IS0FFD
RB750UP firmware update problem
Fri Oct 05, 2018 5:41 pm
I have updated two RB750UP ros 6.43.2, when I try to update the firmware the RB stops working and needs a full reset.
The current firmware on board in 3.19, I would like to upgrade it to 6.43.2 :)
I tried a search on the forum but I did not find any information.
I add:
at every reboot I have to completely reset... it is not normal!!!
Nivalis
Re: RB750UP firmware update problem
Wed Oct 17, 2018 12:53 pm
Hello, I have same problem with upgrade firmware on 750UP (i have 30 routers). I try to send this problem in Support with [Ticket#2018100822005227], but they recommend to use NetInstall. It's not working for me. I noticed that after upgrade firmware eth led began fast-fast blinking.
chechito
Sun Oct 21, 2018 5:30 am
same here 2 rb750up
we had to netinstall them with 6.42.9, no more tries with 6.43.xx for a while for us
AndresRqta
Mon Oct 22, 2018 4:05 am
I have similar problem. but with RB751u-2hnd. this RB is previously hacked with coinhive-virus.
viewtopic.php?f=2&t=140672&p=693661&hilit=virus#p693661
Nivalis
Mon Nov 26, 2018 10:20 am
I can update 750UP to 6.42.10 firmware with disabled poe and firewall.
xicu
Wed Dec 12, 2018 2:52 pm
We have detected these problem with more than 5 RB750UP. When we try to upgrade firmware then it not starts.
Users browsing this forum: No registered users and 64 guests
