MUM Europe 2020
krystian
Mikrotik RB962UIGS wifi speed problem
Tue Sep 18, 2018 1:43 pm
I have Mikrotik RB962UIGS and wifi speed problem.
My connection WAN is 100 Mbit/s and cable LAN speed is OK about 98 Mbit/s.
I have my MacBook Pro 13 2017 connected to this Mikrotik 5GHz and my connect is good condition.
I have max only 75-80 Mbit/s I don't know why... my MacBook I have 2 meters from Mikrotik.
Maybe someone will tell me how to fix it so that I would have about 100Mbit/s after wifi?
normis
Re: Mikrotik RB962UIGS wifi speed problem
Tue Sep 18, 2018 1:46 pm
Bring it further away. Try other wifi frequency in settings. Make sure you have all 3 chains enabled.
krystian
Tue Sep 18, 2018 1:53 pm
This is my 5GHz configuration: https://postimg.cc/gallery/1rjz2x9u6/
WirtelPL
Tue Sep 18, 2018 2:26 pm
Turn off auto frequency. Select fixed channel, e.g. 5180 MHz.
Don't use 802.11a mode if you don't must. Set n and ac.
RB951G-2HnD for home production
RBmAP2nD | RB952Ui-5ac2nD-TC for home lab
krystian
Tue Sep 18, 2018 2:30 pm
It will be ok?
https://i.postimg.cc/zf3WNZ4D/4mt.png
WirtelPL
Tue Sep 18, 2018 2:40 pm
Yes, now the settings are correct. If it still goes wrong, try changing the width or channel (frequency).
krystian
Tue Sep 18, 2018 2:44 pm
Ok but 20/40/80 Ceee will be good?
krystian
Tue Sep 18, 2018 2:48 pm
Such a connection should 100 Mbit/s without a problem like that?
WirtelPL
Tue Sep 18, 2018 2:56 pm
This setting is good in itself. It all depends on the use of channels in your area.
I use the 20/40 ce channel in 802.11n mode and at 100Mbit/s from the provider I reach 96 - 97 Mbit/s.
krystian
Tue Sep 18, 2018 3:08 pm
I don't have 5GHz networks in my area so I should have about 100 Mbit/s wifi speed no problem... I check it when will be in home, thanks.
krystian
Wed Sep 19, 2018 8:14 am
I check and I have about 75-80 Mbit/s all time... I don't know why...
eddieb
Wed Sep 19, 2018 8:55 am
Running 6.46 (stable) on :
CCR1009-8G-1S (2x ipsec/l2tp site-to-site, ipsec/l2tp roadwarrior, dhcpd, dns), CRS125-24G-1S, RB1100, RB962UiGS-5HacT2HnT (10pc), RB931-2nD, RB951, RB750GL ,RB2011UAS-RM, CHR running dude (CHR running in VirtualBox on OSX)
krystian
Thu Sep 20, 2018 9:11 am
I tried different settings but all the time I have max 75-80 Mbit/s.
I don't know why...
I went with the Macbook next to Mikrotik and all time I have the same.
Wired connection I have 98-100 Mbit/s.
Users browsing this forum: No registered users and 22 guests
