Stril
Winbox-Traffic - 200kbit/s
Fri Nov 02, 2018 10:02 am
Hi!
Winbox takes a lot of traffic, if it is simply connected to a router (about 200kbit/s).
Is there any possibility to limit this?
Today, I just had the problem, that two engineers have been connected on a low-bandwidth-link and that caused problems...
Thank you for your hints
Stril
xvo
Long time Member
Long time Member
Re: Winbox-Traffic - 200kbit/s
Fri Nov 02, 2018 10:29 am
Winbox traffic depends on the number of simultaneously opened windows (number of data, that need to be refreshed in real-time).
Stril
Fri Nov 02, 2018 10:48 am
Hi!
Yes, but with only one window, I already see 200 kbps...
nescafe2002
Long time Member
Long time Member
Fri Nov 02, 2018 10:51 am
You can use ssh to configure device on low bandwith links.
yancho
Fri Nov 02, 2018 11:46 am
Torch? :)
xvo
Long time Member
Long time Member
Fri Nov 02, 2018 12:04 pm
Torch? :)
Not necessarily :)
For example firewall with around 40 rules - adds around 100kbps in spikes.
Interfaces window with 10 interfaces - 80kbps, almost constantly.
IPsec Installed SAs with 10 items - 20kbps.
So opening a bunch of windows can easily create a constant bandwidth of 200-250kbps.
As was already mentioned by @nescafe2002 - if it becomes a problem, one can always use ssh.
Stril
Fri Nov 02, 2018 12:09 pm
Hi!
I see constantly 200 kbps with NO open windows.
...tested with CRS 326.
Stril
xvo
Long time Member
Long time Member
Fri Nov 02, 2018 12:16 pm
Hi!
Stril
Are you sure that it's winbox traffic?
Stril
Fri Nov 02, 2018 12:50 pm
Hi!
Absolutely.
I checked it twice
xvo
Long time Member
Long time Member
Fri Nov 02, 2018 1:08 pm
Hi!
Absolutely.
I checked it twice
It should not be that way.
That is winbox connections to 4 different routers:
Lower 3 have no open windows, only cpu/time/date/etc in the dashboard.
Upper one has an open IP --> Firewall --> Connections from where I took a screenshot.
So it never rises over 5kbps/10kbps (To winbox/From winbox) for the ones without windows open.
So check again that it is a single winbox connection and not something else on the router.
seho
Fri Nov 02, 2018 3:08 pm
How are you connecting with Winbox?
When I connect to the Router I can also see, up to 250kbits but only when I use the MAC-ADDRESS for connecting.
Greets,
Sebastian
Stril
Fri Nov 02, 2018 4:09 pm
Hi!
Thats strange... I am connecting to the IP of the CRS.
I just checked my Firewall-connection-list....
If I just connect to the CRS, it consumes only a few kbps (14,4)
If I only open the interface-list, it goes up to 260 kbps
--> The problem seems to be the Interface List.
Can you confirm this?
xvo
Long time Member
Long time Member
Fri Nov 02, 2018 4:15 pm
Hi!
As I already posted, for 10 interfaces I have ~80kbps, so 260kbps for your almost 30 interfaces totally makes sense.
Stril
Fri Nov 02, 2018 4:20 pm
Hi!
It would be great to be able to configure the refresh rate to lower that bandwidth consumption...
xvo
Long time Member
Long time Member
Fri Nov 02, 2018 4:43 pm
Hi!
You can give it a try here: viewtopic.php?t=45934
Users browsing this forum: anav, Google [Bot], sindy, sv000008 and 47 guests
