rado3105
EU and approvment of LHG 60?
Sat Jan 12, 2019 1:12 pm
Are true rumours that EU didnt certified Mikrotik LHG 60 and wont in future?
doneware
Trainer
Trainer
Re: EU and approvment of LHG 60?
Sun Jan 13, 2019 3:16 am
the EU doesn’t certify anything. the just pass the laws, and the technology working groups create documents describing the requirements the device mst comply. testing is usually done by the vendor or an independent lab. then you put together the documentation with the results.
but each country in the eu may have different regulations, and most probably those folks at the local regulator will be the first who kight actually review the docs.
the device is available for domestic purchase inside the eu. this is only possible if the device has a CE mark, and since this is a radio-communication device, it must comply with some regulations. on the other hand, inside the eu 60ghz is still approved for p2p links - except the UK (ofcom did the right thing!) where also p2mp usage is allowed.
#TR0359
Insider
Mon Jan 14, 2019 10:44 am
I would oppose your description. Almost all over the Europe is 60 GHz fine (60-64GHz for non fix installation), but in range of 56-60GHz it in history prevailed to use for fixed licensed service. This fixed service should be removed shortly and band should be available for non licensed RLAN based on PtP, PtMP and hybrid mobile technologies. The current steps are going towards free up band 56-64GHz for MGWS but it needs some time. This time was MikroTik a step forward regulation.
Frequency microwave transvertors, design, development, manufacture
http://Pojitko.cz
honzam
Mon Jan 14, 2019 12:55 pm
From support:
Yes! We didn't manage to get CE for RBLHG-60ad therefore we can't sell it in Europe.
Best regards,
Martin Kengis
LAN, FTTx, Wireless. ISP operator
mistry7
Mon Jan 14, 2019 9:37 pm
From support:
Best regards,
Martin Kengis
Only LHG-60AD or LHGG-60AD too?
honzam
Mon Jan 14, 2019 10:54 pm
Only Lite version - LHG Lite60
mistry7
Mon Jan 14, 2019 10:58 pm
Useless Device until smaller channels available
normis
Re: EU and approvment of LHG 60?  [SOLVED]
Tue Jan 15, 2019 8:38 am
Only applies to LHG Lite60 (LHG-60ad) model with 10/100Mbps Ethernet.
Wireless Wire Dish (LHGG-60adkit) with 1Gbps port is certified for use in Europe.
tetecko
Thu Feb 14, 2019 12:18 pm
Will Mikrotik work on EU Certification again? Or is this device lost for ever?
Users browsing this forum: Bing [Bot] and 15 guests
