normis
February Newsletter #87
Thu Jan 31, 2019 12:39 pm
In this MikroTik newsletter:
- new 8 x SFP+ port switch CRS309-1G-8S+IN
- new wAP 60Gx3 60GHz Sector Base Station
- new low cost 60GHz CPE LHG Lite60
- InterCell - LTE Base Stations, preorders available
- new active direct attach 5m cable
- RB4011 rackmount ears
- MUM schedule
- MUM Europe 2019 in Austria
Download newsletter here:
https://download2.mikrotik.com/news/news_87.pdf
rushlife
Re: January Newsletter #87
Thu Jan 31, 2019 1:04 pm
CRS332-32S+RM
CRS354-48P-4S+2Q+
CRS354-48G-4S+2Q+
still nothing ?
mistry7
Thu Jan 31, 2019 1:09 pm
wAP 60Gx3
Does it have 3 interface that means 3x2 Ghz Channels?
mkx
Thu Jan 31, 2019 1:42 pm
wAP 60Gx3
Propaganda letter says:
... It uses breakthrough antenna design, that consists of 96 elements to provide unprecedented 180 degree beam-forming coverage (three times bigger than regular wAP 60G AP!) ...
(highliting is mine)
BR,
Metod
normis
Thu Jan 31, 2019 1:50 pm
wrong highlight, though. I would highlight the previous sentence, where it says that there are more antenna elements, so it's basically a sector design. not more interfaces.
mistry7
Thu Jan 31, 2019 1:57 pm
OK, 4 port switch with POE?
mkx
Thu Jan 31, 2019 1:58 pm
Number of antenna elements by itself doesn't say anything about where's performance difference (the increased number of antenna elements could be used as well for better focussing which would mean higher gain) ... that's why I highlited what I highlited.
BR,
Metod
normis
Thu Jan 31, 2019 2:04 pm
there is no performance difference. the new sector wAP60 simply has a wider antenna angle, that is all.
marekm
Thu Jan 31, 2019 2:42 pm
It would be nice to be able to connect 3x as many stations per sector though - still limited to max 8.
soooc
Thu Jan 31, 2019 4:13 pm
Please :)
mkx
Thu Jan 31, 2019 4:20 pm
Wider antenna aperture while maintaining antenna gain (due to beam forming) makes performance difference. At least to me.
BR,
Metod
WirelessRudy
Thu Jan 31, 2019 4:40 pm
Why is the client limit of the 60Ghz AP's still 8?
Is this a chip set limit, software? Practical?
An AP with a wider beam invites for more clients to connect. But if the limit is still eight, why bother. I am already reaching that limit in the 60 degree units. We need more clients per AP.
(And if this means the throughput per client goes down..... I'd rather have 20 clients that can reach maximum speeds of 50Mb (not all at the same time) then only 8 and each can do 200-500mbps....)
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
WirelessRudy
Thu Jan 31, 2019 4:46 pm
Can somebody update me on this...
I understood LTE is cell operator's stuff. And the LTE devices Mikrotik sells are to pickup that signal and enhance it.. But you need to connect to cell op's network with cell op's simm card.
Now MT has 'base station'........
Is this aimed at the cell op's world?
Do you need a license to use such base station? Do we need a frequency license? (So we need to bring a couple of millions to buy them from the goverment and in competition to the 'big' boys like Vodafone etc......?)
Can every LTE client (Mikrotik!, mobiles) connect to that base station?
Can somebody enlight me about the LTE and how we as Mikrotik users / WISP can make use of it?
Rudy R. Puister
mistry7
Thu Jan 31, 2019 4:48 pm
Yes it is Base Station, and yes for the now supported Bands, are only licensed
normis
Thu Jan 31, 2019 4:51 pm
This InterCell is not really for WISP. It is for companies who want to operate LTE cell towers, either for public or private reasons. Yes, you probably need a license from the regulator. These InterCell devices only support data (no voice calls, except whatsapp/skype etc over data connection). The InterCell can also be used to interconnect a lot of devices, like our LtAP units, in smaller areas where wifi is crowded or there is no line of sight. Still you need the license for it.
soooc
Thu Jan 31, 2019 4:54 pm
Its clear, what about count of 60 GHz clients??
normis
Thu Jan 31, 2019 5:02 pm
chipset limit is 8
mistry7
Thu Jan 31, 2019 5:13 pm
chipset limit is 8
Whats about smaller Channels?
bastys
Thu Jan 31, 2019 5:19 pm
Device Is one chipset with 3x60° 96 elements, right?
Arcee
Thu Jan 31, 2019 5:27 pm
Why not for WISPs?
I would love to move to a licensed frequency (my own highway) for PtMP.
I had been looking at Baicells products recently for this same reason. If Mikrotik has a comparable solution, I am sticking with my tried and proven brand. Very excited about this edition of the newsletter.
Can you say why this might not be feasible for WISPs?
Sent from my Pixel 2 using Tapatalk
WirelessRudy
Thu Jan 31, 2019 5:51 pm
chipset limit is 8
That's a pity! Can we expect some change in the future?
Rudy R. Puister
WirelessRudy
Thu Jan 31, 2019 5:55 pm
chipset limit is 8
Yes, what about smaller channels?
With smaller channels we can setup more sectors on one tower and still get good speeds (100+Mbps) to the only 8 maximum clients per sector......
(4 frequencies is not enough if you wan't to build a mini cell network that also need 60Ghz for the backhauls. I have one tower with 4 &0Ghz backhauls and 4 60Ghz AP's... it's a hell of a job to get these separated so none of the unit's clients get a signal from one of the other AP's)
Rudy R. Puister
BG4DRL
Thu Jan 31, 2019 6:02 pm
60G AP udp both =900Mbps Beta61 Firmware. very nice
soooc
Thu Jan 31, 2019 6:17 pm
chipset limit is 8
But ignite metrolinq (has different chipset, but wigig too) can use 12 clients. Any sollution in future? And somebody from Mikrotik on MUM said, that it is software limit. But it can be a mistake.
marekm
Thu Jan 31, 2019 7:11 pm
chipset limit is 8
Any better chipsets (802.11ay?) on the horizon? Ideally, backwards-compatible with current 802.11ad stations so that only the AP needs to be upgraded.
r00t
Thu Jan 31, 2019 7:45 pm
Also 60GHz hardware with SFP+ port is badly needed... channel capacity is so much higher than what we can use currently.
doneware
Trainer
Trainer
Thu Jan 31, 2019 8:39 pm
chipset limit is 8
there was a press announcement from Qualcomm and Mikrotik back in october around the 17th or so, emphasising Qualcomm's upcoming QCA64x8 and QCA64x1 chipsets, promising .11ay.
https://www.qualcomm.com/news/releases/ ... hz-80211ay
#TR0359
doneware
Trainer
Trainer
Thu Jan 31, 2019 8:51 pm
let's be easy with that. if you can't have more than MCS9 (SC), then 1Gbps is just ok. .11ad doesn't have channel bonding, so in general you couldn't use the available extra juice anyway.
.11ad has at least channel bonding, they said. but the standard is not out yet. unless you have more radios driving different antenna arrays, you can't really hit the barrier of 1G in a single device. tbh i never saw any of the Mikrotik equipments do MCS11+, but even if we have MCS12, which is in best case around 4.62Gbps, and that's the whole available bw for tx and rx. and this is at radio level.
unless you really can squeeze out the 1+Gbps from the radio, there's no need to bump up the prices of these boxes just by adding a pipe you can't fill even halfway.
in my opinion, nbase-t would be a better fit here. and we also need to take into consideration, that currently PoE is used to power the device - you can't have this at 10GE esp with SFP+
#TR0359
doneware
Trainer
Trainer
Thu Jan 31, 2019 8:53 pm
you can be OK with this channel mapping. you can have the 100Mbps clients run the same high MCS, and ultimately serve more safely and do buffering on the FE part. i'm more interested in TDD - cause this is the key to boost client numbers.
#TR0359
macgaiver
Fri Feb 01, 2019 7:13 am
CRS332-32S+RM
CRS354-48P-4S+2Q+
CRS354-48G-4S+2Q+
still nothing ?
CRS332-32S+RM + community feedback == CRS326-24S+2Q+RM in latest MUM opening presentations.
https://youtu.be/zMbtmeTm1PI?list=PLXr- ... O2&t=2053s
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
anuser
Fri Feb 01, 2019 7:56 am
For the WAP 60 it would be great if I could setup it like cAP AC with CAPSMAN enabled, multiple concurrent SSIDs enabled and support for 20/30 e.g. smartphones not only with other MikroTik WAP 60 devices.
BaseflexISP
Fri Feb 01, 2019 8:16 am
- MUM schedule
The interCell is a very good and welcome idea for those with LTE licensed in building small cell to extend coverage, however Mikrotik is missing an important emerging band, B42. It took a long time before Mikrotik released ODU in that Band infact only recently (I mean the LHG 4G kit -RBLHGR&R11e-4G). Are we going to see Intercell in B42 also?
baseflexisp.com
Flexible ISP billing software for everyone!
uldis
Fri Feb 01, 2019 11:32 am
- MUM schedule
We are getting lot of requests for B42 LTE Base Station. But we would need to understand more which exact band is needed as it looks more that B48 is the main band that we would need to focus.
What are the requirements for such Base Station for 3.5GHz solution - output power, antenna gain (or can be external), any other software feature?
eduncan911
Re: February Newsletter #87
Fri Feb 01, 2019 2:19 pm
Is there any news on the CRS312-4C-8XG?
It was announced April 2018. :)
rushlife
Fri Feb 01, 2019 3:19 pm
I am so pumped up for these product but still nothing...
I will keep looking for them.
eduncan911
Fri Feb 01, 2019 5:00 pm
I know, right? It hits all the sweet spots: low end CPU for those of us that don't really need routing (to keep the cost way way down as well) with the non-blocking bandwidth we all want in a switch at an affordable price ($400 maybe?) to crush other brands that are way overpriced for a simple home setup.
I mean, I purposely bought the CRS328-24P-4S+RM specifically to match this CRS312-4C-8XG device when it comes out for 40 Gbps between the two - while connecting my laptop (with a 10 Gbps RJ45 10GBaseT dock!) and two servers, both with 10GBaseT onboard the motherboard - not to mention my new desktop. The CRS328-24P-4S is still sitting in its box as I remodel the house in the coming months, which includes cat6a everywhere and a few fiber drops (since it's so cheap, and the "just in case" between my home office and rack location across the house).
otgooneo
Trainer
Trainer
Fri Feb 01, 2019 5:50 pm
Ohhh. This is something very very interesting for me. Would like to know details about it. Does it include vEPC inside the cell? Can it connect to operator EPC? What will be the software? What is the roadmap? Does Mikrotik has strong interest to continue this solution until 5G (maybe too early to ask)?
Want to learn more and more...
uldis
Fri Feb 01, 2019 6:16 pm
As written in the PDF of Intercell it will support built-in EPC with up to 256 clients and also will support external EPC if you have an existing EPC. It will feature special dedicated software (not RouterOS). Currently only B38/B39 bands, what LTE bands you are looking for? Currently it is too early to talk on the 5G Base Station.
krafg
Sat Feb 02, 2019 4:00 pm
it's possible create an antenna only like LHG for 2G/3G/4G solutions? I want integrate bigger antennas to my RBM33G and mANT LTE 5o are very little. :(
anav
Sat Feb 02, 2019 11:15 pm
What, my RB260GS paperweight switch is not getting RouterOS?
I was sure that was coming LOL. ;-)
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
otgooneo
Trainer
Trainer
Mon Feb 04, 2019 5:46 am
Thank you Uldis. I think B38/B39 is fine in initial stage. Those frequencies are popular among most of countries.
JimmyNyholm
Mon Feb 04, 2019 7:44 am
Can we please have special mounting fot having 2 SFP+ port switch CRS309-1G-8S+IN in one rack Unit
Redmor
Mon Feb 04, 2019 8:28 am
What about CCR1036-12G-4S+?
vladimirslk
Mon Feb 04, 2019 1:44 pm
b48 easier to license in eu countries..
what is the performance of that lte ""wimax"" product? :) no info regarding speeds
normis
Mon Feb 04, 2019 1:52 pm
there is no wimax product here. what do you mean?
lapsio
Mon Feb 04, 2019 2:52 pm
CRS332-32S+RM
CRS354-48P-4S+2Q+
CRS354-48G-4S+2Q+
still nothing ?
Iirc CRS332-32S+RM evolved into CRS326-24S+2Q+RM
MTCNA, MTCRE, MTCINE
raffav
Mon Feb 04, 2019 5:30 pm
Hello it's possible to a SFP+ Ethernet Module to have POE-out capability ?
lapsio
Mon Feb 04, 2019 5:36 pm
Great choice of thread to ask such question!
No it's not. SFP and SFP+ have standardized maximum power draw (which is relatively low) so unless you'd like to power some ultra low powered device there's no chance. Also SFP is powered by 3V so it's quite low for PoE standards. Average SFP/SFP+ draws around 1W up to 1.5W for long distance ones. It'd be hard to find device that can be powered with that
Of course you could break those standards and make specialized switch and specialized modules but those modules would burn any normal hardware, not suited for such current.
raffav
Mon Feb 04, 2019 5:56 pm
uldis
Tue Feb 05, 2019 10:10 am
We will see on the other bands when we will release the current series but it is possible that we could look at 3.5ghz bands. All depends on the demand. As currently the 3.5ghz is more popular in US.
Regarding the speed you can see the datasheet what ti the maximum download/upload speed.
Users browsing this forum: No registered users and 8 guests
