ccr
New Routerboard - Jumper settings?
Thu Mar 08, 2007 4:20 pm
Anyone know how the jumpers need to be set in new routerboard 532?
normis
Thu Mar 08, 2007 4:31 pm
it's written on the board, select between two positions "12V" or "48V", there are no other jumpers to worry about.
ccr
Thu Mar 08, 2007 4:58 pm
Which one is for POE? JP3 or JP4? Also should the open pin be on 48V if you want to use 48V? Or should the open pin be on 48V if you want to use 12V?
Thank You
normis
Thu Mar 08, 2007 4:59 pm
there is only ONE jumper (well two, but it's a pair) on the device, 12V or 48V, the rest is automatic. You have to find out what voltage you will have, and set it to the appropriate value.
cmit
Thu Mar 08, 2007 5:49 pm
Normunds, the quick setup guide I got with the last RB532 R5 is misleading regarding the jumpers, although the title definitely states "ROUTERBOARD 500r5":
It still says:
The board has 2 jumpers for configuring input voltage range and one for disabling PoE controller.
(A bit below the middle of the first page of the quick setup guide.)
I suppose that's where the confusion comes from (I was thinking about it for some seconds, too...).
Best regards,
Christian Meis
normis
Fri Mar 09, 2007 8:32 am
where did you get that document, if it's not made yet?
cmit
Fri Mar 09, 2007 3:24 pm
Huh?
What do you mean? I pulled it from the box with the latest RB5232 (hardware r5) I got. Do you want me to fax it to you? ;-)
Best regards,
Christian Meis
normis
Fri Mar 09, 2007 3:55 pm
it was finished 30 minutes ago, and is now on the web
mip
Fri Mar 09, 2007 4:40 pm
Then CMIT probably saw the future. :?
Or someone was wrong. :oops:
https://www.youtube.com/watch?v=j7q0Y_JZMrg - the country you must visit
cmit
Fri Mar 09, 2007 4:52 pm
Hmmm, Normunds, that file (you ARE talking about http://www.routerboard.com/pdf/rb500r5mG.pdf, right?) is exactly the one I have here on paper from my latest order containing a RB532r5.
But nevermind...
If someone else needs some fortune-telling services, don't hesitate to contact me :lol: 8) ...
Best regards,
Christian Meis
normis
Mon Mar 12, 2007 8:55 am
It's very strange, as I only made the pictures like a few hours before you posted
mip
Sun Mar 18, 2007 5:28 pm
I think its time to call agent Murder now. :D :D
Users browsing this forum: akakua, ayazi and 14 guests
