MUM Europe 2020
pshulgin
DNAT does not translated returned traffic
Wed Jan 23, 2019 10:00 am
Hi everyone !!!
I have issue with DNAT
i created rule
add action=dst-nat chain=dstnat dst-address=ххх.ххх.ххх.ххх dst-port=64000 in-interface=ether1 protocol=tcp to-addresses=10.60.7.20 to-ports=22
it works in one direction, when traffic comes from outside
i see incoming traffic on 10.60.7.20 and responses to outside then i see returned traffic on router but DNAT does not translated back srcip and srcport to public ip
on all route some routers uses PBR but i think it does not affected traffic
# jan/23/2019 14:57:09 by RouterOS 6.43.8
# software id =
set [ find default-name=ether1 ] disable-running-check=no
/interface gre
add allow-fast-path=no ipsec-secret=xxxxx !keepalive local-address=xxx.xxx.xxx.xxx mtu=1400 name=xxxxxx remote-address=xxx.xxx.xxx.xxx
/ip ipsec peer profile
add dh-group=modp2048 enc-algorithm=aes-128 hash-algorithm=sha256 name=some_name nat-traversal=no
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-128-cbc name=some_name pfs-group=modp2048
/snmp community
add address=xxx.xxx.xxx.xxx/20 interface=ether1 network=xxx.xxx.xxx.xxx
add address=10.140.64.2/30 interface=To_MKRHUB network=10.140.64.0
add address=10.140.64.5/30 interface=To_FAC network=10.140.64.4
add address=10.140.80.5/30 interface=To_FAC network=10.140.80.4
/ip dhcp-client
add disabled=no interface=ether1
set servers=8.8.8.8
add action=accept chain=input dst-port=161 in-interface-list=all protocol=udp
add action=accept chain=input src-address=95.182.74.14
add action=accept chain=input src-address=5.43.226.94
add action=accept chain=input src-address=10.140.64.0/24
add action=accept chain=forward src-address=192.168.10.0/24
add action=src-nat chain=srcnat comment="xxxxxxxxxxx" out-interface=ether1 src-address=10.60.7.0/24 to-addresses=xxx.xxx.xxx.xxx
add action=dst-nat chain=dstnat dst-address=xxx.xxx.xxx.xxx dst-port=64000 in-interface=ether1 protocol=tcp to-addresses=10.60.7.20 to-ports=22
/ip ipsec policy
set 0 disabled=yes
add distance=1 gateway=xxxxxxxxxxx
add distance=1 dst-address=10.33.0.0/18 gateway=10.140.64.1
add distance=1 dst-address=10.60.2.0/24 gateway=10.140.64.1
add distance=1 dst-address=10.60.7.0/24 gateway=10.140.64.1
add distance=1 dst-address=10.140.80.0/23 gateway=xxxxxxxxxxx
add distance=1 dst-address=192.168.10.0/24 gateway=10.140.64.6
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/snmp
set enabled=yes trap-generators="" trap-version=2
/system clock
set time-zone-name=Asia/Krasnoyarsk
/system identity
set name=xxxxxxxxxxx
anav
Re: DNAT does not translated returned traffic
Wed Mar 20, 2019 5:49 pm
The standard dst-nat rule looks like:
add action=dst-nat chain=dstnat dst-port=xx
in-interface-list=WAN protocol=tcp to-addresses=192.168.y.yy to-ports=yy
Note1: If one has known list of WANIP authorized for access (static) then its best to make the rule more secure by adding a source address list.
Note2: If the destination port and to-ports are the same (no port translation, the too ports are not required).
In your case I dont think you need both destination address and in-interface=ether1 (try just using one or the other first). I dont think putting in both is required but on the other hand I dont see that stopping traffic, but worth a try.
This leads me to believe the source nat rule needs closer inspection.
The standard format is...............
add action=masquerade chain=srcnat comment="SCR_NAT for LAN Users" \
ipsec-policy=out,none out-interface=eth1
Therefore I believe you rule should be modified to the following (drop everything after ether1!!!.......
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Sob
Wed Mar 20, 2019 8:23 pm
Dstnat and correct rewriting of responses is something that just works. There's nothing to go wrong, unless there's some asymmetric routing or something like that. I don't see anything wrong in this config.
@anav: You like MUM presentations, don't you? Check this one (notice the title and then from page 25):
https://mum.mikrotik.com/presentations/ ... 948376.pdf
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
Users browsing this forum: sparky and 3 guests
