Arcee
Tower Cabling Choice?
Mon Jan 14, 2019 8:57 pm
All variables considered... Outdoor elements (Sun/Head/Cold/Rain), what are you guys using for your tower cabling?
This is particularly for a new tower install. I need to this cable to last long... maybe CAT6a?
Thoughts?
R1CH
Forum Veteran
Forum Veteran
Re: Tower Cabling Choice?
Mon Jan 14, 2019 10:57 pm
Shielding / UV resistance is probably more important for outdoor use. Ubiquiti have a product which looks good: https://www.ui.com/accessories/toughcable/
mistry7
Mon Jan 14, 2019 11:04 pm
How long is your cable way?
vecernik87
Long time Member
Long time Member
Tue Jan 15, 2019 4:50 am
1) category has nothing to do with quality of the jacket. Look for outdoor-rated cables.
2) if you plan to use POE over long cable, make sure that you choose cable with pure copper wires (often there are copper-aluminium wires) and as much of them as possible (lower AWG = more wires in each strand = less resistance = better for POE)
3) if there are some other antennas or other sources of interference, make sure you use shielded cable. This is even more important if you run it all the way next to 230V power cable.
4) Conduit and plastic covers can shield your cable from sun and rain and prolong its life.
Arcee
Tue Jan 15, 2019 5:39 am
250ft?
Sent from my Pixel 2 using Tapatalk
Users browsing this forum: Bing [Bot] and 56 guests
