MUM Europe 2020
nickb333
L2TP server interface in VRF?
Wed Oct 10, 2018 6:26 pm
I am trying to isolate L2TP connections on my router so the traffic goes into separate VRFs.
I have created two static l2tp server instances
/ip route vrf
add interfaces=l2tp-in1,ether4 routing-mark=SYSTEM1
add interfaces=l2tp-in2,ether3 routing-mark=SYSTEM2
Created two VRFs
/ip route vrf
However when I connect from L2TP client to l2tp-in1 I can still ping stuff in SYSTEM2 vrf or the main routing table.
I've read viewtopic.php?t=45122 but that seems to refer to PPPoE.
What am I missing?
Thanks.
Nick B.
UK.
floaty
Re: L2TP server interface in VRF?
Thu Nov 22, 2018 1:12 am
I'm not really an english-teacher ... but ...
when we examine the word 'or' in the quote above , it is not possible to bring the described failure in compliance to master George Boole ... aren't we ?
... so: first check if the setup you've tested in, may be leaky (in terms of routing - detouring the box you wanted to test).
... allways noteable in Mikrotik-OS ( ... until now [v6.4xx]) you can have overlapping address-space in VRF's ... BUT ! ... you can not have overlapping interface-addresses in different VRF's on your MTik : |
sincerely
floaty
We know what happens to people who stay in the middle of the road. They get run over.
nickb333
Sat Dec 01, 2018 11:52 pm
Thanks for your helpful reply. I see you posted a solution using scripts which makes things clearer to me. I've implemented VRFs on Cisco equipment but Mikrotik just doesn't work the way I was expecting it to!
Nick B.
UK.
Users browsing this forum: Google [Bot], zuyang and 128 guests
