cosmos
[SOLVED] CHR VM 6.41.2 & QEMU agent issues on proxmox 5.3
Tue Jan 15, 2019 9:23 am
I've been running a CHR VM version 6.41.2 for some time now. Since I've been having problems with shutting the VM down from the hypervisor, I've been searching for a way to notify the VM.
This could be accomplished if the VM supported the QEMU Agent. According to https://wiki.mikrotik.com/wiki/Manual:CHR#KVM, CHR VMs do support this feature. However even though my hypervisor (Proxmox 5.3) does support it as well and I've enabled the "Qemu agent" in the respective VM settings, proxmox still can not connect to the Qemu agent on CHR: from the proxmox gui, it is noted that "Guest Agent is not running".
Should I enable the Qemu agent in the CHR VM in some way?
Do note, that trying to use the command to enable chr.provision-agent (which I don't know what it is for, presumably opening a TCP/IP channel for comms? ) works, but then gives an error when I try to bring the VM up...
cosmos
Re: CHR VM 6.41.2 & QEMU agent issues on proxmox 5.3
Mon Jan 21, 2019 11:27 pm
(bump) Someone?
cosmos
Wed Mar 13, 2019 11:08 am
It's a bit disconcerning that a question as simple as this one does not get a(ny) answer.
Again, does the CHR include qemu or not? In all tests I've made, it seems as though there is no qemu agent running in the CHR VM... Can someone shed some light here?
cosmos
Re: CHR VM 6.41.2 & QEMU agent issues on proxmox 5.3  [SOLVED]
Wed Mar 13, 2019 11:37 am
Answering my own question, 6.41.2 did not support qemu from the looks of it. 6.44 seems to be ok.
Lifz
Re: [SOLVED] CHR VM 6.41.2 & QEMU agent issues on proxmox 5.3
Wed Mar 13, 2019 11:47 am
What's new in 6.42 (2018-Apr-13 11:03):
*) chr - added "qemu-guest-agent" and "virtio-scsi" driver on KVM installations;
Please upgrade your CHR RouterOS.
plastilin
Sun May 21, 2023 1:16 pm
Installed the latest Proxmox 7.4 and CHR 7.9. The guest agent is not running. How to fix it? In the Proxmox interface, information about the guest agent: Guest Agent not running.
I do: qm agent 3000 ping
I get the result: QEMU guest agent is not running
In Proxmox 6.4, the guest agent works.
Lifz
Mon May 22, 2023 8:24 am
By default Quemu Guest agent is disabled, you can enable it in VM options under Quemu Agent.
Note: Default CPU type should be selected Default (in our case it is Default (kvm64)).
plastilin
Tue May 23, 2023 11:08 am
The guest agent in the Options section of the virtual machine is enabled. But there is no connection with him.
agent: 1
balloon: 0
boot: order=scsi0
cores: 1
cpu: host
machine: q35
memory: 320
meta: creation-qemu=7.2.0,ctime=1684484965
net0: virtio=76:6E:53:F5:63:43,bridge=vmbr0
numa: 1
onboot: 1
ostype: l26
parent: auto-daily-23052257
scsi0: data:vm-3000-disk-0,iothread=1,size=128M
scsihw: virtio-scsi-single
smbios1: uuid=5fa9559f-f381-4803-9ab6-3badd22664b0
sockets: 2
vmgenid: c7310125-9d1b-4797-badc-519fdad4db61
Lifz
Tue May 23, 2023 11:32 am
Did you change your CPU type to Default (kvm64)?
plastilin
Tue May 23, 2023 11:58 am
After changing the CPU to kvm64, the information appeared
agent: 1
balloon: 0
boot: order=scsi0
cores: 1
cpu: kvm64
machine: q35
memory: 320
numa: 1
onboot: 1
ostype: l26
sockets: 2
But not all information is displayed. Also a question. Will the agent only work when using a kvm64 processor? Server installed: Intel(R) Xeon(R) CPU E5-2690
Users browsing this forum: No registered users and 4 guests
