larmaid
how to conect 2 mikrotik....?? [urgent]
Mon Feb 19, 2007 8:02 am
hi im having a small problem, i just setting a new mikrotik (2.9.27) and i want to connect with my other mikrotik (2.9.7)
here r the ip config =
mikrotik 1(2.9.7) =
ether 1 -> 10.10.0.xxx (local)
ether 2 -> 202.165.xxx.xxx (global)
mkrotik 2(2.9.27) =
bridge1 -> 10.10.0.xxx (i connected 4 ether with bridge1) (local)(reply-only)
ether5 -> 202.165.xxx.xxx (global)
right now i connect to mikrotik 1 using ether1 the problem is i cant connect to local network on mikrotik 2....!!!!
here is my nat on mikrotik2 =
chain=dstnat | action=dst-nat | to address=10.10.xxx.xxx | to-ports=0-65545
anyone can help me ...... :(
thx
i like it
janisk
Mon Feb 19, 2007 9:00 am
this "bug" is solved in 2.9.40
larmaid
Mon Feb 19, 2007 9:16 am
is this a "bug"...... :?
so your saying that my configuration is right...!!!!
i like it
janisk
Mon Feb 19, 2007 9:26 am
ok. check your routes - if everything is ok, can you ping current nework (set on interface) can you ping one further.
and i encourage you to use newest version of RouterOS that would be 2.9.40 as it is recommended. :roll:
larmaid
Mon Feb 19, 2007 9:31 am
my routers is OKAY, but the problem i cant connect to mikrotik2 local network..... :(
i like it
janisk
Mon Feb 19, 2007 9:34 am
are routed ok on MT2?
larmaid
Mon Feb 19, 2007 9:37 am
the local network on MT2 is OK & the machine MT2 is OK, so whats wrong???any solution..???, btw janisk can i contact u by YM...???
i like it
janisk
Mon Feb 19, 2007 10:37 am
please post ip address configuration
ip route configuration here of both routers.
and as i have understood than MT2 default gateway is MT1 right? or what you want to achieve with this configuration, that both routers have real ip address
larmaid
Mon Feb 19, 2007 11:03 am
okay here r the all most configration :
mikrotik1 =
ether1 -> 10.10.9.99/16 (local)
ether2 -> 202.165.xxx.xxx (global)
gateway -> 202.165.33.xxx (cisco gateway)
mikrotik2 =
ether1 -> no ip (bridge1)
ether2 -> no ip (bridge1)
ether3 -> no ip (bridge1)
ether4 -> no ip (bridge1)
bridge1 -> 10.10.10.99/16 (bridge local)
ether 5 -> 202.165.xxx.xxx (global)
any solutions....???? :cry:
time is closing.............
i like it
janisk
Mon Feb 19, 2007 11:12 am
mikrotik1 =
mikrotik2 =
so there is no physical link to MT2 other than through your cisco Gateway, is it?
larmaid
Mon Feb 19, 2007 11:22 am
that is true.....!!!!
so.....
i like it
normis
Mon Feb 19, 2007 1:04 pm
please upgrade, there is no reason not to
Users browsing this forum: Baidu [Spider], eworm, jmcguckin, sindy, temporal, wispmikrotik, Znevna and 107 guests
