Ifteequreshi
Interface ether accidently removed and I am disconnected.
Sat Jan 05, 2019 5:30 pm
Microtik router has a terrible unwanted feature that if you remove ethernet/ether interface accidently , it abruptly disconnects and loses contact with the user interface and you cannot login to set things right via Lan. The only option left is manual reset. For me the hardware reset is cumbersome as the router is fixed with a mast placed on rooftop for signal strength. In a chilly and snowy winter, with 15 inches snow on roofs, I have stopped now using this mode of internet.
Please convey if there are any other means to restore my equipment.
Regards
hgonzale
Re: Interface ether accidently removed and I am disconnected.
Mon Jan 07, 2019 11:39 am
Is not a failure, Mikrotik is a kind of router where YOU HAVE total control.
In other ways, normal router=windows, mikrotik=linux
If you do: rm -f / you will DELETE everything.. no trash can.... just you know what to do..
Ifteequreshi
Mon Jan 07, 2019 8:44 pm
Thanks for a response..
It may not respond to any terminal commands as it is totally disconnected from the windows utility and cannot communicate without Lan interface..
hgonzale
Mon Jan 07, 2019 9:28 pm
Did you try using mac address?
nbencic
Mon Jan 07, 2019 9:59 pm
Mikrotik has something called 'Safe Mode', learn how to work with it to avoid cases like these in the future and don't blame Mikrotik if you haven't done your due diligence...
nitrohydride
Mon Jan 07, 2019 10:09 pm
1.Open winbox and try to connect via MAC adress
If you haven't disabled Mac server, router discovery and WINBOX ports, you should be able to log on.
If this does not help, reset router config using Pin on LCD display (default one is 1234) then log via Winbox through MAC address and restore the previous config (unless you do not have a one, you should have at least one autobackup though( if you've updated your software in the past)).
Ifteequreshi
Mon Jan 07, 2019 10:51 pm
Received your response with thanks..
I cannot connect with Mac address too. Winbox fails to discover router and login fails, what's meant by pins on LCD, will surely use safe mode safety feature once router is reset and I m able to configure it..
But presently I m hung up and can't do anything?
BartoszP
Mon Jan 07, 2019 11:59 pm
How did you remove ethernet interface from router? Physically? Then I doubt if you can connect to your router :-)
Do you have more eth interfaces? What router it is? Configuration?
Real admins use real keyboards.
To quote or not to quote, there is the topic: viewtopic.php?f=2&t=168474
LSan83
Tue Jan 08, 2019 1:11 am
He use a CPE on the roof as a router and now he has 15 inches of snow around the CPE :D
Wrong configuration in the wrongest weather
Take a ladder, go on the roof, take down the CPE and hardware reset it. I did it with my WAP R misconfigurated too, but here in Italy there is no snow :D
Ifteequreshi
Tue Jan 08, 2019 4:49 am
Ha, ha, right sir, I surely have misconfigured this CPE and there seems no other way but to hardware reset it physically,, Difficulty lies in the fact that roof is too high and its constantly snowing. I have managed a ladder and am waiting for the courage...
Regards
Users browsing this forum: CZFan, dekiel, MarcSN, mbovenka, sindy, spr41178 and 157 guests
