dark
Route all traffic through NordVPN?
Tue Nov 20, 2018 7:29 pm
I am new to MikroTik and bought a Mikrotik hAP Lite Intern (RB941-2nD) and would like to configure the following:
The router is behind a firewall I have no access to. To use VPN I have to use Port 443 and TCP.
It is connected to the network with a LAN cable and should be an access point that routes all traffic through a NordVPN Server.
I tried a few tutorials, but nothing worked. The NordVPN support says that the router doesn't support OpenVPN, but it obviously does.
Any chance to do the above?
Thank you for every answer :)
(Here is the .ovpn file I have: https://downloads.nordcdn.com/configs/f ... m.tcp.ovpn)
m4t7e0
Re: Route all traffic through NordVPN?
Wed Nov 21, 2018 7:30 pm
Hi, yes is possible,
first step is setup your openVPN VPN you know hot to do it?
Plese Read https://support.nordvpn.com/#/Connectiv ... -Setup.htm
than you can simple make a prerouting "NordVPN route" mangle rules with for all the traffic that you want to route on NordVPN and than add a static route 0.0.0.0/0 gateway "nordvpn inteface" route mangle "NordVPN route"
sharik987
Tue Nov 27, 2018 10:29 am
How did you set up Mikrotik with NordVPN?
msatter
Tue Nov 27, 2018 1:48 pm
Mikrotik does not yet support the features needed to make use those kind of OpenVPN services.
L2TP/IPSEC is fully supported.
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.47 / Winbox 3.24 / MikroTik APP 1.3.14
filipelias
Tue Nov 27, 2018 3:03 pm
So, Is it possible or not?
Send from my Moto Z Play using Tapatalk.
sharik987
Wed Nov 28, 2018 10:09 am
Why does not it work?
/interface l2tp-client
add connect-to=us2854.nordvpn.com ipsec-secret=nordvpn name=L2TP-nordvpn password=xxxxxxx profile=default user=xxxxxx@gmail.com
/ip ipsec peer
add address=us2854.nordvpn.com disabled=yes exchange-mode=main-l2tp generate-policy=port-strict secret=nordvpn (ipisec manual mode)
add address=87.101.95.163/32 exchange-mode=main-l2tp generate-policy=port-strict secret=nordvpn (ipisec dinamic mode)
/ip ipsec policy
add dst-address=87.101.95.163/32 dst-port=1701 proposal=NordVPN protocol=udp src-address=10.153.XXX.XX/32 src-port=1701
add action=accept chain=input comment="aloow ipsec-ah" protocol=ipsec-ah
add action=accept chain=input comment="allow ipsec-esp" protocol=ipsec-esp
add action=accept chain=input comment="allow l2tp" dst-port=1701,500,4500 protocol=udp
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=md5 enc-algorithms=aes-256-cbc,aes-128-cbc,3des
add auth-algorithms=md5 enc-algorithms=3des lifetime=1h name=NordVPN
darkprocess
Wed Nov 28, 2018 1:01 pm
NordVPN dropped support of l2tp.
msatter
Wed Nov 28, 2018 1:45 pm
Is going to drop support for it on the 1st of December.
https://nordvpn.com/blog/l2tp-pptp-protocol-update/
Come on Mikrotik. We can't use OpenVPN or IKEv2 with NordVPN so which protocol are we going to use? SSTP is only possible with a few providers.
Running:
marianob85
Sun Dec 02, 2018 1:48 pm
@Mikrotik support.
When we can expect OVPN or IKEv2 support for NordVPN ?
m4t7e0
Thu Dec 06, 2018 6:42 pm
Hi dear, i'm so sorry i forgot about USING TCP 443 Port, the only avaiable VPN i think the good one is using SSL like SSTP, but seem they doesen't support this protocol.
castlemaster
Fri Dec 07, 2018 2:09 pm
I've just been chatting with NordVPN about this matter too and they say it's mikrotik's OpenVPN Client implementation that's broken, so when can we expect a fix? They suggest flashing OpenWRT or DD-WRT but I don't want to touch those.
lucasimo88
Fri Dec 07, 2018 9:37 pm
We need complete support for IPSEC/IKEv2 with EAP Authentication...
TheSirStumfy
Tue Dec 11, 2018 8:39 am
Last i heard about this was "probably in rOs V7"... :(
psydrohne
Sun Jan 06, 2019 5:49 pm
[/quote]
[/quote]
Please make OpenVPN or IKEv2 support for NordVPN soon! My Microtik hEX is actually useless, because NordVPN drops L2TP support...
Xymox
Mon Jan 28, 2019 2:39 pm
Ive been asking and posting about this for years. I do not understand why Mikrotik refuses to address this. Its very easy to add this. They added "kid control" which was far more difficult and involved.
Could there be some reason they have intentionally not implemented OpenVPN fully ? Does it create a level of security for users that some countries don't like ?
Over years I have seen this come up over and over and it never gets solved.
gotsprings
Forum Veteran
Forum Veteran
Mon Jan 28, 2019 8:34 pm
OVPN has not worked on port 1194 for about 10 years now.
Also as for using those VPN services to "side step" geolocation... providers update their blacklists from time to time too.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
bgma
Mon Mar 11, 2019 11:09 am
Any news on OpenVPN client?
I find it rude that Mikrotik doesn't even bother to comment ...
jimint
Tue Mar 19, 2019 10:21 am
+1000
pronto
Thu Jul 04, 2019 10:27 pm
Polard55
Tue Jul 09, 2019 9:52 am
Seems to be working now, see here: https://wiki.mikrotik.com/wiki/IKEv2_EA ... d_RouterOS
That's great news that finally Mikrotik is supporting IKEv2 properly, Btw I have been using L2tp Protocol on Mikrotik, as my vpn client [REDACTED] still support it, I have configured it easily by following this guide: https://www.[REDACTED].com/download/router-vpn but still I want to switch it on IKev2 as its much better and secure protocol and finally I can do it. Thanks for sharing this.
daydiff
Sat Dec 14, 2019 11:28 am
Is it broken again? I'm getting an error on the latest RouterOS 6.46
21:30:42 ipsec ike2 starting for: 23.226.132.237
21:30:43 ipsec adding notify: NAT_DETECTION_DESTINATION_IP
21:30:43 ipsec adding notify: NAT_DETECTION_SOURCE_IP
21:30:43 ipsec adding payload: NONCE
21:30:43 ipsec adding payload: KE
21:30:43 ipsec adding payload: SA
21:30:43 ipsec <- ike2 request, exchange: SA_INIT:0 23.226.132.237[4500] 6d7e507d7e8ae0b2:0000000000000000
21:30:43 ipsec -> ike2 reply, exchange: SA_INIT:0 23.226.132.237[4500] 6d7e507d7e8ae0b2:0000000000000000
21:30:43 ipsec payload seen: NOTIFY
21:30:43 ipsec first payload is NOTIFY
21:30:43 ipsec processing payloads: NOTIFY
21:30:43 ipsec   notify: COOKIE
21:30:43 ipsec adding notify: COOKIE
21:30:43 ipsec -> ike2 reply, exchange: SA_INIT:0 23.226.132.237[4500] 6d7e507d7e8ae0b2:8c639a553a050e77
21:30:43 ipsec ike2 initialize recv
21:30:43 ipsec payload seen: SA
21:30:43 ipsec payload seen: KE
21:30:43 ipsec payload seen: NONCE
21:30:43 ipsec processing payload: NONCE
21:30:43 ipsec processing payload: SA
21:30:43 ipsec IKE Protocol: IKE
21:30:43 ipsec  proposal #1
21:30:43 ipsec   enc: aes128-cbc
21:30:43 ipsec   prf: hmac-sha1
21:30:43 ipsec   auth: sha1
21:30:43 ipsec   dh: modp2048
21:30:43 ipsec matched proposal:
21:30:43 ipsec processing payload: KE
21:30:43 ipsec,info new ike2 SA (I): 192.168.178.24[4500]-23.226.132.237[4500] spi:6d7e507d7e8ae0b2:8c639a553a050e77
21:30:43 ipsec   notify: NAT_DETECTION_SOURCE_IP
21:30:43 ipsec   notify: NAT_DETECTION_DESTINATION_IP
21:30:43 ipsec   notify: MULTIPLE_AUTH_SUPPORTED
21:30:43 ipsec (NAT-T) LOCAL
21:30:43 ipsec KA list add: 192.168.178.24[4500]->23.226.132.237[4500]
21:30:43 ipsec init child
21:30:43 ipsec init child continue
21:30:43 ipsec offering proto: 3
21:30:43 ipsec   enc: aes256-cbc
21:30:43 ipsec   enc: aes192-cbc
21:30:43 ipsec can't get local certificate from configuration
21:30:43 ipsec ID_I (ADDR4): 192.168.178.24
21:30:43 ipsec adding payload: ID_I
21:30:43 ipsec adding notify: INITIAL_CONTACT
21:30:43 ipsec initiator selector: 0.0.0.0/0
21:30:43 ipsec adding payload: TS_I
21:30:43 ipsec responder selector: 0.0.0.0/0
21:30:43 ipsec adding payload: TS_R
21:30:43 ipsec prepearing internal IPv4 address
21:30:43 ipsec prepearing internal IPv4 netmask
21:30:43 ipsec prepearing internal IPv6 subnet
21:30:43 ipsec prepearing internal IPv4 DNS
21:30:43 ipsec adding payload: CONFIG
21:30:43 ipsec <- ike2 request, exchange: AUTH:1 23.226.132.237[4500] 6d7e507d7e8ae0b2:8c639a553a050e77
21:30:43 ipsec -> ike2 reply, exchange: AUTH:1 23.226.132.237[4500] 6d7e507d7e8ae0b2:8c639a553a050e77
21:30:43 ipsec payload seen: ENC
21:30:43 ipsec processing payload: ENC
21:30:43 ipsec payload seen: ID_R
21:30:43 ipsec payload seen: CERT
21:30:43 ipsec payload seen: AUTH
21:30:43 ipsec payload seen: EAP
21:30:43 ipsec processing payloads: NOTIFY (none found)
21:30:43 ipsec ike auth: initiator finish
21:30:43 ipsec processing payload: ID_R
21:30:43 ipsec ID_R (FQDN): us3398.nordvpn.com
21:30:43 ipsec processing payload: AUTH
21:30:43 ipsec processing payloads: CERT
21:30:43 ipsec got CERT: us3398.nordvpn.com
21:30:43 ipsec got CERT: CN=NordVPN CA4,C=PA,ST=,L=,O=NordVPN,OU=,SN=
21:30:43 ipsec requested auth method: RSA
21:30:44 ipsec,info,account peer authorized: 192.168.178.24[4500]-23.226.132.237[4500] spi:6d7e507d7e8ae0b2:8c639a553a050e77
21:30:44 ipsec processing payload: EAP
21:30:44 ipsec adding payload: EAP
21:30:44 ipsec <- ike2 request, exchange: AUTH:2 23.226.132.237[4500] 6d7e507d7e8ae0b2:8c639a553a050e77
21:30:44 ipsec -> ike2 reply, exchange: AUTH:2 23.226.132.237[4500] 6d7e507d7e8ae0b2:8c639a553a050e77
21:30:44 ipsec payload seen: ENC
21:30:44 ipsec processing payload: ENC
21:30:44 ipsec payload seen: EAP
21:30:44 ipsec processing payloads: NOTIFY (none found)
21:30:44 ipsec <- ike2 request, exchange: AUTH:3 23.226.132.237[4500] 6d7e507d7e8ae0b2:8c639a553a050e77
21:30:44 ipsec -> ike2 reply, exchange: AUTH:3 23.226.132.237[4500] 6d7e507d7e8ae0b2:8c639a553a050e77
21:30:44 ipsec <- ike2 request, exchange: AUTH:4 23.226.132.237[4500] 6d7e507d7e8ae0b2:8c639a553a050e77
21:30:46 ipsec -> ike2 reply, exchange: AUTH:4 23.226.132.237[4500] 6d7e507d7e8ae0b2:8c639a553a050e77
21:30:46 ipsec payload seen: ENC
21:30:46 ipsec processing payload: ENC
21:30:46 ipsec payload seen: EAP
21:30:46 ipsec processing payloads: NOTIFY (none found)
21:30:46 ipsec processing payload: EAP
21:30:46 ipsec,error EAP failed:
21:30:46 ipsec,info killing ike2 SA: 192.168.178.24[4500]-23.226.132.237[4500] spi:6d7e507d7e8ae0b2:8c639a553a050e77
21:30:46 ipsec KA remove: 192.168.178.24[4500]->23.226.132.237[4500]
Users browsing this forum: No registered users and 35 guests
