reza388
lost configuration on every reboot
Sat Dec 01, 2018 7:22 am
Hi and have good time
I have two sxt lite 5 after config it on reboot lose ever config and device reset to factory default.
I upgrade it by netinstall to 6.34.4 but not sloved.
Does it have a solution?
software or Hardware.
thankyo
laithmikrotik
Re: lost configuration on every reboot
Sat Dec 01, 2018 10:19 am
that mean is the memory loses the OS data information after every rebooting .so lets say that your issue in the hardware
reza388
Sat Dec 01, 2018 11:15 am
Thanks for your replay.
Which part may be broken?
thankyo
msatter
Sat Dec 01, 2018 1:24 pm
Just thinking. Do you have them well grounded (earth)?
The best is to send a request for support to Mikrotik by e-mail: support@mikrotik.com
Explain what you kind of problem you have, and how you mounted them.
sebastia
Sat Dec 01, 2018 9:17 pm
You don't have any remaining npk files on them which would trigger an upgrade ?
alexbel007
Tue Aug 20, 2019 10:54 pm
First, disable packad's if they do not need yo, then select /System/Routerboard/Settings/ProtectedRouterboard set=YES, then reboot, to check it works. In Cli: /system routerboard settings set protected-routerboot=enabled
But, i guess flash is down, so yo can work on some times..
mnouri
Sat Jan 15, 2022 7:38 pm
i have this problem also. please help me
Lokamaya
Tue Sep 06, 2022 1:16 am
Me too. I'm using CRS326+24+2
Lokamaya
Tue Sep 06, 2022 1:26 am
There is nothing wrong with the disk, but it is too small. Only 16Mb.
I lost part of firewall configuration and part of static DNS.
It's seem that that part remains in the memory and lost when I reboot the MK.
holvoetn
Tue Sep 06, 2022 7:06 am
Netinstall.
Users browsing this forum: No registered users and 35 guests
