MUM Europe 2020
bastys
SXTG ac with L4 licence
Tue Jan 15, 2019 1:01 pm
why did you stop supplying SXTG ac with L4 license? It was a good device for a 25° sector?
THX
normis
Re: SXTG ac with L4 licence
Tue Jan 15, 2019 3:41 pm
Here is the sector model: https://mikrotik.com/product/RBSXTG-5HPnD-SAr2
The device you refer to, is no longer in production, so we didn't stop supplying L4 license ... we stopped making it. The new device is https://mikrotik.com/product/sxtsq_5_ac
bastys
Tue Jan 15, 2019 11:47 pm
The SA has a 90 ° angle and a lot of noise in the city.
pity :(
mistry7
Wed Jan 16, 2019 12:07 am
If you want HQ by RF Elements 30° Horn and Use M11g with AC Module in TPA-RBC
Don’t buy ARM Hardware it is BETA Stadium, don’t work as aspected!
bastys
Wed Jan 16, 2019 12:42 am
Horn is not economically profitable for some locations.
Interesting, it seems to me that after the latest updates the army works well.
mistry7
Wed Jan 16, 2019 1:47 am
No it doesn’t....
Vasilije
Tue Aug 27, 2019 2:58 pm
@mistry7 Hi, can you tell me what is better combination for HORN antena:
RouterBOARD 922UAGS-5HPacD
or
RouterBOARD RBM11G with R11e-5HacD
I see that on a 2nd combination the CPU and RAM is much better but the output power in MW are only 500.
Do you have some suggestion for the mini PCI card?
mistry7
Tue Aug 27, 2019 3:41 pm
or
How much dBm are allowed to you?
WE use M11g and hopefully we are able to upgrade to 802.11ax with upgrading PCIE Module only....
Vasilije
Tue Aug 27, 2019 4:35 pm
or
The max is 1w or 30 dBm
I wona use it as a ptm
mistry7
Tue Aug 27, 2019 4:43 pm
or
So with a sector antenna (Gain between 15 and 20dBi) it is allowed to you to do
10-15dBm out of your wireless Module. 15dBm are 32mW, so why you need more then 500mW Module Power?
Vasilije
Tue Aug 27, 2019 5:06 pm
or
And what you sugest its bether to go with rmb11g.
mistry7
Tue Aug 27, 2019 7:31 pm
Yes
Vasilije
Tue Aug 27, 2019 7:35 pm
or
When u switch to Ax standard, do i need to change also a hardware at my clients or it will remain same and only the software will be upgraded?
normis
Thu Aug 29, 2019 2:07 pm
You will need all new wireless interfaces for full 802.11ax support.
Users browsing this forum: No registered users and 38 guests
