becs
SwOS version 2.9 released!
Mon Jan 14, 2019 5:32 pm
http://www.mikrotik.com/download
What's new in v2.9:
*) CRS326 & CRS328 & CRS317: make sure that RSTP BPDU packets are always untagged;
*) CRS328-4C-20S-4S+: make 1G fiber SFP modules work;
*) CRS328-4C-20S-4S+: fixed PSU numbering;
*) CRS328-4C-20S-4S+: light up fault LED on fan failure;
*) CRS328-4C-20S-4S+: make fiber optic SFP modules work;
*) CRS328-24P-4S+: light up fault LED on fan failure;
*) CRS317: make fault led light up on fan failure;
*) CSS106: fixed rx/tx unicast packet counter;
*) CSS106: make low speed ports not block high speed port traffic;
*) make forced ethernet speeds work;
*) added ability to block unknown multicast packets on port;
*) fixed reporting of secondary FAN speeds;
*) fixed problem where sometimes all VLANs or ACLs were not saved;
*) fixed DHCP snooping to forward packets when they are bigger than 300 bytes;
*) made DHCP snooping remove DHCP agent information option from DHCP replies;
*) made DHCP snooping respect port isolation;
*) fixed SFP module wrong info problem;
*) made LACP work together with RSTP;
*) made upgrading over serial work;
becs
Re: SwOS version 2.9 released!
Mon Jan 14, 2019 5:46 pm
Known issue:
*) CRS328-24P-4S+ upgrade from the SwOS does not work in this version
Upgrade using SwOS firmware file "swos-css328p-2.9.bin" from https://mikrotik.com/download should be used instead.
RobertF
Mon Jan 14, 2019 6:20 pm
Hello becs,
It is really frustrating. I copied my posting from v 2.8...
German IPTV (Entertain TV, MR401/201) still not working at all with this SwOS version (CSS326). No IGMP v3.
Picture freezes after a few seconds.
Independent of setting IGMP snooping.
Using together with FritzBox 7590.
Latest usable version is 2.4 (with packet flood on all ports due to missing IGMP)
Please implement IGMP v3 in next update.
Thanks.
Robert
eddieb
Tue Jan 15, 2019 8:21 am
Updated all my RB260GS(CSS106-5G-1S) to 2.9 without any issues.
Running 6.45.6 (stable) on :
CCR1009-8G-1S (2x ipsec/l2tp site-to-site, ipsec/l2tp roadwarrior, dhcpd, dns), CRS125-24G-1S, RB1100, RB962UiGS-5HacT2HnT (10pc), RB931-2nD, RB951, RB750GL ,RB2011UAS-RM, CHR running dude (CHR running in VirtualBox on OSX)
abrodkin
Tue Jan 15, 2019 9:02 am
Hello becs,
Thanks.
Robert
So given this comment and no mention of IGMP in official changelog we may safely conclude IGMP is not yet fixed.
God job Mikrotik team!
I'm staying on v2.4 until IGMP is fixed.
storp
Tue Jan 15, 2019 11:06 am
Any fixes for the issues with RX overruns and RX FCS errors included in this release?
Njumaen
Tue Jan 15, 2019 3:03 pm
Where can I find the 2.8 files? I want to check if some strange behaviour of my rb260gsp is related to the update
biatche
Tue Jan 15, 2019 3:33 pm
I've been patient version after version since 2.3
Each time I upgrade, there's endless issues. Resetting resets to 2.0 and then I'd have to pray and hope it'd upgrade to the latest with my settings intact, and then having to restore again.
This is on CSS326. Can mikrotik somehow allow RouterOS to be installed on CSS326 because honestly, SwOS is complete garbage. Yes I'm annoyed. You already have a good 1 year to fix the product and its still garbage.
kosyot
Wed Jan 16, 2019 1:37 pm
Hi all,
Is there prove of bugs fixing appeared @2.8 for CRS317-1G-16S+ ?
Especial freezing of switch, which forced us all to downgrade to 2.7?
fernaandogarcia
Wed Jan 16, 2019 2:21 pm
I have a CRS317 that in version 2.8 often crashed the management, it was very slow access. The traffic flowed normal but the management looked strange.
This issue has been resolved with version 2.9.
becs
Wed Jan 16, 2019 2:35 pm
@RobertF and @abrodkin
SwOS has supported IGMP v1,v2,v3 since v2.5, also many issues have been addressed since then and now in v2.9 there is an additional port option to disable unknown multicast flooding. We are not aware of common IGMP Snooping problems anymore.
If you experience problems using IGMP Snooping in SwOS, please, write to MikroTik support so your cases can be individually investigated.
@storp
Yes, the v2.9 contains the latest improvements for 10G -> 1G performance issues and they can help regarding Rx Overruns in other setups as well.
@Njumaen
SwOS v2.8 for RB260:
https://download.mikrotik.com/swos2/css ... 1s-2.8.bin
k6ccc
Wed Jan 16, 2019 6:29 pm
Updated my CSS106-5G-1S from 2.8 and all appears to be working. However, after the upgrade, this is what the Upgrade page says:
Firmware
Current Installed Version	2.9 (built at Mon Jan 07 2019 03:04:37 GMT-0800 (GMT-08:00))
Latest Available Version	2.9 (built at Mon Jan 14 2019 02:29:12 GMT-0800 (GMT-08:00))
At the bottom, it says that there is an upgrade available. Tried the upgrade again and it still comes up with the 07 January version and not the 14 January version.
I have not upgraded the other three switches yet.
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Jim
Cha0s
Forum Veteran
Forum Veteran
Wed Jan 16, 2019 8:19 pm
Same here
Cha0s
Forum Veteran
Forum Veteran
Thu Jan 17, 2019 2:47 am
Upgrading from 2.8 to 2.9 on a CSS106-5G-1S causes severe traffic drop between 1G ports and 100Mbit ports. It's random from 0 to 40Mbps.
Reverting back to 2.8 traffic increased back to steady 100Mbps.
biatche
Thu Jan 17, 2019 6:19 am
I can't any longer access webui on vlan management port... coming from 2.7..... do i need to reset settings?.... what settings are required to be able to access webui from vlan99?
i did set the management port on the system page.
becs
Thu Jan 17, 2019 8:27 am
Are there any errors in interface stats when using v2.8 or v2.9?
Njumaen
Thu Jan 17, 2019 10:01 am
The issues (random video playback lags -wirered- or loosing wireless connection) vanished with downgrade to 2.8 of my two rb260gsp.
Before downgrading I looked for transmission errors, but none were shown.
Ralf.
Cha0s
Forum Veteran
Forum Veteran
Thu Jan 17, 2019 12:40 pm
No errors at all on any port.
kosyot
Fri Jan 18, 2019 11:00 am
Any with CRS317 & 2.9 ?
indnti
Sun Jan 20, 2019 12:37 am
[quote=kosyot post_id=709676 time=1547802033 user_id=136437]
[/quote]
Yes. Works.
rofrigo2
Sun Jan 20, 2019 1:28 am
As far as I understood from some posts above, the multicast issues are not fixed?
Shall I stay at 2.4 then?
kosyot
Mon Jan 21, 2019 10:18 am
Yes. Works.
Same story :(
CRS317-1G-16S+ with SwOS 2.9:
  • connection to the switch stopped every 3-5 min (no ping, no web, serial - working)
  • leds on ports not blinking - all ON
  • after hour on stopped all traffic thru switch - must be rebooted by serial console
back to last working version on SwOS - 2.7.
very disappointed indeed again...
zainabiden
Tue Jan 22, 2019 12:39 pm
Agree
smash102
Tue Jan 22, 2019 9:11 pm
Upgraded about 4 of our RB260 series switches (2 of each) to this code.
The ACL page will not SAVE any changes.
Random bandwidth.
Reverting back to 2.8 code.
I do not recommend upgrading to 2.9.
storp
Wed Jan 23, 2019 10:31 am
Upgraded two CSS326 from 2.7 and it worked fine. Still having RX overruns.
kosyot
Wed Jan 23, 2019 11:13 am
I can confirm that CSS326 working fine with 2.9 and there is still RX overruns.
Have no problem with CSS106 too, can't say same for CRS317....
usedtobegood
Wed Jan 23, 2019 12:28 pm
reading that no IGMP (Snooping) Problems are know in the latest 2.9 Firmware release, made me a bit angry...
I currently use several Dell (eg. Powerconnect 7024, 6248) switches and for the Office (because it is silent) a Mikrotik CSS326-24G-2S+RM.
There a dozen or so VLANs configured but only VLAN30 is used for IGMP Snooping, which is needed for the IPTV Product from German Telekom (currently i am still using the old T-Entertain Platform, in a couple of weeks this platform will be shut down by DTAG and only the newer EntertainTV platform is still usable - we'll see whats still working then...)
But making a Point: VLAN 30 with IGMP Snooping activatet works great with the Dell switches. With the IPTV Receivers zapping is a pleasure, you can see (or better you can't) the switch from unicast to broadcast, which occours after a couple of seconds from the Platform, a smooth transition.
With the Mikrotik there is a 5-10 second gap when the unicast switches to broadcast. In these Seconds the Picture freezes, the IGMP group is (too slowly) joined, and after that everyhing is working fine again.
Im am very disappointed that Mikrotik seems to be very inexperienced in the whole IGMP subject. Even the cheapest IGMPv3 Snooping compatible Switches from Netgear (GS105E) work way better in this szenario than the 'rather' expensive and theoretically way more sophisticated Mikrotik Switch :-(
Hope this will be solved soon - but since I bought the switch (back last year) it almost layd unused in its box waiting to be usable :-(
Cheers
UsedToBeGood
Deantwo
Wed Jan 23, 2019 1:35 pm
As @becs just said;
Send an email to support@mikrotik.com with details of the issue, and then they will investigate your case.
Continuing to complain here doesn't really help anyone.
I wish my FTP was FTL.
RobertF
Wed Jan 23, 2019 7:14 pm
@becs Thanks for the offer to solve the IGMP issue via direct support.
I already have been in contact with support more than one year ago using version 2.6. Answer:
SwOS does not support IGMP v3 and there is no fix until v3 is implemented.
IGMP v3 is on the feature list and it will not be implemented in near future.
IGMP changes are not mentioned in release notes for 2.7, 2.8 or 2.9 except this one:
"CSS106: forward IGMP query messages even when IGMP snooping is disabled;"
@Deantwo: I complain about the German IPTV IGMP issue in the forum to save time of other CSS326 users.
Cheers
Robert
casey42387
Mon Jan 28, 2019 7:04 am
Anyone have a download link to previous versions of SwOS for the CRS305-1G-4S+?
I'm trying to do some loop testing and going from 2.8.x to 2.9 nuked the link status lights and internal link status for SFP+ ports (e.g. SFP1 to SFP2).
riks
Mon Jan 28, 2019 10:49 am
i have the same problem i can not update to version 2.9 from 14 jan , also after a few hours the fans are spinning up and down and the fault led is burning current version of switch os is 2.9 7 jan switch CRS317-1G-16S+RM
nicoguido
Mon Jan 28, 2019 11:14 pm
I did some tests on a CRS317 with switchos 2.9 (I usually use routeros).
The test wasn't long, because straight after starting with switchos, some iot (netatmo weather station) and the logitech harmony hub were unreachable.
I think harmony hubs are using zeroconf or mDNS.
I played with igmp parameters (vlans and system panels), but nothing went back to normal.
So I'm back to routeros. At least it works (if igmp snooping is disabled on the bridge. With it enabled, it works partially, with strange behaviors).
I'll try the next release.
quentin
Mon Feb 11, 2019 9:34 am
Same thing happened to me when upgrading from 2.8 to 2.9; the switch that was previously accessible is suddenly not responding to ARP requests (and therefore the web UI is inaccessible). It's still sending out MNDP packets, though - I see it in the Neighbors list on all my RouterOS devices.
ymw
Tue Feb 12, 2019 9:01 am
After upgrading my CSS326-24P-4S+RM to OS 2.9, my sfp+ ports stopped working with my direct attach 10G transceivers. I have two pairs of those direct attach copper transceivers that were working fine before, now both are not recognized. One pair is a Cisco SFP-H10GB-CU3M. The other is an Optech.The sfp+ ports are confirmed to be still workng working OK with the new OS using some Finisar opto trasceivers. Any suggestion on how to proceed? I was connecting to the sfp+ ports on a CRS328-24P-4S+RM.
illussion
Tue Feb 12, 2019 10:56 am
Where the button "Reset Counters" in Errors page RB260GSP? What with Rx Overruns and TX pauses ?
8cqv
Wed Feb 27, 2019 7:19 am
Fan control still completely broken for CRS328.
SwOS is a bit of a joke isn’t it really? How can fundamental problems not be addressed, especially with so much delay between releases?
Siorg
Thu Mar 07, 2019 4:48 pm
Upgrading to 2.9 caused mikrotik SplusDA0003 direct link cable failure. No link anymore.
chechito
Fri Mar 08, 2019 10:36 pm
some body have the 2.8 version for RB260GSP ??
chechito
Fri Mar 08, 2019 10:37 pm
exactly the same problem on RB260GSP
some body have the 2.8 version for this device?
chechito
Fri Mar 08, 2019 10:56 pm
@storp
@Njumaen
im trying to downgrade a rb260gsp CSS106-1G-4P-1S with this file but switch cease to operate and reboot is needed to get it online again but still on 2.9
Paternot
Long time Member
Long time Member
Fri Mar 08, 2019 11:32 pm
@storp
@Njumaen
Do You have backups? If I remember correctly, when You reset a switch to factory default it goes back to the original firmware too.
chechito
Sat Mar 09, 2019 1:26 am
@storp
@Njumaen
thx a lot
i had to reset to factory (2.7) then i was able to upgrade to 2.8
chechito
Sat Mar 09, 2019 1:33 am
even on 2.8 the problem exists in 2.9 just gets worse
conecting rb260 to main router gigabit full duplex
testing in 2,7 if a client on a downlink port of the switch is at 100m full duplex i cant surpas 75-85mbps of download (upload test 95mbps ok) on speedtest, switching the client to 1g full duplex gets 150mbps on speedtest (that was the internet connection available)
testing in 2,8 gets 25-40 mbps of download on speedtest
testing on 2.9 gets 5-10 mbps of download on speedtest
the funny (not so funny) thing is that because of this issue we tested a CRS 326-328 with routeros or sw-os and suffer from the same issue, (25-40 mbps of download)
looks like a common behavior on mikrotik switch's
interprime
Sun Mar 17, 2019 9:45 pm
same problem
andycher
Wed Mar 27, 2019 11:58 am
CSS326-24G-2S+
1Gbit SFP module does not work in auto mode.
Tobei
Thu Apr 04, 2019 11:17 pm
  • Board Name: CSS106-1G-4P-1S
  • Current Installed Version 2.9 (built at Mon Jan 07 2019 12:04:37 GMT+0100
ACL functionality is broken! On Version 2.8 it is working, so please fix this soon!
Regards Tobias
heviejob
Sat Apr 13, 2019 12:26 am
Ralf.
I had the same issue after upgrading to 2.9. The experience was so bad It cost me, several customers. I downgraded to 2.8 and went back to normal. I had checked for any errors but there were none.
It made me hard reset core CCR and reconfigured it but still, slow connections persisted. Only a downgrade sorted it out.
anav
Sun Apr 21, 2019 4:58 pm
Thats funny as version 2.9 is the only version I will run as its more stable and works compared to the older ones. To be fair, this thing tries ones patience but once setup properly it keeps on working.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
mjpswe
Thu May 02, 2019 11:17 pm
Have a CRS309-1G-8S+ runnig SwOS 2.9 built on 7 Jan, it says there is an upgrade from 21 Feb I click on upgrade and reboot it restart but dont upgrade.
Can I download the file anywhere and do a manual upgrade?
lygstate
Sat May 04, 2019 2:03 pm
After upgrading CRS309-1G-8S+ to swos 2.9, the 192.168.88.1 can not be access any more
krdx
Sat May 25, 2019 4:48 pm
CSS106-1G-4P-1S with 2.7 firmware out of the box.
Then proceeded to upgrade firmware via the web gui manually [swos-css106-2.9.bin]
Switch is no longer accessible via 192.168.88.1. Does not respond to arp.. It appears in Mikrotik neighbour discovery with firmware 2.7, its uptime started counting from 0 after the upgrade.
Will a power reset bring it back to life? Will need to visit a remote location.
RobertF
Tue May 28, 2019 7:07 pm
Hello @becs,
I opened a support ticked as you requested and the last response was on Jan 29th.
I provided wireshark logs and received this response
Seems that the cause of this problem is clear now. ...
I requested a beta fw and did not receive anything during the last 4 Months...
Is anybody working on the German IPTV IGMP issue?
When will the issue be fixed?
RobertF
johanvdw
Mon Jun 03, 2019 11:01 pm
Using SWOS 2.9 after a while, we often have a fan which constantly spins up and down, leading to an irritating noise.
Are there any options we can use to mitigate this? On routeros we don't have this issue (but I prefer the simple configuration on swos).
Device is the CRS328-24P-4S+
fatzgenfatz
Wed Jun 05, 2019 12:06 am
Have you been able to revive your switch? Is an upgrade to 2.9 possible?
I'm a bit anxious to install 2.9 on my CSS106-1G-4P-1S.
f.
theBLBDan
Tue Jun 11, 2019 8:47 pm
Ditto!! I've been stuck in the mud for months now.
https://i.imgur.com/sndoI9B.png
http://192.168.88.1/index.html
https://i.imgur.com/4ucKNWP.png
alfred998
Thu Jun 27, 2019 1:58 pm
CSS326
Same issue as a few others here
Current Installed Version	2.9 (built at Mon Jan 07 2019 12:05:03 GMT+0100 (Central European Standard Time))
Latest Available Version	2.9 (built at Mon Jan 14 2019 07:49:36 GMT+0100 (Central European Standard Time))
https://imgur.com/n6OJHu7
Tried manual upgrade also
DzheksonLambert
Mon Jul 01, 2019 9:26 am
Can I update my switch or I need to phone for specialist???
alfred998
Thu Jul 04, 2019 1:17 pm
It's quite a simple procedure and takes 30 seconds. Still you should read carefully what has changed between your version and the new one, and if there are any known bugs that might be a problem to you in the new version.
rua
Fri Jul 05, 2019 11:49 pm
how did you upgrade to ver 2.9? i can not find crs309 in download page?
MTCNA, MTCRE
Copenhagen, Denmark
Consulting, building and managing networks.
scottg0
Sat Jul 06, 2019 12:58 am
I had this same problem and wrote to support and got the answer to fix it. You have to switch back to router OS, install the latest routerOS version which updates the fan controller firmware, then switch back to switchOS and the fan oscillations will stop.
os62
Mon Jul 15, 2019 6:21 pm
Dear Sirs,
I run a CRS317-1G-16S+ with SwOS 2.9.
It's a great switch, however:
Getting 1Gbase-T sfp modules to recognize link up is a pain. At every reboot, links on such sfp modules are dropped and stay down.
The only way to get links back up again, that I know of, is to configure them no No Autonegotion, No Flow control, reboot the SwOS, see links still being down, then click them back to Autonegotion and Flow control. This is a bit of a discomfort, since that has to be done every time the switch is (re)booted, regardless of power outage or software upgrades.
Leaving Speed configured to 1G shows links are up, alas, no traffic will flow on that setting.
Said does not happen with 10Gbase-T sfp+'s, nor with 10Gbase opticals or DACs.
Anyone with further information on the matter - ie. how to get this run a bit smoothier?
Thank you.
nonamed108
Wed Jul 17, 2019 9:24 am
Did you have address acquisition in the system tab set to "DHCP with fallback" (think it might be default)? I noticed that after upgrading to 2.9 my switch pulled a DHCP address which prevented the 192.168.88.1 address to stop working. I would check if a lease was assigned to your switch as I was able to access it once I saw the ip it was assigned. The original default should have been set to "static" most likely as this setting now appears to properly work.
BrunoDAlessio
Mon Aug 05, 2019 9:19 pm
I can confirm a trouble with SFT interfaces in SwOS 2.9
I have a CSS326-24G-2S+ switch with two SFP copper modules inserted in both the SFP slot.
Both the adapters are similar to the MikroTik S-RJ01 but cheaper (about 17€ on Amazon), they are 10-100-1000M Ethernet with auto-negotiation.
They are of brand 6Com, model 6C-SFP-T:
http://www.6comgiga.com/products_list/pmcId=99.html
and they worked great with 2.8 version of SwOS.
A couple of months ago I upgraded the SwOS to 2.9 version and I didn't note any trouble.
Last week I had a blackout and the switch rebooted. From this time the SFP modules worked only at 1G and I couldn't get them to work at 100M.
The trick of os62 posted here was unsuccessful in my case, so I tried to downgrade the SwOS to 2.8 version and magically the adapters worked fine again.
I don't know if the same issue occurs with Mikrotik S-RJ01 SFP module because I haven't it.
Yesterday I wrote to MikroTik support reporting this trouble and hoping to fix it in the next SwOS version
os62
Mon Aug 19, 2019 6:32 pm
I tried mr. D'Alessio's suggestion of downgrading to 2.8.
That, instead of improving matters, started to flap all ports on the switch.
So back to 2.9, and reboot-loss of 1000Base-T sfp modules on all power outages and reboots. Unfortunately.
I sure do hope this'll be fixed.
kosyot
Mon Aug 19, 2019 8:50 pm
You must read more above:
only SwOS 2.7 working like a charm
BrunoDAlessio
Sun Sep 01, 2019 11:32 pm
Hi os62,
I'm sorry for the trouble downgrading the SwOS firmware in your switch.
Maybe the file you used was not the right one for your device? ...I don't know...
In every case my switch is the "CSS326-24G-2S+" and it is different from your model (CRS317-1G-16S+). Perhaps the behavior changes for this reason.
Just as a simple tip I wish to tell you that in the MikroTik download page:
I was not able to find the 2.8 version, so I solved by changing the link of the 2.9 version in the row of my device. The link is:
https://download.mikrotik.com/swos2/css ... 26-2.9.bin
and I changed it in:
https://download.mikrotik.com/swos2/css ... 26-2.8.bin
(the link works changing the "9" to "7" also).
Using the same rule, the 2.8 version for your switch should be
https://download.mikrotik.com/swos2/css ... 17-2.8.bin .
Did you use this link?
I hope you'll solve every problem in the best way.
Best regards,
Bruno
n0xlf
Wed Sep 04, 2019 10:01 am
My new CRS312 shipped with 2.10 which does not work with 1G SFPs at all. I've been talking to support a bit with this being my latest reply (there is more conversation before about it not establishing a 1G link to my UBNT ERP):
I did more testing with the following and found the same results for all:
-10Gtek SFP+ DAC
-10Gtek 1G SFP MM fiber
-Cisco 1G SFP MM fiber
-UBNT 1G SFP MM fiber
-addon 10G SFP+ MM fiber
-Dell 1G SFP MM fiiber
-ipolex 1G SFP MM fiber
My Ubiquiti Edgerouter Pro will link to anything else I throw at, but even so I forced the port to 1000/full/no auto negotiation using ethtool.
The CRS312 will not link to anything at 1G with any of the above SFPs when it auto negotiation mode, and will always establish a simplex link when forced to 1G but obviously traffic only in one direction doesn't help me much.
As mentioned before, the CRS312 does link successfully at 10G with an EdgeSwitch, or at least it did until the SwOS version 2.10 (dated 09/03) came out. Now to even get that to link I have to reboot with it auto negotiating, force it to 1G, and then set it back to auto negotiation again. That will finally bring up the link. Additionally, all of the ports of the switch drop off entirely when I make any changes to the SFP ports.
This thread mentions at least some of what I'm dealing with: viewtopic.php?f=21&t=144031
I think the SwOS firmware is just a disaster at the moment when it comes to SFP slots. BTW, I tried RouterOS and it was no better.
I doubt there is much you or I can do until these issues evolve more, but I would ask if there is anything I can do to help the development of this firmware, please let me know.
kosyot
Wed Sep 04, 2019 12:55 pm
The question is when 2.10 will come on public, to check what they did for last 10 months?
chechito
Wed Sep 04, 2019 6:29 pm
-10Gtek SFP+ DAC
On the specifics of you issue, have you tried setting 1g full duplex manually on ubiquiti device?
On general
CRS312 is a very new device
My advice, wait at least 2 months to put it in a production workload, takes time to get all the new discovered issues and fix them, do not depend on that
n0xlf
Wed Sep 04, 2019 6:39 pm
Ubiquiti is a bit odd when trying to force it to 1G - When done through the web interface you'll see "1000 is not valid for Copper port" because it's a shared port but I did force it on the back end with ethtool. Unfortunately it didn't make a difference.
I was waiting for the CRS312 for a long time and was very quick to jump on it when it was released, so I understand paying the price for that a bit. They are bound to figure this one out because it's so easy to reproduce.
McSee
Thu Sep 05, 2019 4:33 am
2.10 is already available for upgrade on devices.
What's new in v2.10:
*) do not ignore RSTP port state when forwarding DHCP, PPPoE or IGMP snooped packets;
*) IGMP snooping: send out IGMPv3 queries by default;
*) IGMP snooping: handle IGMPv3 leaves much better;
*) IGMP snooping: handle dropped IGMP reports much better;
*) CRS309, CRS312, CRS317, CRS326Q: fixed ACL matching by ip destination port;
*) CRS309, CRS312, CRS317, CRS326Q: fixed ICMP TTL packet switching;
*) CRS305, CSS106: make ACL work again;
*) CSS106: improve packet forwarding between different speed interfaces;
*) restart RSTP on LACP ports that got disbundled;
*) made disabling of flow-control work as expected;
*) do not account rx-overflows twice in SNMP ifInErrors;
*) CRS328-24P-4S+: make auto upgrade work;
*) CRS326Q: fixed vlan configuration on ports sfp22-sfp24 & qsfp+1.1-qsfp+2.4;
*) added support for unicode symbols in labels;
*) make DHCP & PPPoE snooping work correctly on port trunks;
*) made port lock filter out packets with unknown source addresses;
*) CRS309: make VLAN configuration work;
*) fixed problem where disabled autonegotiation on some SFP modules
became effective only after reboot;
*) CRS305, CRS326, CRS328: improved switch-chip resource allocation;
os62
Thu Sep 05, 2019 1:33 pm
Hi os62,
Dear Bruno,
yes, I figured out how to alter the download link and got the correct firmware, so it wasn't that..
Oddly enough, I found out (on CRS317 and SwOS 2.9) that toggling 1000Base-T SFPs Off-enabled and Enabled on Link pane, make them work stable forced at 1 Gbit/s speed - even over reboots.
Haven't have had the guts to try if it'd work over power outage, probably will try that this evening. I'm pretty sure switching OSs and we'd be back on disable/enable again.
becs
Thu Sep 05, 2019 3:27 pm
Version 2.10 of SwOS has been released:
viewtopic.php?f=21&t=151881
Users browsing this forum: No registered users and 7 guests
