crazydesigner
Site to Site IPsec tunnel. Can't ping hosts
Mon Jan 28, 2019 10:19 pm
Hello
I have a site-to-site vpn and it is working correctly PH2 State is estabilished and also I see Installed Sas, but I can not ping the router and network computers.
I am using this tutorial and everything works fine but can't ping hosts. https://wiki.mikrotik.com/wiki/Manual:I ... sec_tunnel
Site 1 configuration
/ip ipsec peer
add address=192.168.80.1/32 auth-method=pre-shared-key secret="test"
Using default proposal and will not write command for this
/ip ipsec policy
add src-address=10.1.202.0/24 src-port=any dst-address=10.1.101.0/24 dst-port=any \
sa-src-address=192.168.90.1 sa-dst-address=192.168.80.1 \
tunnel=yes action=encrypt proposal=default
Site 2 configuration
/ip ipsec peer
add address=192.168.90.1/32 auth-method=pre-shared-key secret="test"
/ip ipsec policy
add src-address=10.1.101.0/24 src-port=any dst-address=10.1.202.0/24 dst-port=any \
sa-src-address=192.168.80.1 sa-dst-address=192.168.90.1 \
After this PH2 State is estabilished and also I see Installed Sas.
NAT and Fasttrack Bypass
Office 1 router:
add chain=srcnat action=accept  place-before=0 \
 src-address=10.1.202.0/24 dst-address=10.1.101.0/24
Office 2 router:
 src-address=10.1.101.0/24 dst-address=10.1.202.0/24
Adding Firewall raw Rule
/ip firewall raw
add action=notrack chain=prerouting src-address=10.1.101.0/24 dst-address=10.1.202.0/24
add action=notrack chain=prerouting src-address=10.1.202.0/24 dst-address=10.1.101.0/24
So also which steps I must do in firewall or nat, route to hosts from network 10.1.202.0 ping 10.1.101.0 computers?
Thanks and waiting advice using this tuturoial
nescafe2002
Forum Veteran
Forum Veteran
Re: Site to Site IPsec tunnel. Can't ping hosts
Mon Jan 28, 2019 10:46 pm
Default firewall accepts untracked connections. Are you using default firewall? Are you pinging from/to routers or hosts? If routers, add route to remote subnet via local interface to ensure router picks correct source address.
crazydesigner
Tue Feb 05, 2019 6:11 pm
moderator note: do not quote preceding post, just use "Post Reply".
Thanks. added route and now i can ping/tracert from 10.1.202.1 to 10.1.101.1 and from 10.1.101.1 to 10.1.202.1 but after some time I am unable ping/tracert from 10.1.202.1. if i send ping from 10.1.101.1 then I am able to ping again. what kind of problem I have no idea
JanWerner
Thu Oct 31, 2019 2:33 pm
Hi. I have the same problem. Have you solved this problem?
albantax
Thu Jun 17, 2021 1:33 am
I have same problem, i have to ping before i can send traffic, any one solved this issue?
Elranchero
Sun Oct 02, 2022 7:27 pm
Hi
Do you have a drop rule at the end?
If yes than just add this rule before the drop rule
chain: input
protocol: ipsec-esp
Action: Accept
Users browsing this forum: No registered users and 77 guests
