w201
RB4011iGS+5HacQ2HnD-IN
Fri Dec 21, 2018 7:37 pm
Just received this device and stuck from start
switch it on.
No new wifi network in air....
connect pc to any port (LED shows that PC connected) - DHCP doesn't assign any address.
try to reset (3 and 5 seconds hold reset buttons after start) - no success.
I have no idea what to do...
mistry7
Re: RB4011iGS+5HacQ2HnD-IN
Fri Dec 21, 2018 9:04 pm
Try to google Winbox
w201
Fri Dec 21, 2018 9:25 pm
Netboot & update firmware with default settings helps to start it. Interesting why it doesn't work from the beginning....
pcunite
Forum Veteran
Forum Veteran
Sat Dec 22, 2018 6:35 am
The default configuration does not have DHCP service running. You'll need to use Winbox and connect via MAC address.
networkfudge
Trainer
Trainer
Sat Dec 22, 2018 8:13 am
Default-config script on shipped version doesn't set up the router fully, it applies IP address 192.168.88.1 to ETHER1 and that's about it. Use mac-winbox to connect and setup to your liking.
Alternatively you can try upgrading to latest version and resetting to factory defaults again, maybe the new version fixes the default config.
Good luck
MTCNA MTCWE MTCRE MTCINE MTCTCE UWBS UWBA
Users browsing this forum: No registered users and 14 guests
