wispmikrotik
DNS xxx.ddns.net
Fri Jan 18, 2019 7:46 pm
I am seeing in my mikrotik router some connection to dns "k3yhol3.ddns.net", this dns has the IP 0.0.0.0.
Linux (nslookup):
Non-authoritative answer:
Address: 0.0.0.0
ping web:
What's up with this domain? I do not understand anything, if someone can help me ...
Regards.
anav
Re: DNS xxx.ddns.net
Fri Jan 18, 2019 8:22 pm
Please post your config
/export hide=sensitive file=mylatestconfig
It will help determine how your DNS and firewall rules are setup.
We may also want to consider redirect NAT rules for DNS.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
wispmikrotik
Fri Jan 18, 2019 8:41 pm
Hi anav,
Thanks. export:
# jan/18/2019 20:37:41 by RouterOS 6.44beta54
# software id = 06GQ-R3YM
add name=loopback protocol-mode=none
add authentication-types=wpa2-psk disable-pmkid=yes eap-methods="" \
    group-key-update=30m management-protection=allowed mode=dynamic-keys \
    name=p_AP supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode \
    ampdu-priorities=0,1,2,3,4 band=2ghz-onlyn basic-rates-a/g="" \
    basic-rates-b="" bridge-mode=disabled disabled=no distance=indoors \
    frequency=2452 ht-basic-mcs="" ht-supported-mcs="mcs-3,mcs-4,mcs-5,mcs-6,m\
    cs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15" \
    hw-protection-mode=cts-to-self installation=indoor mode=ap-bridge \
    radio-name="" rate-set=configured security-profile=p_AP ssid=INVI \
    supported-rates-a/g="" supported-rates-b="" wireless-protocol=802.11 \
    wps-mode=disabled
add name=pool_lan ranges=192.168.88.50-192.168.88.254
add add-arp=yes address-pool=pool_lan disabled=no interface=wlan1 lease-time=\
    1d name=dhcp_lan
set discover-interface-list=none
add address=192.168.88.1/24 interface=wlan1 network=192.168.88.0
add address=192.168.240.100 interface=loopback network=192.168.240.100
/ip dhcp-client
add dhcp-options=clientid,hostname disabled=no interface=ether1 use-peer-dns=\
    no use-peer-ntp=no
add address=192.168.88.0/24 gateway=192.168.88.1 netmask=24
set servers=1.1.1.1,208.67.220.220
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/system clock
set time-zone-name=Europe/Athens
/system identity
set name=valb01
/system ntp client
set enabled=yes primary-ntp=52.209.118.149 secondary-ntp=163.172.61.210
/tool bandwidth-server
set authenticate=no enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
If you make a ping or solve the domain that resolves to you?
Regards.
anav
Fri Jan 18, 2019 8:47 pm
I am not familiar with 1.1.1.1 is that a legitimate DNS server??
Overall your setup is missing so many things and most of all any firewall rules.
I suggest you download the latest stable firmware 6.43.8 and reset to defaults.
For example
missing an IP pool
missing a DHCP-SERVER NEWORK
no firewall filter rules
no firewall nat rules
no IP route rules
and many others.......
wispmikrotik
Fri Jan 18, 2019 8:54 pm
For example
missing an IP pool
no IP route rules
IP 1.1.1.1 is cloudfare.
https://blog.cloudflare.com/announcing-1111/
Regarding the rules of the firewall, they are not necessary, since in front of the mikrotik there is a firewall that blocks all unwanted input/forward traffic.
Can you try to resolve the domain k3yhol3.ddns.net by ping and tell me if an IP responds?
Regards.
I appreciate your help.
Takv
Tue Jan 22, 2019 12:38 am
Localhost... So strange.
Enviado desde mi Mi A2 mediante Tapatalk
Takv
Tue Jan 22, 2019 12:45 am
https://otx.alienvault.com/indicator/do ... 3.ddns.net
Jotne
Tue Jan 22, 2019 10:51 am
Not strange at all. When you register a DNS name, you can add any IP you like.
So some has registered k3yhol3.ddns.net with IP 127.0.0.1
I can register myserverhome.dyndns,com with IP 127.0.0.1 but why should I do that is an other question.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
Takv
Tue Jan 22, 2019 4:09 pm
Exactly
Jcon
Fri Jan 25, 2019 8:00 pm
Google `k3yhol3`
It sounds like you may have something on your network you'll want to get rid of. Sounds like whatever it is, it keeps checking that domain for a valid IP. And once it has it... it will start its process. Be it transferring data... performing a DDoS attack.... not good.
Burn it with fire... quick.
Users browsing this forum: Bing [Bot] and 79 guests
