vipsss09
AirPrint doesn't work
Wed Dec 05, 2018 10:45 pm
Hello everyone
I bought new Mikrotik hAP ac lite router. Upgraded firmware to last stable version 6.43.7. Setup router with Quick Set (other default setups give same results)
connect iPhone and printer Canon MF232w (what support AirPrint) to same wireless but iPhone can't find this printer.
Printer successfull connecting to wi-fi, getting IP from same subnet, I can ping printer, but can't print with AirPrint. AirPrint on printer works fine, becouse if I connect printer to other wi-fi router I can print from iPhone
Here is wireless settings
Here is my current export
/export hide-sensitive
# jan/02/1970 00:33:32 by RouterOS 6.43.7
# software id = FA5Y-B7HN
# model = RouterBOARD 952Ui-5ac2nD
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] country=ukraine disabled=no mode=ap-bridge \
    ssid=MTIK2 wireless-protocol=802.11
set [ find default-name=wlan2 ] country=ukraine disabled=no mode=ap-bridge \
    ssid=MTIK5 wireless-protocol=802.11
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.1.3-192.168.1.254
add address-pool=dhcp disabled=no interface=bridge1 name=dhcp1
add bridge=bridge1 interface=wlan2
add bridge=bridge1 interface=wlan1
add interface=ether1 list=WAN
add address=192.168.1.1/24 interface=ether2 network=192.168.1.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.1.0/24 gateway=192.168.1.1 netmask=24
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge1 type=internal
add interface=ether1 type=external
what I should do for enable AirPrint?
sibi1979
Re: AirPrint doesn't work
Wed Jul 31, 2019 7:07 pm
Did you find a solution ?
I have the same issue where the ap's are managed by capsman.
cdiedrich
Forum Veteran
Forum Veteran
Thu Aug 01, 2019 3:00 pm
Setting multicast-helper from 'default' or 'disabled' to 'full' should solve the issue.
Additionally, check if lower rates are disabled - I had this issue more than once when el-cheapo WiFi printers only worked reliably when lower rates were re-enabled.
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
sibi1979
Thu Aug 01, 2019 4:35 pm
Hey -Chris,
Thanks for the feedback and "bonjour".
Just an additional question on the answer you gave. I didn't specify anything (I didn't thick the boxes).
Is this correct ?
Thanks and greetings,
Sibi
cdiedrich
Forum Veteran
Forum Veteran
Thu Aug 01, 2019 4:47 pm
If you didn't touch the data rates, then it should be good.
-Chris
Basel, Switzerland
Bremen, Germany
sibi1979
Thu Aug 01, 2019 5:11 pm
Thanks -Chris
Do you have some time to have a small talk about the mikrotik wireless ap and your experience with it ?
I would be very happy with it. I didn't find how to contact you directly.
Greetings,
Sibi
rumorconsumer
Sun Aug 04, 2019 7:03 am
-Chris
Can you say how exactly you get this setting to change? Can I do it through the Webfig?
sibi1979
Sun Aug 04, 2019 9:43 pm
It is under
Capsman - configurations - datapath
In the Mikrotik app
Users browsing this forum: No registered users and 14 guests
