MUM Europe 2020
blackbox100
CRS326 6.43.2 Reset Mac-adress results in kernel failure
Thu Sep 27, 2018 2:18 pm
Hi all
on 6.43.2 and the previous 6.43.1 and 6.44beta9 if you try to reset the Mac-adress on a interface, the switch hangs and becomes unresponsive, after a reboot, the log shows kernel failure in previous boot
It works perfectly in 6.43.rc.12
Can anyone verify this fault?
Sincerely
Carsten Larsen
nescafe2002
Long time Member
Long time Member
Re: CRS326 6.43.2 Reset Mac-adress results in kernel failure
Thu Sep 27, 2018 3:03 pm
I encountered the same on a rb3011 in 6.43rc66 and reported to support:
You might be able to avoid this bug by setting hw=no to all ports or by enabling IGMP Snooping, though that might not help entirely, it vastly depends on the traffic type and amount of it.
and one week later:
We reproduced this issue in our labs and fixed it, you should wait for the next 6.44beta version, most probably a fix will be included in 6.44beta11 or newer.
blackbox100
Thu Sep 27, 2018 3:33 pm
Ok thanks
Will wait for next beta
Users browsing this forum: No registered users and 19 guests
