susil
Upcoming Highend CCR Router model
Sun Sep 09, 2018 7:40 pm
Dear ,
Kindly suggest upcoming high end CCR router which can support bandwidth aggregation.
I have 3 ISP , each ISP having throughput 1.5gig *3, also 2 nos of 1gig each peering traffic,Kindly suggest me the Best model which can aggregate bandwidth, if any upcoming model is suppose to introduce please suggest.
Susil
jarda
Re: Upcoming Highend CCR Router model
Wed Sep 19, 2018 4:54 pm
You need many sfp+ /10g interfaces so for example this:
https://mikrotik.com/product/CCR1072-1G-8Splus
susil
Mon Oct 01, 2018 6:03 am
Thanks my Dear !
Could you please suggest me 10g Switch for backbone use.
Susil
vecernik87
Long time Member
Long time Member
Mon Oct 01, 2018 9:51 pm
You should specify if you need Layer 2 or Layer 3 switch. (mikrotik makes only L2 switches)
Usually, term "switch" is understood as L2 switch. On the other hand, unless you really need L2 features, it is more common to have L3 backbone network. Otherwise broadcasts might turn it into hell for you.
Similarly, it is impossible to suggest anything if you don't specify amount of required ports. I assume this is for different purpose than originally requested CCR, right?
Users browsing this forum: No registered users and 7 guests
