, 2019 4:09 pm
@lapsio Thank you that is exactly what I wanted to hear.
UpRunTech
Re: RB4011
Fri Oct 04, 2019 12:58 pm
I agree the RB4011 has lots of grunt. I have just set up a site with 17 CAPACs and am using non-local forwarding CAPSMAN configurations running off some bridges in an RB4011. The RB4011 is connected to a CRS328 switch using only a 10Gbit SFP+. Given my experience using 12 CAPAC/WAPACs in a similar setup using a hEX (amazingly it copes very well with the load) I don't anticipate any problems.
msatter
Re: RB4011
Fri Jun 12, 2020 4:20 pm
Now the hot days are back I looked for a way to cool the 4011 a bit. It is passive cooled by the housing but it still gets quite warm so looked for a very small fan and a way to attach it to the 4011.
I took small plugs used to keep screws into a wall and cut one of the halves of the plug away. then I pushed them in the hole to attach the fan and then I pushed the whole into the cooling slots of the 4011. There is a space of about 7mm between the 4011 and the fan. The are is flowing over the housing of the 4011 increasing the air cooling of the router.
On top I have placed a plug that is adapted to fit the holes in the fan.
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.48beta48 / Winbox 3.27 64bits / MikroTik APP 1.3.15
Hero
Re: RB4011
Sat Jun 20, 2020 4:15 pm
I choose to use a Intel Core2Duo CPU FAN powered by a 5V adapter, for a no noise environment. As you can see in the picture, the FAN is fixit by it's own lock mechanism. For 24 degree in the room, the router is running at 31 degree when both wirelesses are up. I keep the router in a vertical position.
wpeople
Re: RB4011
Tue Jun 23, 2020 7:02 pm
I have to say, RB4011 DO work with passive DAC modules.
On the test bed, 4011 connected to CRS305 with FS.com's passive DAC cable.
https://www.fs.com/de-en/products/74617.html
interface ethernet monitor sfp-sfpplus1
                    status: link-ok
          auto-negotiation: done
                      rate: 10Gbps
               full-duplex: yes
           tx-flow-control: no
           rx-flow-control: no
               advertising:
  link-partner-advertising:
        sfp-module-present: yes
               sfp-rx-loss: no
              sfp-tx-fault: no
                  sfp-type: SFP-or-SFP+
        sfp-connector-type: copper-pigtail
    sfp-link-length-copper: 1m
           sfp-vendor-name: FS
    sfp-vendor-part-number: SFPP-PC01
       sfp-vendor-revision: A
         sfp-vendor-serial: C2006174143-2
    sfp-manufacturing-date: 20-06-08
           eeprom-checksum: good
ps: i'm not an SFP expert, but i think, there is no such thing as auto-negotiate (or its working different way somehow).
For example if you have SFP interface on a device (like 3011) and connecting to SFP+ (like 4011) you need to fix 4011's port to 1G to get it work.
On the test bed above (4011 and CRS305) i tried to disable autoneg on 4011 and set fixed to 1G, there is no link on CRS305.
Probably you need to have dual personality modules, like this:
https://www.fs.com/de-en/products/36432.html
msatter
Re: RB4011
Tue Jun 23, 2020 8:45 pm
At product page only the passive DAC warning remains and it seems that Mikrotik got to grips with the other problems mentioned by you for the 4011. I had some problems with my SPF and that resolved and in the next beta also the last hickup should be tackled.
The solution you mention is already known and used and cheap.
Running:
Smoerrebroed
Re: RB4011
Wed Aug 05, 2020 4:26 pm
Just got my RB4011, and I can confirm that SFP+ works very well with passive DAC. Of course I didn't use the Mikrotik cable. ;) iperf shows around 800 MB/s against my NAS, so I'd say it actually works. Also, I didn't see any flapping.
IPANetEngineer
Trainer
Trainer
Re: RB4011
Wed Aug 05, 2020 5:46 pm
I would be careful until they officially come back with word that it's fixed in prod.
I've worked on this issue across a number of clients and It works intermittently. Will often break after ROS upgrade.
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
oreggin
Re: RB4011
Sat Sep 19, 2020 12:20 pm
Hello! Does anyone know if Mikrotik GPON ONU SFP can be used with this device?
Same question here. Plus I see it is discontinued. There will be a replacement device? Some store has discontinued modules but if it is not supported in 4011 then I don't want to loose 90$.
Atlantis
Re: RB4011
Mon Oct 19, 2020 1:32 am
Hi, can anybody please measure real power consumption of RB4011iGS+5HacQ2HnD-IN when running both wireless APs and mild traffic (or no traffic - just idle)?
By the spec sheet is max power consumption 44 W but I am wondering how much it draws in real when just sitting moreless idle or under mild load. Because having let's say 40W constant load would be pretty significant. Thanks
Paternot
Forum Veteran
Forum Veteran
Re: RB4011
Mon Oct 19, 2020 4:51 am
44 W is while powering another device, through PoE. Without attachments the max power usage is 23 W
https://mikrotik.com/product/rb4011igs_5hacq2hnd_in
Atlantis
Re: RB4011
Tue Oct 20, 2020 12:51 pm
Well that sounds better but I still wonder what is the real power draw - how much it depends on the load etc...can somebody please measure it? Thanks
Users browsing this forum: No registered users and 31 guests
