MUM Europe 2020
RalfRademacher
hap lite not enough space for update
Thu Jan 10, 2019 5:28 pm
how i'm able to update if free space is 7.0MB and the update is 7.2MB?
Regards
Ralf
Pea
Re: hap lite not enough space for update
Thu Jan 10, 2019 7:33 pm
try to reboot first to clean some memory...
RalfRademacher
Thu Jan 10, 2019 9:30 pm
Done several times. No additional packages are installed. Always to few memory for the actual update.
pe1chl
Thu Jan 10, 2019 9:33 pm
Then something is corrupted.
Make a backup and an export (when you have valuable info in your config) and then do a netinstall with format, and reload the backup.
(the export is just to have a readable version of the config in case things go really bad)
sebastia
Thu Jan 10, 2019 9:36 pm
don't use the flash dir or subdirs. these are on limited flash, rest is in memory and you'll be able to write more but limited to your available mem.
Edit: see the attachment in additional post below
RalfRademacher
Thu Jan 10, 2019 10:35 pm
I don't know what you mean with dont use flash dir. Normally i click on download and install and everything is going alone
pcunite
Thu Jan 10, 2019 10:40 pm
I don't know what you mean with don't use flash directory. Normally, I click on download and install.
Under the Winbox tool, go to the "Files" menu option. Clear out anything there you're not using.
RalfRademacher
Thu Jan 10, 2019 10:44 pm
Are all the files i see in root dir only in ram drive? Because i saw an npk file there
sebastia
Fri Jan 11, 2019 12:52 pm
files under flash are in flash storage. See screenshot: the "large_file" is to big for flash sotrage (only 5m free) but it fits just fine in ramdrive part.
RalfRademacher
Fri Jan 11, 2019 2:03 pm
Thank you, and how I access the ramdrive? May i delete all the folders and files shown in your Screenshot . I mean the ones in my files folder. To get more space free.
Pea
Fri Jan 11, 2019 2:10 pm
For standard home use you can remove safely all files and folders from File List
(flash folder cannot be removed but all sub folders yes)
pe1chl
Fri Jan 11, 2019 2:20 pm
Did you already try to power it off and on instead of using "reboot"?
RalfRademacher
Fri Jan 11, 2019 2:29 pm
RalfRademacher
Fri Jan 11, 2019 2:31 pm
i think so, but i'm not sure. i will be at the installed hap lite in some hours. i did not have access all the day. only every second weekend. so thats why i asked und try all the suggestions today, when i'm in place. ;-)
sebastia
Fri Jan 11, 2019 2:45 pm
Files not within "flash" path are indeed in ramdrive.
RalfRademacher
Fri Jan 11, 2019 2:59 pm
so then i think: the npk file i see last time, was in ramdrive. i will see in two hours.
RalfRademacher
Re: hap lite not enough space for update  [SOLVED]
Mon Jan 14, 2019 2:19 pm
After deleting the folders i saw in Mikrotik-App (on android device) i still got several times the message, shown in attached image.
But finally it worked after several tries and restarts.
Users browsing this forum: Google [Bot] and 21 guests
