MUM Europe 2020
masteruwu
The Dude scan kills network connectivity
Tue Oct 09, 2018 11:09 am
Hi everyone,
RB750Gr3 on 6.43.2 here.
If i enable The Dude service and connect to it, The Dude client suddenly drops connection about 2 minutes in. Then the client tries to re-connect and fails.
My network continues working for another 2-3 minutes, then everything stops responding.
Even if i wait 15, 20 minutes it stays down. If I pull the power plug and put it back in, i don't hear the power-on beep.
The only way I could get the router to work again is doing a hard reset...
I had set up dude-data on my disk1 microSD.
This happened twice in a row, am I doing something wrong?
I followed this guide exactly: https://wiki.mikrotik.com/wiki/Manual:T ... X_RB750Gr3
Thanks in advance!
jarda
Re: The Dude scan kills network connectivity
Tue Oct 09, 2018 10:51 pm
I was running the dude on 750Gr3 in role as main router for almost two years and this never happened. From other reasons I moved the dude to chr.
masteruwu
Sat Oct 13, 2018 8:35 am
I believe you, but why could this be happening? I'm unable to view logs since the router effectively locks me out after a short while of being connected to The Dude.
My 750gr3 is working great except i would like to be able to use the dude :(
jarda
Thu Oct 18, 2018 11:34 am
I have no other idea than recheck the disk, it's format, router settings.. Maybe the netinstall can help as it clears everything out.
Joni
Thu Oct 18, 2018 2:59 pm
Mikrotik is notoriously famous for under performing MicroSD (compatibility?), and Dude uses a lot of I/O (in comparison to logging). Switch to USB and compare.
Users browsing this forum: No registered users and 5 guests
