almj
Traccar GPS http post advice
Wed Sep 05, 2018 6:55 am
Hi Team,
I've got hAP ac2 which will live in my car together with 3G modem and a GPS receiver.
It's all configured, I have internet and VPN tunnel back to home, GPS data is also getting through.
Now I need to send the GPS data to the Traccar server.
There is a script on wiki:
:global lat
:global lon
/system gps monitor once do={
:set $lat $("latitude")
:set $lon $("longitude")
tool fetch mode=http url="http://10.55.8.160/index.php" port=8080 http-method=post \
http-data=("{\"lat\":\"" . $lat . "\",\"lon\":\"" . $lon . "\"}") http-content-type="application/json"
:put ("{\"lat\":\"" . $lat . "\",\"lon\":\"" . $lon . "\"}")
The problem is that I need to send data in OsmAnd format, the syntax is very simple:
http://demo.traccar.org:5055/?id=123456&lat={0}&lon={1}&timestamp={2}&hdop={3}&altitude={4}&speed={5}
id is fixed for the current device.
Can you please help to modify the original script?
Thank you so much!
ADahi
Re: Traccar GPS http post advice
Fri Sep 07, 2018 12:08 am
I do not have GPS, but i tried to write one, may help you
:do {
:local latitude ([/system gps monitor as-value once]->"latitude");
:local longitude ([/system gps monitor as-value once]->"longitude");
:do {/tool fetch keep-result=no url=("http://demo.traccar.org:5055/\?id=123456&lat=" . $latitude . "&lon=" . $longitude . "&timestamp={2}&hdop={3}&altitude={4}&speed={5}")
} on-error={:log error message="Fetch failed..."}
} on-error={:log error message="GPS script failed..."}
mibauer1701
Mon Sep 24, 2018 11:58 pm
Thanks for the hint, but I´m not able to get it working...
Can please someone add a working script? Or give at least a little help?
Thanks!!
Michael
VipITBE
Mon Nov 26, 2018 12:34 pm
The problem is that the values returned by the tik GPS are not in a decimal value.
You need the data in a decimal value to post to traccar. Same with altitude and speed. For those you need to remove m and km/h from the data.
Just tested with Postman and after converting the latitude and longtitude to decimal value it would post
jspool
Mon Nov 26, 2018 6:32 pm
viewtopic.php?f=9&t=137114&p=697697&hil ... pi#p697348
When Mikrotik updates the GPS package and enables it to output the location data to a friendly format it should work fine without requiring a middleman server to translate the data.
Currently I use Particle Electrons to send location data to Traccar and it works great. However I would love to use the LtAP as well.
VipITBE
Tue Nov 27, 2018 10:57 am
I've got a working script since last night.
Started working on it and took some code snips from other scripts, including a github page I've found to be very helpfull, and the script translates the coordinates - outputted by /gps monitor - to decimal coordinates.
I've uploaded the script to github, but will be making some changes.
The tracket ID is the same as the LTE IMEI address
I'll be experimenting with the date-time so that can also be uploaded to traccar.
The current variables that need be updated are:
:local serverurl "demo5.traccar.org";
:local serverport "5055";
The script is located at
https://github.com/CreasaBE/Mikrotik_Sc ... ar_updater
normis
Tue Nov 27, 2018 1:18 pm
v6.44beta37 will have:
*) gps - added "coordinate-format" parameter (CLI only);
ddmm will be an option.
VipITBE
Tue Nov 27, 2018 1:50 pm
Sweet!
Is there some way of extracting or generating a datetime timestamp ?
VipITBE
Thu Nov 29, 2018 2:35 pm
Sweet!
Timestamp issue solved with a script from forum user adeeadee
viewtopic.php?t=75555
script updated with the addition of the datestamp and posting the datestamp to the Traccar server
jspool
Fri Nov 30, 2018 2:48 am
Thanks Normis!
nemke
Wed Dec 19, 2018 12:03 am
Where is "cordinate format" in CLI ?
Under system/gps I can't find it. I use 6.44.beta50
bazzer
Trainer
Trainer
Fri Dec 21, 2018 10:39 pm
continued monitoring
/system gps monitor format=<dd ddmm dms>
one off read out
/system gps monitor once format=<dd ddmm dms>
Barry Higgins
Mikrotik Certified Trainer
MTCRE MTCWE MTCTCE MTCUME MTCIPv6E MTCINE MTCSE
https://www.allness.it
Users browsing this forum: No registered users and 25 guests
