thasser
FEATURE QUESTION/REQUEST: Logging blocked login attempts from IP's outside the whitelist added under ip -> services
Mon Oct 15, 2018 9:52 pm
This writing to the log file, although minute, causes some CPU power. If this were exploited it could make one of our devices more vulnerable to a DDoS attack than if it were not logged, correct?
sindy
Re: FEATURE QUESTION/REQUEST: Logging blocked login attempts from IP's outside the whitelist added under ip -> services
Mon Oct 15, 2018 10:34 pm
I'd say there are many more ways to exhaust the CPU than by writing to the disk once per minute. But if you want to avoid these log messages, set up the firewall so that it wouldn't permit access to the service port from outside the address range.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Users browsing this forum: lucapsg, nick7, Zacharias and 240 guests
