BostjanC
How to use Mikrotik router as a “switch”?
Tue Jan 15, 2019 9:05 pm
I want to use Mikrotik router as a “switch”.
I’ve tried several instructions I’ve found on the net, but at the end I had to reset the Mikrotik router several times so far (by holding down the reset button while powering it on).
I have one existing router xy brand with IP 192.168.1.1, which is also a gateway. It is also a DHCP on my 192.168.1.1/24 network.
I just want this MT router to have an IP 192.168.1.2 and to be a “switch” (bridge?) to other wired and wireless devices connected to it – so that they can talk to any device on my 192.168.1.1/24 network.
How to do that and not to reset it?
Thanks.
fbuster
Re: How to use Mikrotik router as a “switch”?
Tue Jan 15, 2019 9:27 pm
depending on your model it can be a 4port or 5port switch
Here's a sample config:
add name="My bridge"
set [ find default-name=ether1 ] name=ether1-To-modem
set [ find default-name=ether3 ] master-port=ether2
set [ find default-name=ether4 ] master-port=ether2
set [ find default-name=ether5 ] master-port=ether2
add bridge="My bridge" interface=ether1-To-modem
add bridge="My bridge" interface=ether2
BostjanC
Tue Jan 15, 2019 9:33 pm
It is hAP ac².
Your code just puts all interfaces to the bridge.
What about IP?
fbuster
Tue Jan 15, 2019 9:41 pm
Its a switch now , it doesnt need ip.
switching is layer 2 (mac)
BostjanC
Tue Jan 15, 2019 9:51 pm
What about DHCP?
If I want to update it, it says ERROR: could not resolve dns name.
zandhaas
Tue Jan 15, 2019 11:21 pm
I have a HAP ac2 and used the procedure described in the below post to configure it as an AP.
viewtopic.php?f=13&t=143446
baragoon
Wed Jan 16, 2019 8:24 am
It is hAP ac².
What about IP?
add dhcp client to bridge
mkx
Wed Jan 16, 2019 4:18 pm
Cook-book recipe by @fbuster is good for ROS version<6.41. For newer version, the recipe would be:
add name=bridge
add bridge=bridge interface=ether1
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
# optionally: add bridge=bridge interface=wlan1
# etc.
#  For static IP address:
add address=192.168.1.2/24 interface=bridge network=192.168.1.0
# for internet access - ROS updates etc.
add gateway=192.168.1.1
set servers=192.168.1.1 # or some other DNS server
# To run DHCP client, set thus instead:
/ip dhcp-client
add interface=bridge
BR,
Metod
nescafe2002
Long time Member
Long time Member
Wed Jan 16, 2019 4:23 pm
Note that this is done automatically if you reset the device to CAPs mode - even if you don't have wireless interfaces or a CAPsMAN controller.
Keep holding the reset button for 5 more seconds, LED turns solid, release now to turn on CAPs mode (total 10 seconds).
Users browsing this forum: amu, anav, creatin, eworm, Google [Bot], HakanE, r00t, UpRunTech and 114 guests
