MUM Europe 2020
j2sw
CHR, LACP, and VMware
Tue Jan 08, 2019 9:05 pm
I have a vmware setup where we are trying to bond multiple 10 Gig SFP+ with a Cisco Nexus. The Cisco says the port members are Individual (I). The Mikrotik bond is set on 802.3ad and this setup works on CCRs. Should I do the bonding in VMWare? I have not done this before. Thoughts?
Cha0s
Forum Veteran
Forum Veteran
Re: CHR, LACP, and VMware
Fri Jan 18, 2019 1:56 pm
You cannot bond at the CHR level.
Right now you are bonding two virtual NICs that connect to a Virtual Switch. Not Nexus.
You should do the bonding at the ESXi level.
But from there I don't know how you could get more that 10Gbps on the CHR.
I've read some posts that the VMXNET3 driver doesn't really limit the bandwidth at 10Gbps. I don't know how CHR will handle it.
cdiedrich
Forum Veteran
Forum Veteran
Fri Jan 18, 2019 4:16 pm
If your license allows, do the bonding in ESX.
If not, you'll need to dedicate NICs to your CHR instance and then follow these steps:
Create a vSwitch per NIC, allow promiscuous mode for vSwitch.
Add each dedicated NIC to the corresponding vSwitch as single uplink only.
Create port groups on that vSwitch (ideally as trunk ports - vlan 4095 in ESX)., enable promiscuous mode, mac changes and forged transmits.
Connect these vSwitches to your CHR instance.
Now you can bond from your CHR to the nexus.
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
Users browsing this forum: No registered users and 3 guests
