ColoCenter
CCR1036-8G-2S+with HIGH CPU load
Fri Jan 11, 2019 3:29 pm
I have a CCR1036-8G-2S+ acting as PPPoE server, with at the moment 170 sessions.
I see constantly one CPU having a high load. Randomly this load moves to another CPU. And it gradually increases, and then sometimes drops a bit. This is now happening for a week. See the images:
The firmware is Version 6.43.4 (stable), the routerboard version is the same.
Any ideas what might cause this?
Kindis
Re: CCR1036-8G-2S+with HIGH CPU load
Fri Jan 11, 2019 3:38 pm
Could it we scheduled script. They run in the management process if I remember correctly.
ColoCenter
Fri Jan 11, 2019 4:14 pm
I only have one script, that emails me the configuration once a week. Can't imagine that's the problem. Especially since the load shifts to different CPU's multiple times a day.
mac86
Sat Jan 12, 2019 10:39 pm
Are u doing too much nat or mangle?
Enviado desde mi Moto G (5) mediante Tapatalk
http://www.netpro-ar.com
MTINE - MTCWE - MTCRE - MTCTCE - MTCNA
Patagonia Argentina IT Consultant
Mikrotik user from V2.7.7 - Aug/2003
darioferrante
Sun Jan 13, 2019 7:06 am
Did you verify that the front LCD works correctly? Try however to disable it. Sometimes a failure on the serial interface that manages it generates a CPU overload.
Inviato dal mio HUAWEI MT7-TL10 utilizzando Tapatalk
mducharme
Trainer
Trainer
Sun Jan 13, 2019 7:14 am
We experienced this previously - a reboot appeared to clear it. I noticed it happens on our router when a user session is "stuck" - sometimes winbox disconnects but the router still thinks the user is logged in, and continues to think so until it is rebooted. I'm not sure if this is the cause or not, but it is correlated.
ColoCenter
Sun Jan 13, 2019 12:05 pm
The device doesn't do nat'ing or has any magle rules.
I rebooted the device this night, and the CPU load is gone.
I noticed that the memory usage was also gradually increasing since the CPU load appeared.
Fortunatly it's fixed for now, but not to happy i didn't find a specific cause to prevent it in the future.
CZFan
Sun Jan 13, 2019 12:37 pm
I am experiencing this on a CCR1036-12G-4S-EM, when I disable SNMP, it goes away so think it is SNMP related.
Have upgraded a couple of versions already since I originally noticed it and currently running 6.43.8 but still the same
MTCNA, MTCTCE, MTCRE & MTCINE
ColoCenter
Sun Jan 13, 2019 3:35 pm
I read about the disabling SNMP, tried it too, didn't help for me.
This is by the way what the CPU looks like after the reboot. Busy, but normal:
mducharme
Trainer
Trainer
Mon Jan 14, 2019 1:00 am
Yes this is exactly what happened to us. In our case it seemed to start when a winbox session terminated abnormally that had a large table open (I think it was the ip routes table). The user session showed as permanently active on the router (under system->users->active users) even though it had disconnected. My guess is that the management CPU was high because it was trying to redraw the table every single time there was a change, even though the user was no longer connected.
Users browsing this forum: Bing [Bot] and 43 guests
