MUM Europe 2020
jmguilbert
Migrate CCR 1009 to CCR 1036
Sat Oct 20, 2018 1:28 pm
hello
I search the method for migrate my CCR1009 to my new CCR1036.
The combo port is not present in the CCR1036.
Should i modify manually the backup file before "import" ?
Thank for your advice.
JM.
joegoldman
Long time Member
Long time Member
Re: Migrate CCR 1009 to CCR 1036
Sat Oct 20, 2018 2:57 pm
get a copy of /export from your 1009, make the necessary adjustments to change ports etc and run it as an import on your 1036.
xvo
Long time Member
Long time Member
Sat Oct 20, 2018 3:45 pm
hello
JM.
You shouldn't use a backup file on the hardware of different type from the one it was created on.
ingdaka
Sun Oct 21, 2018 12:14 am
Backup file will give you error if you are in different models. Even if you are in same model you have to make reset mac after restore to new machine.
Best practice is to got to terminal to actual device type export, copy all to txt file, make your necessary modifications and then go to new device terminal and paste al modified text!
This will make you correct config also with all passwords!
Ilir Daka
Electronic & Network Engineer
E-mail: ilirdaka@live.com
Mob: +355692982151
WhatsApp: +355692982151
Mikrotik Official Consultant
CCNA | Fortinet NSE3 | MTCRE | MTCSE
Users browsing this forum: No registered users and 26 guests
