firebat
Wireless MAC authenication?
Mon Feb 26, 2007 7:38 am
Is wireless MAC authenication supported in 2.9.40 or is it in BETA3? I tried to set it up in 2.9.40 and its not working.
Also, is anyone seeing issues with adding a customer or a router via the CLI and it not showing up in user manager in 2.9.40? (still there in CLI)
sergejs
Mon Feb 26, 2007 8:21 am
1) Use the particular example to accomplish MAC-authentication,
http://wiki.mikrotik.com/wiki/User_Mana ... ss_Example
Report back if you will have any problems.
2) Make sure that customer has enough permissions to view other customers.
firebat
Mon Feb 26, 2007 9:11 am
Yeah, I tried that and it didn't work in 2.9.40.
Like I said, 2.9.40 user manager cant even see changes that you make via the CLI. I tried adding a new customer as an owner via the user manager and I get an error indicating only subscribers can be owners. I add it via the CLI and it is fine but user manager doesn't the new customer. I added a router via the CLI and user manager didn't see it either.
sergejs
Mon Feb 26, 2007 9:44 am
1) Send support output file to support(support@mikrotik.com), regarding this issue.
2) Could you provide the exact command used, when you are tying to add new customer ?
firebat
Tue Feb 27, 2007 7:27 am
How many customers can you have on a system (parent is himself)? I can only get one added via user manager.
BTW, authorization is spelled incorrectly in user manager. User manager has it spelled with an s: authorisation.
Can you rate limit wireless customers? I select rate limit and enter the data but as soon as I click save, the rate limit box becomes unchecked.
sergejs
Wed Feb 28, 2007 3:16 pm
Thank you for the spelling error report, the particular issue has been fixied.
You cannot set 'rate-limit' attribute/option for RADIUS wireless clients, 'rate-limit' might be used for HotSpot,PPP, DHCP wireless clients.
firebat
Thu Mar 01, 2007 9:58 am
Thanks. Is that something that will be added in the future? :D
Also, how many customers can you have on a system (parent is himself)? I can only get one added via user manager.
dawam
Trainer
Trainer
Re: Wireless MAC authenication?
Thu Mar 01, 2007 6:32 pm
I got this issue on my router too.. Though it was only me. luckily its my house router.
firebat
Sat Mar 10, 2007 9:12 am
Will this be available for radius wireless clients soon? :)
Users browsing this forum: No registered users and 24 guests
