bjornr
Port mirroring not working with CRS326-24G-2S+
Thu Sep 13, 2018 3:09 pm
I'm not able to get port mirroring working on a CRS326-24G-2S+. The unit runs 6.43 and the new bridge VLAN setup.
[admin@coreswitch] /interface ethernet switch> print
Flags: I - invalid
 #   NAME     TYPE             MIRROR-SOURCE   MIRROR-TARGET   SWITCH-ALL-PORTS
 0   switch1  Marvell-98DX3236 none            none
[admin@coreswitch] /interface ethernet switch> set switch1 mirror-source=ether20
 mirror-target=ether05
failure: cpu flow control not supported
I've tried removing ether05 from the bridge VLAN setup, but that didn't change anything.
Any ideas?
artz
Re: Port mirroring not working with CRS326-24G-2S+
Thu Sep 13, 2018 5:43 pm
It seems you discovered a bug, a fix will be released in the next 6.44beta version and later in 6.43.x
Currently you will have to reset the configuration and reapply the configuration in order to fix this issue or wait until an update is released.
Sorry for the inconvenience!
Users browsing this forum: sid5632 and 129 guests
