Rytis
WISP AP DHCP server does not work
Wed Jan 09, 2019 11:34 pm
A newbie question. I am trying to make a WISP AP with a DHCP server. I need to bridge lan port with wlan. I did a DHCP server on a bridge however it does not give an IP address to any wireless device trying to connect to AP. Could you help me out?
code:
# jan/02/1970 00:23:10 by RouterOS 6.43.8
# software id = GX9W-RIZM
# model = Metal G-52SHPacn
# serial number = 7284063BE953
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] disabled=no mode=ap-bridge name=grock ssid=\
grock wireless-protocol=802.11
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik wpa-pre-shared-key=garsistas \
wpa2-pre-shared-key=garsistas
add disabled=no interface=bridge1 name=server1
/ip hotspot profile
add bridge=bridge1 interface=grock
add interface=ether1 list=WAN
add interface=grock list=LAN
add address=10.0.1.1/24 interface=grock network=10.0.1.0
set servers=10.0.1.1
add distance=1 gateway=10.0.1.1
bramwittendorp
Re: WISP AP DHCP server does not work  [SOLVED]
Thu Jan 10, 2019 4:04 pm
Your config is incomplete if this is your full configuration.
Please use the DHCP Server setup option in Winbox or follow the guide found in the Wiki: https://wiki.mikrotik.com/wiki/Manual:IP/DHCP_Server.
You're now just running a DHCP server, without any Pool (addresses to hand out) or any other options.
Bram - MikroTik enthusiast - MTCNA / MTCRE / MTCWE / MTCIPv6E
Don't be shy, share your /export hide-sensitive and make sure to read this.
Rytis
Fri Jan 11, 2019 11:55 am
Oh thanks. got it sorted.
Users browsing this forum: No registered users and 17 guests
