MUM Europe 2020
modrus
Problem with certificate backup for SSTP
Wed Feb 06, 2019 11:46 am
I have used two hEX Mikrotik as SSTP VPN concentrator with certifications and lot of hAP as clients.
On the primary hEX I generated a ca, server and client certificates. So ca and client cert imported to clients hAP and created SSTP tunnel. On the hEX I had set "verify client certificate". Everything works fine.
But if I exported a certifications and import these to second hEX. So if first mikrotik shutdown and turn on second Mikrotik hEX and with the same configuration and restore certifications so the clients are not possible to connect.
I found only diferences with certifications that on the primary (on this were generated) are certifications issued and index ca but on the second one Mikrotik not.
Do you have any idea why?
modrus
Re: Problem with certificate backup for SSTP
Tue Feb 12, 2019 9:51 pm
Really nobody :(
kadety
Mon Apr 29, 2019 5:08 pm
I'm having the same problem, how resolved?
Exiver
Mon Apr 29, 2019 5:45 pm
Do you use the exact same configuration on the second hex as on the first one? Since OP has selected "Verify Server Address from Certificate" the DNS must match the second hex as well (so if you use another IP for the second router and the Hostname is different this wont work).
@kadety: We need your configuration as well as the errors seen on client and server. Otherwise there is no chance to help you
kadety
Mon Apr 29, 2019 8:59 pm
Hi Exiver, I have two CCR1016, firts in production and second in backup. Same Hardware end RouterOS 6.44.3.
When I restore the backup, the certificates do not have the "K" of privete key, see.
After restore backup, I Export certificate of MK Production end import to backup (.crt and .KEY), but not working
tdw
Mon Apr 29, 2019 9:44 pm
I had a similar problem recently. After restoring the backup did you delete the certificates before importing them again?
Exiver
Mon Apr 29, 2019 9:58 pm
As @tdw mentioned: If you want to import the certificates again - you need to delete them first.
Your first picture shows us that you dont have the private keys on that Device. Where did you first create them?
The right procedure would be:
-> Router #1 with CA-Certificate and everything else (Export Certs+Keys)
-> Download Certs+Keys to your Computer or a safe location
-> Backup Router#1
-> Router #2 should be completetly empty, same software version as Router #1 (no default config, no certificates, check /certifiticates print before importing)
-> Restore Certificates + private Keys
-> Rename Certificates + private Keys to the same "Name" as on Router #1
-> Import Config
That should be the correct way...
kadety
Mon Apr 29, 2019 11:28 pm
These are the MK production certificates that work. See the first column. Certificate CA KLAT, Certificate client KI. There are Working.
In MK backup:
1-factory reset (Not default configuration)
2-Restore Backup (With the production MK settings)
3- Deleted the existing certificates
4- Import certificates / key sucess.
5-Certificates Not working, VPN not conection and first column not "i" (issued), only "K"
Exiver
Tue Apr 30, 2019 2:04 am
You should understand that my howto steps werent in random order but i had a plan telling you so. After you have restored the configuration there is some setting relying on a certificate which is indeed there at this time. But if you delete it afterwards it wont be there - your settings are maybe screwed at this point. Thats why you should follow the steps: Make sure the router is cleared of all config an certificates, import the certificates, name them correctly and apply the configuration afterwards.
The I for issued is not necessary since its only displayed on the device which created the certificates. Thats expected.
If it doesnt work post your log as well as it maybe can explain whats happening
kadety
Tue Apr 30, 2019 8:26 pm
Now, I took the following steps in MK Backup (BKP).
1- Factory reset (Not default configuration)
2 - MK BKP, No settings
3- Import Certificate to MK BKP
4 - Not Working the VPN Error (TLS Failed)
Unfortunable it does not work, the VPN does not connect. But, if disable "required Client Certificate", this work.
Exiver
Tue Apr 30, 2019 10:39 pm
Can you please make sure that your date and time is set correct on both routers? Looks like a certificate problem - this may be caused by "not valid" certificates since your router shows in picture (2) that time is not set thus resulting in unix standard time (01.01.1970 00:00) Is that Log in picture (4) from the CCR or the Client-side? If time and date is set correctly we need more of the log. Please poste both sites from start until end of the connection. This output doesnt show that much.
kadety
Wed May 01, 2019 12:07 am
Time is equal in both routers
Please, see if the log is better.
Exiver
Wed May 01, 2019 10:11 pm
You missed the clients side logs...
Thus guessing into the wild again: Is the Hostname on your server the same as on your original router? Must be since the certificate is only valid for identity "server_MK" so if your backup system has a different /system identity the client wont accept the server certificate.
kadety
Thu May 02, 2019 2:29 pm
Hi Exiver, I changed the name of MK BKP, but not working.
08:07:17 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=08cc6394b47b43e5 pid=3 DATA len=1400
08:07:17 ovpn,debug,packet sent P_ACK kid=0 sid=cd6c2e6757ed684e [3 sid=08cc6394b47b43e5] DATA len=0
08:07:17 ovpn,debug,packet sent P_CONTROL kid=0 sid=cd6c2e6757ed684e pid=4 DATA len=7
08:07:17 ovpn,debug <187.69.86.246>: disconnected <TLS failed>
08:07:17 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=8d26e0ee9a2cd43f [0 sid=b156dbdc6951121c] pid=1 DATA len=0
08:07:17 ovpn,debug,packet sent P_ACK kid=0 sid=b156dbdc6951121c [1 sid=8d26e0ee9a2cd43f] DATA len=0
08:07:17 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=8d26e0ee9a2cd43f pid=2 DATA len=283
08:07:17 ovpn,debug,packet sent P_ACK kid=0 sid=b156dbdc6951121c [2 sid=8d26e0ee9a2cd43f] DATA len=0
08:07:17 ovpn,debug,packet sent P_CONTROL kid=0 sid=b156dbdc6951121c pid=1 DATA len=1400
08:07:17 ovpn,debug,packet sent P_CONTROL kid=0 sid=b156dbdc6951121c pid=2 DATA len=1400
08:07:17 ovpn,debug,packet sent P_CONTROL kid=0 sid=b156dbdc6951121c pid=3 DATA len=79
08:07:17 ovpn,debug,packet rcvd P_ACK kid=0 sid=8d26e0ee9a2cd43f [1 sid=b156dbdc6951121c] DATA len=0
08:07:17 ovpn,debug,packet rcvd P_ACK kid=0 sid=8d26e0ee9a2cd43f [2 sid=b156dbdc6951121c] DATA len=0
08:07:17 ovpn,debug,packet rcvd P_ACK kid=0 sid=8d26e0ee9a2cd43f [3 sid=b156dbdc6951121c] DATA len=0
08:07:18 ovpn,info TCP connection established from 200.9.126.102
08:07:18 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=299189ea932f30e1 pid=0 DATA len=0
08:07:18 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=6a1fad2a431ff322 pid=0 DATA len=0
08:07:18 ovpn,debug,packet sent P_ACK kid=0 sid=299189ea932f30e1 [0 sid=6a1fad2a431ff322] DATA len=0
08:07:18 ovpn,info TCP connection established from 179.150.174.205
08:07:18 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=b6cf43ad2e24c4c4 pid=0 DATA len=0
08:07:18 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=548deae82b13e927 pid=0 DATA len=0
08:07:18 ovpn,debug,packet sent P_ACK kid=0 sid=b6cf43ad2e24c4c4 [0 sid=548deae82b13e927] DATA len=0
08:07:18 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=6a1fad2a431ff322 [0 sid=299189ea932f30e1] pid=1 DATA len=0
08:07:18 ovpn,debug,packet sent P_ACK kid=0 sid=299189ea932f30e1 [1 sid=6a1fad2a431ff322] DATA len=0
08:07:18 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=6a1fad2a431ff322 pid=2 DATA len=283
08:07:18 ovpn,debug,packet sent P_ACK kid=0 sid=299189ea932f30e1 [2 sid=6a1fad2a431ff322] DATA len=0
08:07:18 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=548deae82b13e927 [0 sid=b6cf43ad2e24c4c4] pid=1 DATA len=0
08:07:18 ovpn,debug,packet sent P_ACK kid=0 sid=b6cf43ad2e24c4c4 [1 sid=548deae82b13e927] DATA len=0
08:07:18 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=548deae82b13e927 pid=2 DATA len=283
08:07:18 ovpn,debug,packet sent P_ACK kid=0 sid=b6cf43ad2e24c4c4 [2 sid=548deae82b13e927] DATA len=0
08:07:19 ovpn,debug,packet sent P_CONTROL kid=0 sid=299189ea932f30e1 pid=1 DATA len=1400
08:07:19 ovpn,debug,packet sent P_CONTROL kid=0 sid=299189ea932f30e1 pid=2 DATA len=1400
08:07:19 ovpn,debug,packet sent P_CONTROL kid=0 sid=299189ea932f30e1 pid=3 DATA len=79
08:07:19 ovpn,debug,packet rcvd P_ACK kid=0 sid=6a1fad2a431ff322 [1 sid=299189ea932f30e1] DATA len=0
08:07:19 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=8d26e0ee9a2cd43f pid=3 DATA len=1400
08:07:19 ovpn,debug,packet sent P_ACK kid=0 sid=b156dbdc6951121c [3 sid=8d26e0ee9a2cd43f] DATA len=0
08:07:19 ovpn,debug,packet sent P_CONTROL kid=0 sid=b156dbdc6951121c pid=4 DATA len=7
08:07:19 ovpn,debug <191.207.207.17>: disconnected <TLS failed>
08:07:19 ovpn,debug,packet sent P_CONTROL kid=0 sid=b6cf43ad2e24c4c4 pid=1 DATA len=1400
08:07:19 ovpn,debug,packet sent P_CONTROL kid=0 sid=b6cf43ad2e24c4c4 pid=2 DATA len=1400
08:07:19 ovpn,debug,packet sent P_CONTROL kid=0 sid=b6cf43ad2e24c4c4 pid=3 DATA len=79
08:07:19 ovpn,debug,packet rcvd P_ACK kid=0 sid=6a1fad2a431ff322 [2 sid=299189ea932f30e1] DATA len=0
08:07:19 ovpn,debug,packet rcvd P_ACK kid=0 sid=6a1fad2a431ff322 [3 sid=299189ea932f30e1] DATA len=0
08:07:19 ovpn,debug,packet rcvd P_ACK kid=0 sid=548deae82b13e927 [1 sid=b6cf43ad2e24c4c4] DATA len=0
08:07:19 ovpn,debug,packet rcvd P_ACK kid=0 sid=548deae82b13e927 [2 sid=b6cf43ad2e24c4c4] DATA len=0
08:07:19 ovpn,debug,packet rcvd P_ACK kid=0 sid=548deae82b13e927 [3 sid=b6cf43ad2e24c4c4] DATA len=0
08:07:19 ovpn,info TCP connection established from 187.2.142.65
08:07:19 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=0eafd69ce1c3e83 pid=0 DATA len=0
08:07:19 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=61ac2f52e8203619 pid=0 DATA len=0
08:07:19 ovpn,debug,packet sent P_ACK kid=0 sid=0eafd69ce1c3e83 [0 sid=61ac2f52e8203619] DATA len=0
08:07:19 ovpn,info TCP connection established from 187.68.131.100
08:07:19 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=aaa5253dec49a9ca pid=0 DATA len=0
08:07:19 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=5635d751a76dfd3c pid=0 DATA len=0
08:07:19 ovpn,debug,packet sent P_ACK kid=0 sid=aaa5253dec49a9ca [0 sid=5635d751a76dfd3c] DATA len=0
08:07:19 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=61ac2f52e8203619 [0 sid=0eafd69ce1c3e83] pid=1 DATA len=0
08:07:19 ovpn,debug,packet sent P_ACK kid=0 sid=0eafd69ce1c3e83 [1 sid=61ac2f52e8203619] DATA len=0
08:07:19 ovpn,info TCP connection established from 179.242.106.114
08:07:19 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=30705daf7dd21374 pid=0 DATA len=0
08:07:19 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=61ac2f52e8203619 pid=2 DATA len=283
08:07:19 ovpn,debug,packet sent P_ACK kid=0 sid=0eafd69ce1c3e83 [2 sid=61ac2f52e8203619] DATA len=0
08:07:19 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=5635d751a76dfd3c [0 sid=aaa5253dec49a9ca] pid=1 DATA len=0
08:07:19 ovpn,debug,packet sent P_ACK kid=0 sid=aaa5253dec49a9ca [1 sid=5635d751a76dfd3c] DATA len=0
08:07:20 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=5635d751a76dfd3c pid=2 DATA len=283
08:07:20 ovpn,debug,packet sent P_ACK kid=0 sid=aaa5253dec49a9ca [2 sid=5635d751a76dfd3c] DATA len=0
08:07:20 ovpn,debug,packet sent P_CONTROL kid=0 sid=0eafd69ce1c3e83 pid=1 DATA len=1400
08:07:20 ovpn,debug,packet sent P_CONTROL kid=0 sid=0eafd69ce1c3e83 pid=2 DATA len=1400
08:07:20 ovpn,debug,packet sent P_CONTROL kid=0 sid=0eafd69ce1c3e83 pid=3 DATA len=79
08:07:20 ovpn,debug,packet rcvd P_ACK kid=0 sid=61ac2f52e8203619 [1 sid=0eafd69ce1c3e83] DATA len=0
08:07:20 ovpn,info TCP connection established from 189.93.154.204
08:07:20 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=5aacee9cbe2ff2 pid=0 DATA len=0
08:07:20 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=8dee7d9a74d387f pid=0 DATA len=0
08:07:20 ovpn,debug,packet sent P_ACK kid=0 sid=5aacee9cbe2ff2 [0 sid=8dee7d9a74d387f] DATA len=0
08:07:20 ovpn,debug,packet rcvd P_ACK kid=0 sid=61ac2f52e8203619 [2 sid=0eafd69ce1c3e83] DATA len=0
08:07:20 ovpn,debug,packet rcvd P_ACK kid=0 sid=61ac2f52e8203619 [3 sid=0eafd69ce1c3e83] DATA len=0
08:07:20 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=8dee7d9a74d387f [0 sid=5aacee9cbe2ff2] pid=1 DATA len=0
08:07:20 ovpn,debug,packet sent P_ACK kid=0 sid=5aacee9cbe2ff2 [1 sid=8dee7d9a74d387f] DATA len=0
08:07:20 ovpn,debug,packet sent P_CONTROL kid=0 sid=aaa5253dec49a9ca pid=1 DATA len=1400
08:07:20 ovpn,debug,packet sent P_CONTROL kid=0 sid=aaa5253dec49a9ca pid=2 DATA len=1400
08:07:20 ovpn,debug,packet sent P_CONTROL kid=0 sid=aaa5253dec49a9ca pid=3 DATA len=79
08:07:20 ovpn,debug,packet rcvd P_ACK kid=0 sid=5635d751a76dfd3c [1 sid=aaa5253dec49a9ca] DATA len=0
08:07:20 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=8dee7d9a74d387f pid=2 DATA len=283
08:07:20 ovpn,debug,packet sent P_ACK kid=0 sid=5aacee9cbe2ff2 [2 sid=8dee7d9a74d387f] DATA len=0
08:07:20 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=6a1fad2a431ff322 pid=3 DATA len=1400
08:07:20 ovpn,debug,packet sent P_ACK kid=0 sid=299189ea932f30e1 [3 sid=6a1fad2a431ff322] DATA len=0
08:07:20 ovpn,debug,packet sent P_CONTROL kid=0 sid=299189ea932f30e1 pid=4 DATA len=7
08:07:20 ovpn,debug <200.9.126.102>: disconnected <TLS failed>
08:07:20 ovpn,debug,packet rcvd P_ACK kid=0 sid=5635d751a76dfd3c [2 sid=aaa5253dec49a9ca] DATA len=0
08:07:20 ovpn,debug,packet rcvd P_ACK kid=0 sid=5635d751a76dfd3c [3 sid=aaa5253dec49a9ca] DATA len=0
08:07:20 ovpn,info TCP connection established from 179.102.176.19
08:07:20 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=638d6eb59d9e25fa pid=0 DATA len=0
08:07:20 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=0df14e5bf93087ec pid=0 DATA len=0
08:07:20 ovpn,debug,packet sent P_ACK kid=0 sid=638d6eb59d9e25fa [0 sid=0df14e5bf93087ec] DATA len=0
08:07:20 ovpn,debug,packet sent P_CONTROL kid=0 sid=5aacee9cbe2ff2 pid=1 DATA len=1400
08:07:20 ovpn,debug,packet sent P_CONTROL kid=0 sid=5aacee9cbe2ff2 pid=2 DATA len=1400
08:07:20 ovpn,debug,packet sent P_CONTROL kid=0 sid=5aacee9cbe2ff2 pid=3 DATA len=79
08:07:20 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=0df14e5bf93087ec [0 sid=638d6eb59d9e25fa] pid=1 DATA len=0
08:07:20 ovpn,debug,packet sent P_ACK kid=0 sid=638d6eb59d9e25fa [1 sid=0df14e5bf93087ec] DATA len=0
08:07:20 ovpn,debug,packet rcvd P_ACK kid=0 sid=8dee7d9a74d387f [1 sid=5aacee9cbe2ff2] DATA len=0
08:07:20 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=0df14e5bf93087ec pid=2 DATA len=283
08:07:20 ovpn,debug,packet sent P_ACK kid=0 sid=638d6eb59d9e25fa [2 sid=0df14e5bf93087ec] DATA len=0
08:07:20 ovpn,debug,packet rcvd P_ACK kid=0 sid=8dee7d9a74d387f [2 sid=5aacee9cbe2ff2] DATA len=0
08:07:20 ovpn,debug,packet rcvd P_ACK kid=0 sid=8dee7d9a74d387f [3 sid=5aacee9cbe2ff2] DATA len=0
08:07:20 ovpn,debug,packet sent P_CONTROL kid=0 sid=638d6eb59d9e25fa pid=1 DATA len=1400
08:07:20 ovpn,debug,packet sent P_CONTROL kid=0 sid=638d6eb59d9e25fa pid=2 DATA len=1400
08:07:20 ovpn,debug,packet sent P_CONTROL kid=0 sid=638d6eb59d9e25fa pid=3 DATA len=79
08:07:20 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=548deae82b13e927 pid=3 DATA len=1400
08:07:20 ovpn,debug,packet sent P_ACK kid=0 sid=b6cf43ad2e24c4c4 [3 sid=548deae82b13e927] DATA len=0
08:07:20 ovpn,debug,packet sent P_CONTROL kid=0 sid=b6cf43ad2e24c4c4 pid=4 DATA len=7
08:07:20 ovpn,debug <179.150.174.205>: disconnected <TLS failed>
08:07:20 ovpn,debug,packet rcvd P_ACK kid=0 sid=0df14e5bf93087ec [1 sid=638d6eb59d9e25fa] DATA len=0
08:07:21 ovpn,debug,packet rcvd P_ACK kid=0 sid=0df14e5bf93087ec [2 sid=638d6eb59d9e25fa] DATA len=0
08:07:21 ovpn,debug,packet rcvd P_ACK kid=0 sid=0df14e5bf93087ec [3 sid=638d6eb59d9e25fa] DATA len=0
08:07:21 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=452eecfe4dd667d7 pid=0 DATA len=0
08:07:21 ovpn,debug,packet sent P_ACK kid=0 sid=30705daf7dd21374 [0 sid=452eecfe4dd667d7] DATA len=0
08:07:21 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=5635d751a76dfd3c pid=3 DATA len=1400
08:07:21 ovpn,debug,packet sent P_ACK kid=0 sid=aaa5253dec49a9ca [3 sid=5635d751a76dfd3c] DATA len=0
08:07:21 ovpn,debug,packet sent P_CONTROL kid=0 sid=aaa5253dec49a9ca pid=4 DATA len=7
08:07:21 ovpn,debug <187.68.131.100>: disconnected <TLS failed>
08:07:21 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=8dee7d9a74d387f pid=3 DATA len=1400
08:07:21 ovpn,debug,packet sent P_ACK kid=0 sid=5aacee9cbe2ff2 [3 sid=8dee7d9a74d387f] DATA len=0
08:07:21 ovpn,debug,packet sent P_CONTROL kid=0 sid=5aacee9cbe2ff2 pid=4 DATA len=7
08:07:21 ovpn,debug <189.93.154.204>: disconnected <TLS failed>
08:07:22 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=0df14e5bf93087ec pid=3 DATA len=1400
08:07:22 ovpn,debug,packet sent P_ACK kid=0 sid=638d6eb59d9e25fa [3 sid=0df14e5bf93087ec] DATA len=0
08:07:22 ovpn,debug,packet sent P_CONTROL kid=0 sid=638d6eb59d9e25fa pid=4 DATA len=7
08:07:22 ovpn,debug <179.102.176.19>: disconnected <TLS failed>
08:07:22 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=61ac2f52e8203619 pid=3 DATA len=1400
08:07:22 ovpn,debug,packet sent P_ACK kid=0 sid=0eafd69ce1c3e83 [3 sid=61ac2f52e8203619] DATA len=0
08:07:22 ovpn,debug,packet sent P_CONTROL kid=0 sid=0eafd69ce1c3e83 pid=4 DATA len=7
08:07:22 ovpn,debug <187.2.142.65>: disconnected <TLS failed>
08:07:22 ovpn,info TCP connection established from 191.11.230.207
08:07:22 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=17755e1feadb52e8 pid=0 DATA len=0
08:07:22 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=fbd132b7409cdc25 pid=0 DATA len=0
08:07:22 ovpn,debug,packet sent P_ACK kid=0 sid=17755e1feadb52e8 [0 sid=fbd132b7409cdc25] DATA len=0
08:07:22 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=fbd132b7409cdc25 [0 sid=17755e1feadb52e8] pid=1 DATA len=0
08:07:22 ovpn,debug,packet sent P_ACK kid=0 sid=17755e1feadb52e8 [1 sid=fbd132b7409cdc25] DATA len=0
08:07:22 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=fbd132b7409cdc25 pid=2 DATA len=283
08:07:22 ovpn,debug,packet sent P_ACK kid=0 sid=17755e1feadb52e8 [2 sid=fbd132b7409cdc25] DATA len=0
08:07:22 ovpn,debug,packet sent P_CONTROL kid=0 sid=17755e1feadb52e8 pid=1 DATA len=1400
08:07:22 ovpn,debug,packet sent P_CONTROL kid=0 sid=17755e1feadb52e8 pid=2 DATA len=1400
08:07:22 ovpn,debug,packet sent P_CONTROL kid=0 sid=17755e1feadb52e8 pid=3 DATA len=79
08:07:22 ovpn,debug,packet rcvd P_ACK kid=0 sid=fbd132b7409cdc25 [1 sid=17755e1feadb52e8] DATA len=0
08:07:23 ovpn,debug,packet rcvd P_ACK kid=0 sid=fbd132b7409cdc25 [2 sid=17755e1feadb52e8] DATA len=0
08:07:23 ovpn,debug,packet rcvd P_ACK kid=0 sid=fbd132b7409cdc25 [3 sid=17755e1feadb52e8] DATA len=0
08:07:23 ovpn,info TCP connection established from 191.207.231.204
08:07:23 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=0ae0b5138072382c pid=0 DATA len=0
08:07:23 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=7b9b2b01f86e2ae pid=0 DATA len=0
08:07:23 ovpn,debug,packet sent P_ACK kid=0 sid=0ae0b5138072382c [0 sid=7b9b2b01f86e2ae] DATA len=0
08:07:23 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=7b9b2b01f86e2ae [0 sid=0ae0b5138072382c] pid=1 DATA len=0
08:07:23 ovpn,debug,packet sent P_ACK kid=0 sid=0ae0b5138072382c [1 sid=7b9b2b01f86e2ae] DATA len=0
08:07:23 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=7b9b2b01f86e2ae pid=2 DATA len=283
08:07:23 ovpn,debug,packet sent P_ACK kid=0 sid=0ae0b5138072382c [2 sid=7b9b2b01f86e2ae] DATA len=0
08:07:23 ovpn,debug,packet sent P_CONTROL kid=0 sid=0ae0b5138072382c pid=1 DATA len=1400
08:07:23 ovpn,debug,packet sent P_CONTROL kid=0 sid=0ae0b5138072382c pid=2 DATA len=1400
08:07:23 ovpn,debug,packet sent P_CONTROL kid=0 sid=0ae0b5138072382c pid=3 DATA len=79
08:07:23 ovpn,debug,packet rcvd P_ACK kid=0 sid=7b9b2b01f86e2ae [1 sid=0ae0b5138072382c] DATA len=0
08:07:23 ovpn,debug,packet rcvd P_ACK kid=0 sid=7b9b2b01f86e2ae [2 sid=0ae0b5138072382c] DATA len=0
08:07:23 ovpn,debug,packet rcvd P_ACK kid=0 sid=7b9b2b01f86e2ae [3 sid=0ae0b5138072382c] DATA len=0
08:07:23 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=452eecfe4dd667d7 [0 sid=30705daf7dd21374] pid=1 DATA len=0
08:07:23 ovpn,debug,packet sent P_ACK kid=0 sid=30705daf7dd21374 [1 sid=452eecfe4dd667d7] DATA len=0
08:07:23 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=452eecfe4dd667d7 pid=2 DATA len=283
08:07:23 ovpn,debug,packet sent P_ACK kid=0 sid=30705daf7dd21374 [2 sid=452eecfe4dd667d7] DATA len=0
08:07:23 ovpn,debug,packet sent P_CONTROL kid=0 sid=30705daf7dd21374 pid=1 DATA len=1400
08:07:23 ovpn,debug,packet sent P_CONTROL kid=0 sid=30705daf7dd21374 pid=2 DATA len=1400
08:07:23 ovpn,debug,packet sent P_CONTROL kid=0 sid=30705daf7dd21374 pid=3 DATA len=79
08:07:24 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=fbd132b7409cdc25 pid=3 DATA len=1400
08:07:24 ovpn,debug,packet sent P_ACK kid=0 sid=17755e1feadb52e8 [3 sid=fbd132b7409cdc25] DATA len=0
08:07:24 ovpn,debug,packet sent P_CONTROL kid=0 sid=17755e1feadb52e8 pid=4 DATA len=7
08:07:24 ovpn,debug <191.11.230.207>: disconnected <TLS failed>
08:07:24 ovpn,info TCP connection established from 191.11.243.178
08:07:24 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=ffb66c8d25212ac3 pid=0 DATA len=0
08:07:24 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=a13552c7a625642 pid=0 DATA len=0
08:07:24 ovpn,debug,packet sent P_ACK kid=0 sid=ffb66c8d25212ac3 [0 sid=a13552c7a625642] DATA len=0
08:07:24 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=7b9b2b01f86e2ae pid=3 DATA len=1400
08:07:24 ovpn,debug,packet sent P_ACK kid=0 sid=0ae0b5138072382c [3 sid=7b9b2b01f86e2ae] DATA len=0
08:07:24 ovpn,debug,packet sent P_CONTROL kid=0 sid=0ae0b5138072382c pid=4 DATA len=7
08:07:24 ovpn,debug <191.207.231.204>: disconnected <TLS failed>
08:07:24 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=a13552c7a625642 [0 sid=ffb66c8d25212ac3] pid=1 DATA len=0
08:07:24 ovpn,debug,packet sent P_ACK kid=0 sid=ffb66c8d25212ac3 [1 sid=a13552c7a625642] DATA len=0
08:07:24 ovpn,debug,packet rcvd P_ACK kid=0 sid=452eecfe4dd667d7 [1 sid=30705daf7dd21374] DATA len=0
08:07:24 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=a13552c7a625642 pid=2 DATA len=283
08:07:24 ovpn,debug,packet sent P_ACK kid=0 sid=ffb66c8d25212ac3 [2 sid=a13552c7a625642] DATA len=0
08:07:24 ovpn,debug,packet sent P_CONTROL kid=0 sid=ffb66c8d25212ac3 pid=1 DATA len=1400
08:07:24 ovpn,debug,packet sent P_CONTROL kid=0 sid=ffb66c8d25212ac3 pid=2 DATA len=1400
08:07:24 ovpn,debug,packet sent P_CONTROL kid=0 sid=ffb66c8d25212ac3 pid=3 DATA len=79
08:07:25 ovpn,info TCP connection established from 187.68.106.119
08:07:25 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=178f129613ea6fb2 pid=0 DATA len=0
08:07:25 ovpn,debug,packet rcvd P_ACK kid=0 sid=a13552c7a625642 [1 sid=ffb66c8d25212ac3] DATA len=0
08:07:25 ovpn,debug,packet rcvd P_ACK kid=0 sid=452eecfe4dd667d7 [2 sid=30705daf7dd21374] DATA len=0
08:07:25 ovpn,debug,packet rcvd P_ACK kid=0 sid=452eecfe4dd667d7 [3 sid=30705daf7dd21374] DATA len=0
08:07:25 ovpn,debug,packet rcvd P_ACK kid=0 sid=a13552c7a625642 [2 sid=ffb66c8d25212ac3] DATA len=0
08:07:25 ovpn,debug,packet rcvd P_ACK kid=0 sid=a13552c7a625642 [3 sid=ffb66c8d25212ac3] DATA len=0
08:07:25 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=c778522662b5256 pid=0 DATA len=0
08:07:25 ovpn,debug,packet sent P_ACK kid=0 sid=178f129613ea6fb2 [0 sid=c778522662b5256] DATA len=0
08:07:26 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=452eecfe4dd667d7 pid=3 DATA len=1400
08:07:26 ovpn,debug,packet sent P_ACK kid=0 sid=30705daf7dd21374 [3 sid=452eecfe4dd667d7] DATA len=0
08:07:26 ovpn,debug,packet sent P_CONTROL kid=0 sid=30705daf7dd21374 pid=4 DATA len=7
08:07:26 ovpn,debug <179.242.106.114>: disconnected <TLS failed>
08:07:26 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=a13552c7a625642 pid=3 DATA len=1400
08:07:26 ovpn,debug,packet sent P_ACK kid=0 sid=ffb66c8d25212ac3 [3 sid=a13552c7a625642] DATA len=0
08:07:26 ovpn,debug,packet sent P_CONTROL kid=0 sid=ffb66c8d25212ac3 pid=4 DATA len=7
08:07:26 ovpn,debug <191.11.243.178>: disconnected <TLS failed>
08:07:26 ovpn,info TCP connection established from 187.68.245.99
08:07:26 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=2411e9f172088e8 pid=0 DATA len=0
08:07:26 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=1954c2b8cdc524a7 pid=0 DATA len=0
08:07:26 ovpn,debug,packet sent P_ACK kid=0 sid=2411e9f172088e8 [0 sid=1954c2b8cdc524a7] DATA len=0
08:07:26 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=1954c2b8cdc524a7 [0 sid=2411e9f172088e8] pid=1 DATA len=0
08:07:26 ovpn,debug,packet sent P_ACK kid=0 sid=2411e9f172088e8 [1 sid=1954c2b8cdc524a7] DATA len=0
08:07:26 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=1954c2b8cdc524a7 pid=2 DATA len=283
08:07:26 ovpn,debug,packet sent P_ACK kid=0 sid=2411e9f172088e8 [2 sid=1954c2b8cdc524a7] DATA len=0
08:07:26 ovpn,debug,packet sent P_CONTROL kid=0 sid=2411e9f172088e8 pid=1 DATA len=1400
08:07:26 ovpn,debug,packet sent P_CONTROL kid=0 sid=2411e9f172088e8 pid=2 DATA len=1400
08:07:26 ovpn,debug,packet sent P_CONTROL kid=0 sid=2411e9f172088e8 pid=3 DATA len=79
08:07:26 ovpn,debug,packet rcvd P_ACK kid=0 sid=1954c2b8cdc524a7 [1 sid=2411e9f172088e8] DATA len=0
08:07:26 ovpn,debug,packet rcvd P_ACK kid=0 sid=1954c2b8cdc524a7 [2 sid=2411e9f172088e8] DATA len=0
08:07:26 ovpn,debug,packet rcvd P_ACK kid=0 sid=1954c2b8cdc524a7 [3 sid=2411e9f172088e8] DATA len=0
08:07:27 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=c778522662b5256 [0 sid=178f129613ea6fb2] pid=1 DATA len=0
08:07:27 ovpn,debug,packet sent P_ACK kid=0 sid=178f129613ea6fb2 [1 sid=c778522662b5256] DATA len=0
08:07:27 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=c778522662b5256 pid=2 DATA len=283
08:07:27 ovpn,debug,packet sent P_ACK kid=0 sid=178f129613ea6fb2 [2 sid=c778522662b5256] DATA len=0
08:07:27 ovpn,debug,packet sent P_CONTROL kid=0 sid=178f129613ea6fb2 pid=1 DATA len=1400
08:07:27 ovpn,debug,packet sent P_CONTROL kid=0 sid=178f129613ea6fb2 pid=2 DATA len=1400
08:07:27 ovpn,debug,packet sent P_CONTROL kid=0 sid=178f129613ea6fb2 pid=3 DATA len=79
08:07:27 ovpn,info TCP connection established from 187.69.86.246
08:07:27 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=0a36e3c877df5aed pid=0 DATA len=0
08:07:27 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=8b102f34dcc1dfa5 pid=0 DATA len=0
08:07:27 ovpn,debug,packet sent P_ACK kid=0 sid=0a36e3c877df5aed [0 sid=8b102f34dcc1dfa5] DATA len=0
08:07:27 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=8b102f34dcc1dfa5 [0 sid=0a36e3c877df5aed] pid=1 DATA len=0
08:07:27 ovpn,debug,packet sent P_ACK kid=0 sid=0a36e3c877df5aed [1 sid=8b102f34dcc1dfa5] DATA len=0
08:07:27 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=8b102f34dcc1dfa5 pid=2 DATA len=283
08:07:27 ovpn,debug,packet sent P_ACK kid=0 sid=0a36e3c877df5aed [2 sid=8b102f34dcc1dfa5] DATA len=0
08:07:27 ovpn,debug,packet sent P_CONTROL kid=0 sid=0a36e3c877df5aed pid=1 DATA len=1400
08:07:27 ovpn,debug,packet sent P_CONTROL kid=0 sid=0a36e3c877df5aed pid=2 DATA len=1400
08:07:27 ovpn,debug,packet sent P_CONTROL kid=0 sid=0a36e3c877df5aed pid=3 DATA len=79
08:07:27 ovpn,debug,packet rcvd P_ACK kid=0 sid=8b102f34dcc1dfa5 [1 sid=0a36e3c877df5aed] DATA len=0
08:07:27 ovpn,debug,packet rcvd P_ACK kid=0 sid=8b102f34dcc1dfa5 [2 sid=0a36e3c877df5aed] DATA len=0
08:07:27 ovpn,debug,packet rcvd P_ACK kid=0 sid=8b102f34dcc1dfa5 [3 sid=0a36e3c877df5aed] DATA len=0
08:07:28 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=1954c2b8cdc524a7 pid=3 DATA len=1400
08:07:28 ovpn,debug,packet sent P_ACK kid=0 sid=2411e9f172088e8 [3 sid=1954c2b8cdc524a7] DATA len=0
08:07:28 ovpn,debug,packet sent P_CONTROL kid=0 sid=2411e9f172088e8 pid=4 DATA len=7
08:07:28 ovpn,debug <187.68.245.99>: disconnected <TLS failed>
08:07:28 ovpn,debug,packet rcvd P_ACK kid=0 sid=c778522662b5256 [1 sid=178f129613ea6fb2] DATA len=0
08:07:28 ovpn,debug,packet rcvd P_ACK kid=0 sid=c778522662b5256 [2 sid=178f129613ea6fb2] DATA len=0
08:07:28 ovpn,debug,packet rcvd P_ACK kid=0 sid=c778522662b5256 [3 sid=178f129613ea6fb2] DATA len=0
08:07:29 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=8b102f34dcc1dfa5 pid=3 DATA len=1400
08:07:29 ovpn,debug,packet sent P_ACK kid=0 sid=0a36e3c877df5aed [3 sid=8b102f34dcc1dfa5] DATA len=0
08:07:29 ovpn,debug,packet sent P_CONTROL kid=0 sid=0a36e3c877df5aed pid=4 DATA len=7
08:07:29 ovpn,debug <187.69.86.246>: disconnected <TLS failed>
08:07:29 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=c778522662b5256 pid=3 DATA len=1400
08:07:29 ovpn,debug,packet sent P_ACK kid=0 sid=178f129613ea6fb2 [3 sid=c778522662b5256] DATA len=0
08:07:29 ovpn,info TCP connection established from 191.207.207.17
08:07:29 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=7c9782d7a3d6839 pid=0 DATA len=0
08:07:29 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=1e4ff334cef48459 pid=0 DATA len=0
08:07:29 ovpn,debug,packet sent P_ACK kid=0 sid=7c9782d7a3d6839 [0 sid=1e4ff334cef48459] DATA len=0
08:07:29 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=1e4ff334cef48459 [0 sid=7c9782d7a3d6839] pid=1 DATA len=0
08:07:29 ovpn,debug,packet sent P_ACK kid=0 sid=7c9782d7a3d6839 [1 sid=1e4ff334cef48459] DATA len=0
08:07:29 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=c778522662b5256 pid=4 DATA len=1162
08:07:29 ovpn,debug,packet sent P_ACK kid=0 sid=178f129613ea6fb2 [4 sid=c778522662b5256] DATA len=0
08:07:29 ovpn,debug,packet sent P_CONTROL kid=0 sid=178f129613ea6fb2 pid=4 DATA len=7
08:07:29 ovpn,debug <187.68.106.119>: disconnected <TLS failed>
08:07:29 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=1e4ff334cef48459 pid=2 DATA len=283
08:07:29 ovpn,debug,packet sent P_ACK kid=0 sid=7c9782d7a3d6839 [2 sid=1e4ff334cef48459] DATA len=0
08:07:29 ovpn,debug,packet sent P_CONTROL kid=0 sid=7c9782d7a3d6839 pid=1 DATA len=1400
08:07:29 ovpn,debug,packet sent P_CONTROL kid=0 sid=7c9782d7a3d6839 pid=2 DATA len=1400
08:07:29 ovpn,debug,packet sent P_CONTROL kid=0 sid=7c9782d7a3d6839 pid=3 DATA len=79
08:07:29 ovpn,debug,packet rcvd P_ACK kid=0 sid=1e4ff334cef48459 [1 sid=7c9782d7a3d6839] DATA len=0
08:07:29 ovpn,debug,packet rcvd P_ACK kid=0 sid=1e4ff334cef48459 [2 sid=7c9782d7a3d6839] DATA len=0
08:07:29 ovpn,debug,packet rcvd P_ACK kid=0 sid=1e4ff334cef48459 [3 sid=7c9782d7a3d6839] DATA len=0
08:07:30 ovpn,info TCP connection established from 200.9.126.102
08:07:30 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=5565e9f2949d117 pid=0 DATA len=0
08:07:30 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=69173269c6da415d pid=0 DATA len=0
08:07:30 ovpn,debug,packet sent P_ACK kid=0 sid=5565e9f2949d117 [0 sid=69173269c6da415d] DATA len=0
08:07:30 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=69173269c6da415d [0 sid=5565e9f2949d117] pid=1 DATA len=0
08:07:30 ovpn,debug,packet sent P_ACK kid=0 sid=5565e9f2949d117 [1 sid=69173269c6da415d] DATA len=0
08:07:30 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=69173269c6da415d pid=2 DATA len=283
08:07:30 ovpn,debug,packet sent P_ACK kid=0 sid=5565e9f2949d117 [2 sid=69173269c6da415d] DATA len=0
08:07:30 ovpn,debug,packet sent P_CONTROL kid=0 sid=5565e9f2949d117 pid=1 DATA len=1400
08:07:30 ovpn,debug,packet sent P_CONTROL kid=0 sid=5565e9f2949d117 pid=2 DATA len=1400
08:07:30 ovpn,debug,packet sent P_CONTROL kid=0 sid=5565e9f2949d117 pid=3 DATA len=79
08:07:30 ovpn,debug,packet rcvd P_ACK kid=0 sid=69173269c6da415d [1 sid=5565e9f2949d117] DATA len=0
08:07:30 ovpn,debug,packet rcvd P_ACK kid=0 sid=69173269c6da415d [2 sid=5565e9f2949d117] DATA len=0
08:07:30 ovpn,debug,packet rcvd P_ACK kid=0 sid=69173269c6da415d [3 sid=5565e9f2949d117] DATA len=0
08:07:31 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=1e4ff334cef48459 pid=3 DATA len=1400
08:07:31 ovpn,debug,packet sent P_ACK kid=0 sid=7c9782d7a3d6839 [3 sid=1e4ff334cef48459] DATA len=0
08:07:31 ovpn,debug,packet sent P_CONTROL kid=0 sid=7c9782d7a3d6839 pid=4 DATA len=7
08:07:31 ovpn,debug <191.207.207.17>: disconnected <TLS failed>
08:07:31 ovpn,info TCP connection established from 179.150.174.205
08:07:31 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=54aaa02b4dad9386 pid=0 DATA len=0
08:07:31 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=187595216dfd64 pid=0 DATA len=0
08:07:31 ovpn,debug,packet sent P_ACK kid=0 sid=54aaa02b4dad9386 [0 sid=187595216dfd64] DATA len=0
08:07:31 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=187595216dfd64 [0 sid=54aaa02b4dad9386] pid=1 DATA len=0
08:07:31 ovpn,debug,packet sent P_ACK kid=0 sid=54aaa02b4dad9386 [1 sid=187595216dfd64] DATA len=0
08:07:31 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=187595216dfd64 pid=2 DATA len=283
08:07:31 ovpn,debug,packet sent P_ACK kid=0 sid=54aaa02b4dad9386 [2 sid=187595216dfd64] DATA len=0
08:07:31 ovpn,debug,packet sent P_CONTROL kid=0 sid=54aaa02b4dad9386 pid=1 DATA len=1400
08:07:31 ovpn,debug,packet sent P_CONTROL kid=0 sid=54aaa02b4dad9386 pid=2 DATA len=1400
08:07:31 ovpn,debug,packet sent P_CONTROL kid=0 sid=54aaa02b4dad9386 pid=3 DATA len=79
08:07:31 ovpn,debug,packet rcvd P_ACK kid=0 sid=187595216dfd64 [1 sid=54aaa02b4dad9386] DATA len=0
08:07:31 ovpn,debug,packet rcvd P_ACK kid=0 sid=187595216dfd64 [2 sid=54aaa02b4dad9386] DATA len=0
08:07:31 ovpn,debug,packet rcvd P_ACK kid=0 sid=187595216dfd64 [3 sid=54aaa02b4dad9386] DATA len=0
08:07:31 ovpn,info TCP connection established from 187.68.131.100
08:07:31 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=8646ced2ec8676d6 pid=0 DATA len=0
08:07:31 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=1cc320937712ccb4 pid=0 DATA len=0
08:07:31 ovpn,debug,packet sent P_ACK kid=0 sid=8646ced2ec8676d6 [0 sid=1cc320937712ccb4] DATA len=0
08:07:31 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=1cc320937712ccb4 [0 sid=8646ced2ec8676d6] pid=1 DATA len=0
08:07:31 ovpn,debug,packet sent P_ACK kid=0 sid=8646ced2ec8676d6 [1 sid=1cc320937712ccb4] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=1cc320937712ccb4 pid=2 DATA len=283
08:07:32 ovpn,debug,packet sent P_ACK kid=0 sid=8646ced2ec8676d6 [2 sid=1cc320937712ccb4] DATA len=0
08:07:32 ovpn,info TCP connection established from 189.93.154.204
08:07:32 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=b29b4bef8a7412e pid=0 DATA len=0
08:07:32 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=06343e5ad11167 pid=0 DATA len=0
08:07:32 ovpn,debug,packet sent P_ACK kid=0 sid=b29b4bef8a7412e [0 sid=06343e5ad11167] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=69173269c6da415d pid=3 DATA len=1400
08:07:32 ovpn,debug,packet sent P_ACK kid=0 sid=5565e9f2949d117 [3 sid=69173269c6da415d] DATA len=0
08:07:32 ovpn,debug,packet sent P_CONTROL kid=0 sid=5565e9f2949d117 pid=4 DATA len=7
08:07:32 ovpn,debug <200.9.126.102>: disconnected <TLS failed>
08:07:32 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=06343e5ad11167 [0 sid=b29b4bef8a7412e] pid=1 DATA len=0
08:07:32 ovpn,debug,packet sent P_ACK kid=0 sid=b29b4bef8a7412e [1 sid=06343e5ad11167] DATA len=0
08:07:32 ovpn,debug,packet sent P_CONTROL kid=0 sid=8646ced2ec8676d6 pid=1 DATA len=1400
08:07:32 ovpn,debug,packet sent P_CONTROL kid=0 sid=8646ced2ec8676d6 pid=2 DATA len=1400
08:07:32 ovpn,debug,packet sent P_CONTROL kid=0 sid=8646ced2ec8676d6 pid=3 DATA len=79
08:07:32 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=06343e5ad11167 pid=2 DATA len=283
08:07:32 ovpn,debug,packet sent P_ACK kid=0 sid=b29b4bef8a7412e [2 sid=06343e5ad11167] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_ACK kid=0 sid=1cc320937712ccb4 [1 sid=8646ced2ec8676d6] DATA len=0
08:07:32 ovpn,info TCP connection established from 179.102.176.19
08:07:32 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=ed5331c21df28e45 pid=0 DATA len=0
08:07:32 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=e8193b66bb7878ad pid=0 DATA len=0
08:07:32 ovpn,debug,packet sent P_ACK kid=0 sid=ed5331c21df28e45 [0 sid=e8193b66bb7878ad] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_ACK kid=0 sid=1cc320937712ccb4 [2 sid=8646ced2ec8676d6] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=e8193b66bb7878ad [0 sid=ed5331c21df28e45] pid=1 DATA len=0
08:07:32 ovpn,debug,packet sent P_ACK kid=0 sid=ed5331c21df28e45 [1 sid=e8193b66bb7878ad] DATA len=0
08:07:32 ovpn,info TCP connection established from 187.2.142.65
08:07:32 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=80b67ffa3cac63b pid=0 DATA len=0
08:07:32 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=086b143a43b97d7b pid=0 DATA len=0
08:07:32 ovpn,debug,packet sent P_ACK kid=0 sid=80b67ffa3cac63b [0 sid=086b143a43b97d7b] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=086b143a43b97d7b [0 sid=80b67ffa3cac63b] pid=1 DATA len=0
08:07:32 ovpn,debug,packet sent P_ACK kid=0 sid=80b67ffa3cac63b [1 sid=086b143a43b97d7b] DATA len=0
08:07:32 ovpn,debug,packet sent P_CONTROL kid=0 sid=b29b4bef8a7412e pid=1 DATA len=1400
08:07:32 ovpn,debug,packet sent P_CONTROL kid=0 sid=b29b4bef8a7412e pid=2 DATA len=1400
08:07:32 ovpn,debug,packet sent P_CONTROL kid=0 sid=b29b4bef8a7412e pid=3 DATA len=79
08:07:32 ovpn,debug,packet rcvd P_ACK kid=0 sid=1cc320937712ccb4 [3 sid=8646ced2ec8676d6] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=086b143a43b97d7b pid=2 DATA len=283
08:07:32 ovpn,debug,packet sent P_ACK kid=0 sid=80b67ffa3cac63b [2 sid=086b143a43b97d7b] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=e8193b66bb7878ad pid=2 DATA len=283
08:07:32 ovpn,debug,packet sent P_ACK kid=0 sid=ed5331c21df28e45 [2 sid=e8193b66bb7878ad] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_ACK kid=0 sid=06343e5ad11167 [1 sid=b29b4bef8a7412e] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=187595216dfd64 pid=3 DATA len=1400
08:07:32 ovpn,debug,packet sent P_ACK kid=0 sid=54aaa02b4dad9386 [3 sid=187595216dfd64] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_ACK kid=0 sid=06343e5ad11167 [2 sid=b29b4bef8a7412e] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_ACK kid=0 sid=06343e5ad11167 [3 sid=b29b4bef8a7412e] DATA len=0
08:07:32 ovpn,debug,packet sent P_CONTROL kid=0 sid=54aaa02b4dad9386 pid=4 DATA len=7
08:07:32 ovpn,debug <179.150.174.205>: disconnected <TLS failed>
08:07:32 ovpn,debug,packet sent P_CONTROL kid=0 sid=80b67ffa3cac63b pid=1 DATA len=1400
08:07:32 ovpn,debug,packet sent P_CONTROL kid=0 sid=80b67ffa3cac63b pid=2 DATA len=1400
08:07:32 ovpn,debug,packet sent P_CONTROL kid=0 sid=80b67ffa3cac63b pid=3 DATA len=79
08:07:32 ovpn,debug,packet sent P_CONTROL kid=0 sid=ed5331c21df28e45 pid=1 DATA len=1400
08:07:32 ovpn,debug,packet sent P_CONTROL kid=0 sid=ed5331c21df28e45 pid=2 DATA len=1400
08:07:32 ovpn,debug,packet sent P_CONTROL kid=0 sid=ed5331c21df28e45 pid=3 DATA len=79
08:07:32 ovpn,debug,packet rcvd P_ACK kid=0 sid=086b143a43b97d7b [1 sid=80b67ffa3cac63b] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_ACK kid=0 sid=e8193b66bb7878ad [1 sid=ed5331c21df28e45] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_ACK kid=0 sid=086b143a43b97d7b [2 sid=80b67ffa3cac63b] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_ACK kid=0 sid=086b143a43b97d7b [3 sid=80b67ffa3cac63b] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_ACK kid=0 sid=e8193b66bb7878ad [2 sid=ed5331c21df28e45] DATA len=0
08:07:32 ovpn,debug,packet rcvd P_ACK kid=0 sid=e8193b66bb7878ad [3 sid=ed5331c21df28e45] DATA len=0
08:07:33 ovpn,info TCP connection established from 189.84.177.130
08:07:33 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=892e5fca95b2a79 pid=0 DATA len=0
08:07:33 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=251d228a7984e173 pid=0 DATA len=0
08:07:33 ovpn,debug,packet sent P_ACK kid=0 sid=892e5fca95b2a79 [0 sid=251d228a7984e173] DATA len=0
08:07:33 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=251d228a7984e173 [0 sid=892e5fca95b2a79] pid=1 DATA len=0
08:07:33 ovpn,debug,packet sent P_ACK kid=0 sid=892e5fca95b2a79 [1 sid=251d228a7984e173] DATA len=0
08:07:33 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=251d228a7984e173 pid=2 DATA len=283
08:07:33 ovpn,debug,packet sent P_ACK kid=0 sid=892e5fca95b2a79 [2 sid=251d228a7984e173] DATA len=0
08:07:33 ovpn,debug,packet sent P_CONTROL kid=0 sid=892e5fca95b2a79 pid=1 DATA len=1400
08:07:33 ovpn,debug,packet sent P_CONTROL kid=0 sid=892e5fca95b2a79 pid=2 DATA len=1400
08:07:33 ovpn,debug,packet sent P_CONTROL kid=0 sid=892e5fca95b2a79 pid=3 DATA len=79
08:07:33 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=1cc320937712ccb4 pid=3 DATA len=1400
08:07:33 ovpn,debug,packet sent P_ACK kid=0 sid=8646ced2ec8676d6 [3 sid=1cc320937712ccb4] DATA len=0
08:07:33 ovpn,debug,packet sent P_CONTROL kid=0 sid=8646ced2ec8676d6 pid=4 DATA len=7
08:07:33 ovpn,debug <187.68.131.100>: disconnected <TLS failed>
08:07:33 ovpn,debug,packet rcvd P_ACK kid=0 sid=251d228a7984e173 [1 sid=892e5fca95b2a79] DATA len=0
08:07:33 ovpn,debug,packet rcvd P_ACK kid=0 sid=251d228a7984e173 [2 sid=892e5fca95b2a79] DATA len=0
08:07:33 ovpn,debug,packet rcvd P_ACK kid=0 sid=251d228a7984e173 [3 sid=892e5fca95b2a79] DATA len=0
08:07:33 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=06343e5ad11167 pid=3 DATA len=1400
08:07:33 ovpn,debug,packet sent P_ACK kid=0 sid=b29b4bef8a7412e [3 sid=06343e5ad11167] DATA len=0
08:07:33 ovpn,debug,packet sent P_CONTROL kid=0 sid=b29b4bef8a7412e pid=4 DATA len=7
08:07:33 ovpn,debug <189.93.154.204>: disconnected <TLS failed>
08:07:34 ovpn,info TCP connection established from 191.11.230.207
08:07:34 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=f5464f4e9b3f16e4 pid=0 DATA len=0
08:07:34 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=4657b9c7f3d814cf pid=0 DATA len=0
08:07:34 ovpn,debug,packet sent P_ACK kid=0 sid=f5464f4e9b3f16e4 [0 sid=4657b9c7f3d814cf] DATA len=0
08:07:34 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=4657b9c7f3d814cf [0 sid=f5464f4e9b3f16e4] pid=1 DATA len=0
08:07:34 ovpn,debug,packet sent P_ACK kid=0 sid=f5464f4e9b3f16e4 [1 sid=4657b9c7f3d814cf] DATA len=0
08:07:34 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=e8193b66bb7878ad pid=3 DATA len=1400
08:07:34 ovpn,debug,packet sent P_ACK kid=0 sid=ed5331c21df28e45 [3 sid=e8193b66bb7878ad] DATA len=0
08:07:34 ovpn,debug,packet sent P_CONTROL kid=0 sid=ed5331c21df28e45 pid=4 DATA len=7
08:07:34 ovpn,debug <179.102.176.19>: disconnected <TLS failed>
08:07:34 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=4657b9c7f3d814cf pid=2 DATA len=283
08:07:34 ovpn,debug,packet sent P_ACK kid=0 sid=f5464f4e9b3f16e4 [2 sid=4657b9c7f3d814cf] DATA len=0
08:07:34 ovpn,debug,packet sent P_CONTROL kid=0 sid=f5464f4e9b3f16e4 pid=1 DATA len=1400
08:07:34 ovpn,debug,packet sent P_CONTROL kid=0 sid=f5464f4e9b3f16e4 pid=2 DATA len=1400
08:07:34 ovpn,debug,packet sent P_CONTROL kid=0 sid=f5464f4e9b3f16e4 pid=3 DATA len=79
08:07:34 ovpn,debug,packet rcvd P_ACK kid=0 sid=4657b9c7f3d814cf [1 sid=f5464f4e9b3f16e4] DATA len=0
08:07:34 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=086b143a43b97d7b pid=3 DATA len=1400
08:07:34 ovpn,debug,packet sent P_ACK kid=0 sid=80b67ffa3cac63b [3 sid=086b143a43b97d7b] DATA len=0
08:07:34 ovpn,debug,packet rcvd P_ACK kid=0 sid=4657b9c7f3d814cf [2 sid=f5464f4e9b3f16e4] DATA len=0
08:07:34 ovpn,debug,packet rcvd P_ACK kid=0 sid=4657b9c7f3d814cf [3 sid=f5464f4e9b3f16e4] DATA len=0
08:07:34 ovpn,debug,packet sent P_CONTROL kid=0 sid=80b67ffa3cac63b pid=4 DATA len=7
08:07:34 ovpn,debug <187.2.142.65>: disconnected <TLS failed>
08:07:34 ovpn,info TCP connection established from 191.207.231.204
08:07:34 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=a24fed3112bc59f pid=0 DATA len=0
08:07:34 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=cf3fdd67b61f7fc pid=0 DATA len=0
08:07:34 ovpn,debug,packet sent P_ACK kid=0 sid=a24fed3112bc59f [0 sid=cf3fdd67b61f7fc] DATA len=0
08:07:34 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=cf3fdd67b61f7fc [0 sid=a24fed3112bc59f] pid=1 DATA len=0
08:07:34 ovpn,debug,packet sent P_ACK kid=0 sid=a24fed3112bc59f [1 sid=cf3fdd67b61f7fc] DATA len=0
08:07:34 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=cf3fdd67b61f7fc pid=2 DATA len=283
08:07:34 ovpn,debug,packet sent P_ACK kid=0 sid=a24fed3112bc59f [2 sid=cf3fdd67b61f7fc] DATA len=0
08:07:35 ovpn,debug,packet sent P_CONTROL kid=0 sid=a24fed3112bc59f pid=1 DATA len=1400
08:07:35 ovpn,debug,packet sent P_CONTROL kid=0 sid=a24fed3112bc59f pid=2 DATA len=1400
08:07:35 ovpn,debug,packet sent P_CONTROL kid=0 sid=a24fed3112bc59f pid=3 DATA len=79
08:07:35 ovpn,debug,packet rcvd P_ACK kid=0 sid=cf3fdd67b61f7fc [1 sid=a24fed3112bc59f] DATA len=0
08:07:35 ovpn,debug,packet rcvd P_ACK kid=0 sid=cf3fdd67b61f7fc [2 sid=a24fed3112bc59f] DATA len=0
08:07:35 ovpn,debug,packet rcvd P_ACK kid=0 sid=cf3fdd67b61f7fc [3 sid=a24fed3112bc59f] DATA len=0
08:07:35 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=251d228a7984e173 pid=3 DATA len=1400
08:07:35 ovpn,debug,packet sent P_ACK kid=0 sid=892e5fca95b2a79 [3 sid=251d228a7984e173] DATA len=0
08:07:35 ovpn,debug,packet sent P_CONTROL kid=0 sid=892e5fca95b2a79 pid=4 DATA len=7
08:07:35 ovpn,debug <189.84.177.130>: disconnected <TLS failed>
08:07:35 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=4657b9c7f3d814cf pid=3 DATA len=1400
08:07:35 ovpn,debug,packet sent P_ACK kid=0 sid=f5464f4e9b3f16e4 [3 sid=4657b9c7f3d814cf] DATA len=0
08:07:35 ovpn,debug,packet sent P_CONTROL kid=0 sid=f5464f4e9b3f16e4 pid=4 DATA len=7
08:07:35 ovpn,debug <191.11.230.207>: disconnected <TLS failed>
08:07:36 ovpn,info TCP connection established from 191.11.243.178
08:07:36 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=c3476313cb6ba8f8 pid=0 DATA len=0
08:07:36 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=2e77d1d1c0b880dc pid=0 DATA len=0
08:07:36 ovpn,debug,packet sent P_ACK kid=0 sid=c3476313cb6ba8f8 [0 sid=2e77d1d1c0b880dc] DATA len=0
08:07:36 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=2e77d1d1c0b880dc [0 sid=c3476313cb6ba8f8] pid=1 DATA len=0
08:07:36 ovpn,debug,packet sent P_ACK kid=0 sid=c3476313cb6ba8f8 [1 sid=2e77d1d1c0b880dc] DATA len=0
08:07:36 ovpn,info TCP connection established from 179.242.106.114
08:07:36 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=4dfe11ac3485df1c pid=0 DATA len=0
08:07:36 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=2e77d1d1c0b880dc pid=2 DATA len=283
08:07:36 ovpn,debug,packet sent P_ACK kid=0 sid=c3476313cb6ba8f8 [2 sid=2e77d1d1c0b880dc] DATA len=0
08:07:36 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=cf3fdd67b61f7fc pid=3 DATA len=1400
08:07:36 ovpn,debug,packet sent P_ACK kid=0 sid=a24fed3112bc59f [3 sid=cf3fdd67b61f7fc] DATA len=0
08:07:36 ovpn,debug,packet sent P_CONTROL kid=0 sid=a24fed3112bc59f pid=4 DATA len=7
08:07:36 ovpn,debug <191.207.231.204>: disconnected <TLS failed>
08:07:36 ovpn,debug,packet sent P_CONTROL kid=0 sid=c3476313cb6ba8f8 pid=1 DATA len=1400
08:07:36 ovpn,debug,packet sent P_CONTROL kid=0 sid=c3476313cb6ba8f8 pid=2 DATA len=1400
08:07:36 ovpn,debug,packet sent P_CONTROL kid=0 sid=c3476313cb6ba8f8 pid=3 DATA len=79
08:07:36 ovpn,debug,packet rcvd P_ACK kid=0 sid=2e77d1d1c0b880dc [1 sid=c3476313cb6ba8f8] DATA len=0
08:07:36 ovpn,debug,packet rcvd P_ACK kid=0 sid=2e77d1d1c0b880dc [2 sid=c3476313cb6ba8f8] DATA len=0
08:07:36 ovpn,debug,packet rcvd P_ACK kid=0 sid=2e77d1d1c0b880dc [3 sid=c3476313cb6ba8f8] DATA len=0
08:07:37 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=da77436584aea9ee pid=0 DATA len=0
08:07:37 ovpn,debug,packet sent P_ACK kid=0 sid=4dfe11ac3485df1c [0 sid=da77436584aea9ee] DATA len=0
08:07:38 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=2e77d1d1c0b880dc pid=3 DATA len=1400
08:07:38 ovpn,debug,packet sent P_ACK kid=0 sid=c3476313cb6ba8f8 [3 sid=2e77d1d1c0b880dc] DATA len=0
08:07:38 ovpn,debug,packet sent P_CONTROL kid=0 sid=c3476313cb6ba8f8 pid=4 DATA len=7
08:07:38 ovpn,debug <191.11.243.178>: disconnected <TLS failed>
08:07:38 ovpn,info TCP connection established from 187.68.245.99
08:07:38 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=987ac7603919edc pid=0 DATA len=0
08:07:38 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=407b6dceee69982 pid=0 DATA len=0
08:07:38 ovpn,debug,packet sent P_ACK kid=0 sid=987ac7603919edc [0 sid=407b6dceee69982] DATA len=0
08:07:38 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=407b6dceee69982 [0 sid=987ac7603919edc] pid=1 DATA len=0
08:07:38 ovpn,debug,packet sent P_ACK kid=0 sid=987ac7603919edc [1 sid=407b6dceee69982] DATA len=0
08:07:38 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=407b6dceee69982 pid=2 DATA len=283
08:07:38 ovpn,debug,packet sent P_ACK kid=0 sid=987ac7603919edc [2 sid=407b6dceee69982] DATA len=0
08:07:38 ovpn,debug,packet sent P_CONTROL kid=0 sid=987ac7603919edc pid=1 DATA len=1400
08:07:38 ovpn,debug,packet sent P_CONTROL kid=0 sid=987ac7603919edc pid=2 DATA len=1400
08:07:38 ovpn,debug,packet sent P_CONTROL kid=0 sid=987ac7603919edc pid=3 DATA len=79
08:07:38 ovpn,debug,packet rcvd P_ACK kid=0 sid=407b6dceee69982 [1 sid=987ac7603919edc] DATA len=0
08:07:38 ovpn,debug,packet rcvd P_ACK kid=0 sid=407b6dceee69982 [2 sid=987ac7603919edc] DATA len=0
08:07:38 ovpn,debug,packet rcvd P_ACK kid=0 sid=407b6dceee69982 [3 sid=987ac7603919edc] DATA len=0
08:07:39 ovpn,info TCP connection established from 187.69.86.246
08:07:39 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=437e1d4a7ec01444 pid=0 DATA len=0
08:07:39 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=f3f6496196e55373 pid=0 DATA len=0
08:07:39 ovpn,debug,packet sent P_ACK kid=0 sid=437e1d4a7ec01444 [0 sid=f3f6496196e55373] DATA len=0
08:07:39 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=f3f6496196e55373 [0 sid=437e1d4a7ec01444] pid=1 DATA len=0
08:07:39 ovpn,debug,packet sent P_ACK kid=0 sid=437e1d4a7ec01444 [1 sid=f3f6496196e55373] DATA len=0
08:07:39 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=f3f6496196e55373 pid=2 DATA len=283
08:07:39 ovpn,debug,packet sent P_ACK kid=0 sid=437e1d4a7ec01444 [2 sid=f3f6496196e55373] DATA len=0
08:07:39 ovpn,info TCP connection established from 187.68.106.119
08:07:39 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=1a6f0bba2ea33f pid=0 DATA len=0
08:07:39 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=53ba9b9891f3840 pid=0 DATA len=0
08:07:39 ovpn,debug,packet sent P_ACK kid=0 sid=1a6f0bba2ea33f [0 sid=53ba9b9891f3840] DATA len=0
08:07:39 ovpn,debug,packet sent P_CONTROL kid=0 sid=437e1d4a7ec01444 pid=1 DATA len=1400
08:07:39 ovpn,debug,packet sent P_CONTROL kid=0 sid=437e1d4a7ec01444 pid=2 DATA len=1400
08:07:39 ovpn,debug,packet sent P_CONTROL kid=0 sid=437e1d4a7ec01444 pid=3 DATA len=79
08:07:39 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=53ba9b9891f3840 [0 sid=1a6f0bba2ea33f] pid=1 DATA len=0
08:07:39 ovpn,debug,packet sent P_ACK kid=0 sid=1a6f0bba2ea33f [1 sid=53ba9b9891f3840] DATA len=0
08:07:39 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=53ba9b9891f3840 pid=2 DATA len=283
08:07:39 ovpn,debug,packet sent P_ACK kid=0 sid=1a6f0bba2ea33f [2 sid=53ba9b9891f3840] DATA len=0
08:07:39 ovpn,debug,packet rcvd P_ACK kid=0 sid=f3f6496196e55373 [1 sid=437e1d4a7ec01444] DATA len=0
08:07:39 ovpn,debug,packet rcvd P_ACK kid=0 sid=f3f6496196e55373 [2 sid=437e1d4a7ec01444] DATA len=0
08:07:39 ovpn,debug,packet rcvd P_ACK kid=0 sid=f3f6496196e55373 [3 sid=437e1d4a7ec01444] DATA len=0
08:07:39 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=407b6dceee69982 pid=3 DATA len=1400
08:07:39 ovpn,debug,packet sent P_ACK kid=0 sid=987ac7603919edc [3 sid=407b6dceee69982] DATA len=0
08:07:39 ovpn,debug,packet sent P_CONTROL kid=0 sid=987ac7603919edc pid=4 DATA len=7
08:07:39 ovpn,debug <187.68.245.99>: disconnected <TLS failed>
08:07:39 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=da77436584aea9ee [0 sid=4dfe11ac3485df1c] pid=1 DATA len=0
08:07:39 ovpn,debug,packet sent P_ACK kid=0 sid=4dfe11ac3485df1c [1 sid=da77436584aea9ee] DATA len=0
08:07:39 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=da77436584aea9ee pid=2 DATA len=283
08:07:39 ovpn,debug,packet sent P_ACK kid=0 sid=4dfe11ac3485df1c [2 sid=da77436584aea9ee] DATA len=0
08:07:39 ovpn,debug,packet sent P_CONTROL kid=0 sid=1a6f0bba2ea33f pid=1 DATA len=1400
08:07:39 ovpn,debug,packet sent P_CONTROL kid=0 sid=1a6f0bba2ea33f pid=2 DATA len=1400
08:07:39 ovpn,debug,packet sent P_CONTROL kid=0 sid=1a6f0bba2ea33f pid=3 DATA len=79
08:07:39 ovpn,debug,packet rcvd P_ACK kid=0 sid=53ba9b9891f3840 [1 sid=1a6f0bba2ea33f] DATA len=0
08:07:40 ovpn,debug,packet sent P_CONTROL kid=0 sid=4dfe11ac3485df1c pid=1 DATA len=1400
08:07:40 ovpn,debug,packet sent P_CONTROL kid=0 sid=4dfe11ac3485df1c pid=2 DATA len=1400
08:07:40 ovpn,debug,packet sent P_CONTROL kid=0 sid=4dfe11ac3485df1c pid=3 DATA len=79
08:07:40 ovpn,debug,packet rcvd P_ACK kid=0 sid=da77436584aea9ee [1 sid=4dfe11ac3485df1c] DATA len=0
08:07:40 ovpn,debug,packet rcvd P_ACK kid=0 sid=da77436584aea9ee [2 sid=4dfe11ac3485df1c] DATA len=0
08:07:40 ovpn,debug,packet rcvd P_ACK kid=0 sid=da77436584aea9ee [3 sid=4dfe11ac3485df1c] DATA len=0
08:07:40 ovpn,debug,packet rcvd P_ACK kid=0 sid=53ba9b9891f3840 [2 sid=1a6f0bba2ea33f] DATA len=0
08:07:40 ovpn,debug,packet rcvd P_ACK kid=0 sid=53ba9b9891f3840 [3 sid=1a6f0bba2ea33f] DATA len=0
08:07:41 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=f3f6496196e55373 pid=3 DATA len=1400
08:07:41 ovpn,debug,packet sent P_ACK kid=0 sid=437e1d4a7ec01444 [3 sid=f3f6496196e55373] DATA len=0
08:07:41 ovpn,debug,packet sent P_CONTROL kid=0 sid=437e1d4a7ec01444 pid=4 DATA len=7
08:07:41 ovpn,debug <187.69.86.246>: disconnected <TLS failed>
08:07:41 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=53ba9b9891f3840 pid=3 DATA len=1400
08:07:41 ovpn,debug,packet sent P_ACK kid=0 sid=1a6f0bba2ea33f [3 sid=53ba9b9891f3840] DATA len=0
08:07:41 ovpn,info TCP connection established from 191.207.207.17
08:07:41 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=fb7054aa2a6ebed6 pid=0 DATA len=0
08:07:41 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=e9f6dea94ffd376c pid=0 DATA len=0
08:07:41 ovpn,debug,packet sent P_ACK kid=0 sid=fb7054aa2a6ebed6 [0 sid=e9f6dea94ffd376c] DATA len=0
08:07:41 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=e9f6dea94ffd376c [0 sid=fb7054aa2a6ebed6] pid=1 DATA len=0
08:07:41 ovpn,debug,packet sent P_ACK kid=0 sid=fb7054aa2a6ebed6 [1 sid=e9f6dea94ffd376c] DATA len=0
08:07:41 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=e9f6dea94ffd376c pid=2 DATA len=283
08:07:41 ovpn,debug,packet sent P_ACK kid=0 sid=fb7054aa2a6ebed6 [2 sid=e9f6dea94ffd376c] DATA len=0
08:07:41 ovpn,debug,packet sent P_CONTROL kid=0 sid=fb7054aa2a6ebed6 pid=1 DATA len=1400
08:07:41 ovpn,debug,packet sent P_CONTROL kid=0 sid=fb7054aa2a6ebed6 pid=2 DATA len=1400
08:07:41 ovpn,debug,packet sent P_CONTROL kid=0 sid=fb7054aa2a6ebed6 pid=3 DATA len=79
08:07:41 ovpn,debug,packet rcvd P_ACK kid=0 sid=e9f6dea94ffd376c [1 sid=fb7054aa2a6ebed6] DATA len=0
08:07:41 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=53ba9b9891f3840 pid=4 DATA len=1162
08:07:41 ovpn,debug,packet sent P_ACK kid=0 sid=1a6f0bba2ea33f [4 sid=53ba9b9891f3840] DATA len=0
08:07:41 ovpn,debug,packet sent P_CONTROL kid=0 sid=1a6f0bba2ea33f pid=4 DATA len=7
08:07:41 ovpn,debug <187.68.106.119>: disconnected <TLS failed>
08:07:41 ovpn,debug,packet rcvd P_ACK kid=0 sid=e9f6dea94ffd376c [2 sid=fb7054aa2a6ebed6] DATA len=0
08:07:41 ovpn,debug,packet rcvd P_ACK kid=0 sid=e9f6dea94ffd376c [3 sid=fb7054aa2a6ebed6] DATA len=0
08:07:41 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=da77436584aea9ee pid=3 DATA len=1400
08:07:41 ovpn,debug,packet sent P_ACK kid=0 sid=4dfe11ac3485df1c [3 sid=da77436584aea9ee] DATA len=0
08:07:41 ovpn,debug,packet sent P_CONTROL kid=0 sid=4dfe11ac3485df1c pid=4 DATA len=7
08:07:41 ovpn,debug <179.242.106.114>: disconnected <TLS failed>
08:07:42 ovpn,info TCP connection established from 200.9.126.102
08:07:42 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=291959d386d7a8a4 pid=0 DATA len=0
08:07:42 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=5e4ce2a334c532d3 pid=0 DATA len=0
08:07:42 ovpn,debug,packet sent P_ACK kid=0 sid=291959d386d7a8a4 [0 sid=5e4ce2a334c532d3] DATA len=0
08:07:42 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=5e4ce2a334c532d3 [0 sid=291959d386d7a8a4] pid=1 DATA len=0
08:07:42 ovpn,debug,packet sent P_ACK kid=0 sid=291959d386d7a8a4 [1 sid=5e4ce2a334c532d3] DATA len=0
08:07:42 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=5e4ce2a334c532d3 pid=2 DATA len=283
08:07:42 ovpn,debug,packet sent P_ACK kid=0 sid=291959d386d7a8a4 [2 sid=5e4ce2a334c532d3] DATA len=0
08:07:42 ovpn,debug,packet sent P_CONTROL kid=0 sid=291959d386d7a8a4 pid=1 DATA len=1400
08:07:42 ovpn,debug,packet sent P_CONTROL kid=0 sid=291959d386d7a8a4 pid=2 DATA len=1400
08:07:42 ovpn,debug,packet sent P_CONTROL kid=0 sid=291959d386d7a8a4 pid=3 DATA len=79
08:07:42 ovpn,debug,packet rcvd P_ACK kid=0 sid=5e4ce2a334c532d3 [1 sid=291959d386d7a8a4] DATA len=0
08:07:42 ovpn,debug,packet rcvd P_ACK kid=0 sid=5e4ce2a334c532d3 [2 sid=291959d386d7a8a4] DATA len=0
08:07:42 ovpn,debug,packet rcvd P_ACK kid=0 sid=5e4ce2a334c532d3 [3 sid=291959d386d7a8a4] DATA len=0
08:07:42 ovpn,info TCP connection established from 179.150.174.205
08:07:42 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=4f99b79ede6ac1b1 pid=0 DATA len=0
08:07:42 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=ef8d8e207391b6e pid=0 DATA len=0
08:07:42 ovpn,debug,packet sent P_ACK kid=0 sid=4f99b79ede6ac1b1 [0 sid=ef8d8e207391b6e] DATA len=0
08:07:42 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=ef8d8e207391b6e [0 sid=4f99b79ede6ac1b1] pid=1 DATA len=0
08:07:42 ovpn,debug,packet sent P_ACK kid=0 sid=4f99b79ede6ac1b1 [1 sid=ef8d8e207391b6e] DATA len=0
08:07:42 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=e9f6dea94ffd376c pid=3 DATA len=1400
08:07:42 ovpn,debug,packet sent P_ACK kid=0 sid=fb7054aa2a6ebed6 [3 sid=e9f6dea94ffd376c] DATA len=0
08:07:42 ovpn,debug,packet sent P_CONTROL kid=0 sid=fb7054aa2a6ebed6 pid=4 DATA len=7
08:07:42 ovpn,debug <191.207.207.17>: disconnected <TLS failed>
08:07:42 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=ef8d8e207391b6e pid=2 DATA len=283
08:07:42 ovpn,debug,packet sent P_ACK kid=0 sid=4f99b79ede6ac1b1 [2 sid=ef8d8e207391b6e] DATA len=0
08:07:43 ovpn,debug,packet sent P_CONTROL kid=0 sid=4f99b79ede6ac1b1 pid=1 DATA len=1400
08:07:43 ovpn,debug,packet sent P_CONTROL kid=0 sid=4f99b79ede6ac1b1 pid=2 DATA len=1400
08:07:43 ovpn,debug,packet sent P_CONTROL kid=0 sid=4f99b79ede6ac1b1 pid=3 DATA len=79
08:07:43 ovpn,debug,packet rcvd P_ACK kid=0 sid=ef8d8e207391b6e [1 sid=4f99b79ede6ac1b1] DATA len=0
08:07:43 ovpn,debug,packet rcvd P_ACK kid=0 sid=ef8d8e207391b6e [2 sid=4f99b79ede6ac1b1] DATA len=0
08:07:43 ovpn,debug,packet rcvd P_ACK kid=0 sid=ef8d8e207391b6e [3 sid=4f99b79ede6ac1b1] DATA len=0
08:07:43 ovpn,info TCP connection established from 187.68.131.100
08:07:43 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=1547f414e72e144f pid=0 DATA len=0
08:07:43 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=2c9fc46da64ab716 pid=0 DATA len=0
08:07:43 ovpn,debug,packet sent P_ACK kid=0 sid=1547f414e72e144f [0 sid=2c9fc46da64ab716] DATA len=0
08:07:43 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=2c9fc46da64ab716 [0 sid=1547f414e72e144f] pid=1 DATA len=0
08:07:43 ovpn,debug,packet sent P_ACK kid=0 sid=1547f414e72e144f [1 sid=2c9fc46da64ab716] DATA len=0
08:07:43 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=2c9fc46da64ab716 pid=2 DATA len=283
08:07:43 ovpn,debug,packet sent P_ACK kid=0 sid=1547f414e72e144f [2 sid=2c9fc46da64ab716] DATA len=0
08:07:43 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=5e4ce2a334c532d3 pid=3 DATA len=1400
08:07:43 ovpn,debug,packet sent P_ACK kid=0 sid=291959d386d7a8a4 [3 sid=5e4ce2a334c532d3] DATA len=0
08:07:43 ovpn,debug,packet sent P_CONTROL kid=0 sid=291959d386d7a8a4 pid=4 DATA len=7
08:07:43 ovpn,debug <200.9.126.102>: disconnected <TLS failed>
08:07:44 ovpn,info TCP connection established from 189.93.154.204
08:07:44 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=fd4c7d1283d0a916 pid=0 DATA len=0
08:07:44 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=bc6ccdb796e87589 pid=0 DATA len=0
08:07:44 ovpn,debug,packet sent P_ACK kid=0 sid=fd4c7d1283d0a916 [0 sid=bc6ccdb796e87589] DATA len=0
08:07:44 ovpn,debug,packet sent P_CONTROL kid=0 sid=1547f414e72e144f pid=1 DATA len=1400
08:07:44 ovpn,debug,packet sent P_CONTROL kid=0 sid=1547f414e72e144f pid=2 DATA len=1400
08:07:44 ovpn,debug,packet sent P_CONTROL kid=0 sid=1547f414e72e144f pid=3 DATA len=79
08:07:44 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=bc6ccdb796e87589 [0 sid=fd4c7d1283d0a916] pid=1 DATA len=0
08:07:44 ovpn,debug,packet sent P_ACK kid=0 sid=fd4c7d1283d0a916 [1 sid=bc6ccdb796e87589] DATA len=0
08:07:44 ovpn,debug,packet rcvd P_ACK kid=0 sid=2c9fc46da64ab716 [1 sid=1547f414e72e144f] DATA len=0
08:07:44 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=bc6ccdb796e87589 pid=2 DATA len=283
08:07:44 ovpn,debug,packet sent P_ACK kid=0 sid=fd4c7d1283d0a916 [2 sid=bc6ccdb796e87589] DATA len=0
08:07:44 ovpn,debug,packet rcvd P_ACK kid=0 sid=2c9fc46da64ab716 [2 sid=1547f414e72e144f] DATA len=0
08:07:44 ovpn,debug,packet rcvd P_ACK kid=0 sid=2c9fc46da64ab716 [3 sid=1547f414e72e144f] DATA len=0
08:07:44 ovpn,debug,packet sent P_CONTROL kid=0 sid=fd4c7d1283d0a916 pid=1 DATA len=1400
08:07:44 ovpn,debug,packet sent P_CONTROL kid=0 sid=fd4c7d1283d0a916 pid=2 DATA len=1400
08:07:44 ovpn,debug,packet sent P_CONTROL kid=0 sid=fd4c7d1283d0a916 pid=3 DATA len=79
08:07:44 ovpn,debug,packet rcvd P_ACK kid=0 sid=bc6ccdb796e87589 [1 sid=fd4c7d1283d0a916] DATA len=0
08:07:44 ovpn,info TCP connection established from 179.102.176.19
08:07:44 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=55f4a02c683acbc0 pid=0 DATA len=0
08:07:44 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=638645bf9ec9a8ed pid=0 DATA len=0
08:07:44 ovpn,debug,packet sent P_ACK kid=0 sid=55f4a02c683acbc0 [0 sid=638645bf9ec9a8ed] DATA len=0
08:07:44 ovpn,debug,packet rcvd P_ACK kid=0 sid=bc6ccdb796e87589 [2 sid=fd4c7d1283d0a916] DATA len=0
08:07:44 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=638645bf9ec9a8ed [0 sid=55f4a02c683acbc0] pid=1 DATA len=0
08:07:44 ovpn,debug,packet sent P_ACK kid=0 sid=55f4a02c683acbc0 [1 sid=638645bf9ec9a8ed] DATA len=0
08:07:44 ovpn,debug,packet rcvd P_ACK kid=0 sid=bc6ccdb796e87589 [3 sid=fd4c7d1283d0a916] DATA len=0
08:07:44 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=638645bf9ec9a8ed pid=2 DATA len=283
08:07:44 ovpn,debug,packet sent P_ACK kid=0 sid=55f4a02c683acbc0 [2 sid=638645bf9ec9a8ed] DATA len=0
08:07:44 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=ef8d8e207391b6e pid=3 DATA len=1400
08:07:44 ovpn,debug,packet sent P_ACK kid=0 sid=4f99b79ede6ac1b1 [3 sid=ef8d8e207391b6e] DATA len=0
08:07:44 ovpn,debug,packet sent P_CONTROL kid=0 sid=4f99b79ede6ac1b1 pid=4 DATA len=7
08:07:44 ovpn,debug <179.150.174.205>: disconnected <TLS failed>
08:07:44 ovpn,info TCP connection established from 187.2.142.65
08:07:44 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=5dfea9193936b4b pid=0 DATA len=0
08:07:44 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=1b22e2a6a4b6b322 pid=0 DATA len=0
08:07:44 ovpn,debug,packet sent P_ACK kid=0 sid=5dfea9193936b4b [0 sid=1b22e2a6a4b6b322] DATA len=0
08:07:44 ovpn,debug,packet sent P_CONTROL kid=0 sid=55f4a02c683acbc0 pid=1 DATA len=1400
08:07:44 ovpn,debug,packet sent P_CONTROL kid=0 sid=55f4a02c683acbc0 pid=2 DATA len=1400
08:07:44 ovpn,debug,packet sent P_CONTROL kid=0 sid=55f4a02c683acbc0 pid=3 DATA len=79
08:07:44 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=1b22e2a6a4b6b322 [0 sid=5dfea9193936b4b] pid=1 DATA len=0
08:07:44 ovpn,debug,packet sent P_ACK kid=0 sid=5dfea9193936b4b [1 sid=1b22e2a6a4b6b322] DATA len=0
08:07:44 ovpn,debug,packet rcvd P_ACK kid=0 sid=638645bf9ec9a8ed [1 sid=55f4a02c683acbc0] DATA len=0
08:07:44 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=1b22e2a6a4b6b322 pid=2 DATA len=283
08:07:44 ovpn,debug,packet sent P_ACK kid=0 sid=5dfea9193936b4b [2 sid=1b22e2a6a4b6b322] DATA len=0
08:07:45 ovpn,debug,packet rcvd P_ACK kid=0 sid=638645bf9ec9a8ed [2 sid=55f4a02c683acbc0] DATA len=0
08:07:45 ovpn,debug,packet rcvd P_ACK kid=0 sid=638645bf9ec9a8ed [3 sid=55f4a02c683acbc0] DATA len=0
08:07:45 ovpn,debug,packet sent P_CONTROL kid=0 sid=5dfea9193936b4b pid=1 DATA len=1400
08:07:45 ovpn,debug,packet sent P_CONTROL kid=0 sid=5dfea9193936b4b pid=2 DATA len=1400
08:07:45 ovpn,debug,packet sent P_CONTROL kid=0 sid=5dfea9193936b4b pid=3 DATA len=79
08:07:45 ovpn,debug,packet rcvd P_ACK kid=0 sid=1b22e2a6a4b6b322 [1 sid=5dfea9193936b4b] DATA len=0
08:07:45 ovpn,debug,packet rcvd P_ACK kid=0 sid=1b22e2a6a4b6b322 [2 sid=5dfea9193936b4b] DATA len=0
08:07:45 ovpn,debug,packet rcvd P_ACK kid=0 sid=1b22e2a6a4b6b322 [3 sid=5dfea9193936b4b] DATA len=0
08:07:45 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=2c9fc46da64ab716 pid=3 DATA len=1400
08:07:45 ovpn,debug,packet sent P_ACK kid=0 sid=1547f414e72e144f [3 sid=2c9fc46da64ab716] DATA len=0
08:07:45 ovpn,debug,packet sent P_CONTROL kid=0 sid=1547f414e72e144f pid=4 DATA len=7
08:07:45 ovpn,debug <187.68.131.100>: disconnected <TLS failed>
08:07:45 ovpn,info TCP connection established from 189.84.177.130
08:07:45 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=10e01e637f2eaed pid=0 DATA len=0
08:07:45 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=589b60c4f8af43e4 pid=0 DATA len=0
08:07:45 ovpn,debug,packet sent P_ACK kid=0 sid=10e01e637f2eaed [0 sid=589b60c4f8af43e4] DATA len=0
08:07:45 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=589b60c4f8af43e4 [0 sid=10e01e637f2eaed] pid=1 DATA len=0
08:07:45 ovpn,debug,packet sent P_ACK kid=0 sid=10e01e637f2eaed [1 sid=589b60c4f8af43e4] DATA len=0
08:07:45 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=bc6ccdb796e87589 pid=3 DATA len=1400
08:07:45 ovpn,debug,packet sent P_ACK kid=0 sid=fd4c7d1283d0a916 [3 sid=bc6ccdb796e87589] DATA len=0
08:07:45 ovpn,debug,packet sent P_CONTROL kid=0 sid=fd4c7d1283d0a916 pid=4 DATA len=7
08:07:45 ovpn,debug <189.93.154.204>: disconnected <TLS failed>
08:07:45 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=589b60c4f8af43e4 pid=2 DATA len=283
08:07:45 ovpn,debug,packet sent P_ACK kid=0 sid=10e01e637f2eaed [2 sid=589b60c4f8af43e4] DATA len=0
08:07:46 ovpn,info TCP connection established from 191.11.230.207
08:07:46 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=8ff5d05d1d956018 pid=0 DATA len=0
08:07:46 ovpn,debug,packet sent P_CONTROL kid=0 sid=10e01e637f2eaed pid=1 DATA len=1400
08:07:46 ovpn,debug,packet sent P_CONTROL kid=0 sid=10e01e637f2eaed pid=2 DATA len=1400
08:07:46 ovpn,debug,packet sent P_CONTROL kid=0 sid=10e01e637f2eaed pid=3 DATA len=79
08:07:46 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=18a86f10a169573a pid=0 DATA len=0
08:07:46 ovpn,debug,packet sent P_ACK kid=0 sid=8ff5d05d1d956018 [0 sid=18a86f10a169573a] DATA len=0
08:07:46 ovpn,debug,packet rcvd P_ACK kid=0 sid=589b60c4f8af43e4 [1 sid=10e01e637f2eaed] DATA len=0
08:07:46 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=18a86f10a169573a [0 sid=8ff5d05d1d956018] pid=1 DATA len=0
08:07:46 ovpn,debug,packet sent P_ACK kid=0 sid=8ff5d05d1d956018 [1 sid=18a86f10a169573a] DATA len=0
08:07:46 ovpn,debug,packet rcvd P_ACK kid=0 sid=589b60c4f8af43e4 [2 sid=10e01e637f2eaed] DATA len=0
08:07:46 ovpn,debug,packet rcvd P_ACK kid=0 sid=589b60c4f8af43e4 [3 sid=10e01e637f2eaed] DATA len=0
08:07:46 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=638645bf9ec9a8ed pid=3 DATA len=1400
08:07:46 ovpn,debug,packet sent P_ACK kid=0 sid=55f4a02c683acbc0 [3 sid=638645bf9ec9a8ed] DATA len=0
08:07:46 ovpn,debug,packet sent P_CONTROL kid=0 sid=55f4a02c683acbc0 pid=4 DATA len=7
08:07:46 ovpn,debug <179.102.176.19>: disconnected <TLS failed>
08:07:46 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=18a86f10a169573a pid=2 DATA len=283
08:07:46 ovpn,debug,packet sent P_ACK kid=0 sid=8ff5d05d1d956018 [2 sid=18a86f10a169573a] DATA len=0
08:07:46 ovpn,debug,packet sent P_CONTROL kid=0 sid=8ff5d05d1d956018 pid=1 DATA len=1400
08:07:46 ovpn,debug,packet sent P_CONTROL kid=0 sid=8ff5d05d1d956018 pid=2 DATA len=1400
08:07:46 ovpn,debug,packet sent P_CONTROL kid=0 sid=8ff5d05d1d956018 pid=3 DATA len=79
08:07:46 ovpn,debug,packet rcvd P_ACK kid=0 sid=18a86f10a169573a [1 sid=8ff5d05d1d956018] DATA len=0
08:07:46 ovpn,debug,packet rcvd P_ACK kid=0 sid=18a86f10a169573a [2 sid=8ff5d05d1d956018] DATA len=0
08:07:46 ovpn,debug,packet rcvd P_ACK kid=0 sid=18a86f10a169573a [3 sid=8ff5d05d1d956018] DATA len=0
08:07:46 ovpn,info TCP connection established from 191.207.231.204
08:07:46 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=816a1f78d05e66d pid=0 DATA len=0
08:07:46 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=dfc2f80f1efedf7 pid=0 DATA len=0
08:07:46 ovpn,debug,packet sent P_ACK kid=0 sid=816a1f78d05e66d [0 sid=dfc2f80f1efedf7] DATA len=0
08:07:46 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=dfc2f80f1efedf7 [0 sid=816a1f78d05e66d] pid=1 DATA len=0
08:07:46 ovpn,debug,packet sent P_ACK kid=0 sid=816a1f78d05e66d [1 sid=dfc2f80f1efedf7] DATA len=0
08:07:46 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=dfc2f80f1efedf7 pid=2 DATA len=283
08:07:46 ovpn,debug,packet sent P_ACK kid=0 sid=816a1f78d05e66d [2 sid=dfc2f80f1efedf7] DATA len=0
08:07:47 ovpn,debug,packet sent P_CONTROL kid=0 sid=816a1f78d05e66d pid=1 DATA len=1400
08:07:47 ovpn,debug,packet sent P_CONTROL kid=0 sid=816a1f78d05e66d pid=2 DATA len=1400
08:07:47 ovpn,debug,packet sent P_CONTROL kid=0 sid=816a1f78d05e66d pid=3 DATA len=79
08:07:47 ovpn,debug,packet rcvd P_ACK kid=0 sid=dfc2f80f1efedf7 [1 sid=816a1f78d05e66d] DATA len=0
08:07:47 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=1b22e2a6a4b6b322 pid=3 DATA len=1400
08:07:47 ovpn,debug,packet sent P_ACK kid=0 sid=5dfea9193936b4b [3 sid=1b22e2a6a4b6b322] DATA len=0
08:07:47 ovpn,debug,packet sent P_CONTROL kid=0 sid=5dfea9193936b4b pid=4 DATA len=7
08:07:47 ovpn,debug <187.2.142.65>: disconnected <TLS failed>
08:07:47 ovpn,debug,packet rcvd P_ACK kid=0 sid=dfc2f80f1efedf7 [2 sid=816a1f78d05e66d] DATA len=0
08:07:47 ovpn,debug,packet rcvd P_ACK kid=0 sid=dfc2f80f1efedf7 [3 sid=816a1f78d05e66d] DATA len=0
08:07:47 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=18a86f10a169573a pid=3 DATA len=1400
08:07:47 ovpn,debug,packet sent P_ACK kid=0 sid=8ff5d05d1d956018 [3 sid=18a86f10a169573a] DATA len=0
08:07:47 ovpn,debug,packet sent P_CONTROL kid=0 sid=8ff5d05d1d956018 pid=4 DATA len=7
08:07:47 ovpn,debug <191.11.230.207>: disconnected <TLS failed>
08:07:48 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=589b60c4f8af43e4 pid=3 DATA len=1400
08:07:48 ovpn,debug,packet sent P_ACK kid=0 sid=10e01e637f2eaed [3 sid=589b60c4f8af43e4] DATA len=0
08:07:48 ovpn,debug,packet sent P_CONTROL kid=0 sid=10e01e637f2eaed pid=4 DATA len=7
08:07:48 ovpn,debug <189.84.177.130>: disconnected <TLS failed>
08:07:48 ovpn,info TCP connection established from 191.11.243.178
08:07:48 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=e7e66686dfba3069 pid=0 DATA len=0
08:07:48 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=764183f85cb078d2 pid=0 DATA len=0
08:07:48 ovpn,debug,packet sent P_ACK kid=0 sid=e7e66686dfba3069 [0 sid=764183f85cb078d2] DATA len=0
08:07:48 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=764183f85cb078d2 [0 sid=e7e66686dfba3069] pid=1 DATA len=0
08:07:48 ovpn,debug,packet sent P_ACK kid=0 sid=e7e66686dfba3069 [1 sid=764183f85cb078d2] DATA len=0
08:07:48 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=764183f85cb078d2 pid=2 DATA len=283
08:07:48 ovpn,debug,packet sent P_ACK kid=0 sid=e7e66686dfba3069 [2 sid=764183f85cb078d2] DATA len=0
08:07:48 ovpn,debug,packet sent P_CONTROL kid=0 sid=e7e66686dfba3069 pid=1 DATA len=1400
08:07:48 ovpn,debug,packet sent P_CONTROL kid=0 sid=e7e66686dfba3069 pid=2 DATA len=1400
08:07:48 ovpn,debug,packet sent P_CONTROL kid=0 sid=e7e66686dfba3069 pid=3 DATA len=79
08:07:48 ovpn,debug,packet rcvd P_ACK kid=0 sid=764183f85cb078d2 [1 sid=e7e66686dfba3069] DATA len=0
08:07:48 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=dfc2f80f1efedf7 pid=3 DATA len=1400
08:07:48 ovpn,debug,packet sent P_ACK kid=0 sid=816a1f78d05e66d [3 sid=dfc2f80f1efedf7] DATA len=0
08:07:48 ovpn,debug,packet sent P_CONTROL kid=0 sid=816a1f78d05e66d pid=4 DATA len=7
08:07:48 ovpn,debug <191.207.231.204>: disconnected <TLS failed>
08:07:48 ovpn,debug,packet rcvd P_ACK kid=0 sid=764183f85cb078d2 [2 sid=e7e66686dfba3069] DATA len=0
08:07:48 ovpn,debug,packet rcvd P_ACK kid=0 sid=764183f85cb078d2 [3 sid=e7e66686dfba3069] DATA len=0
08:07:49 ovpn,info TCP connection established from 185.235.244.244
08:07:49 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=e51d1619664e0cb pid=0 DATA len=0
08:07:49 ovpn,debug <185.235.244.244>: disconnected <peer disconnected>
08:07:49 ovpn,info TCP connection established from 187.68.245.99
08:07:49 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=85af83d1b8d5388b pid=0 DATA len=0
08:07:49 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=057a848163e6dc1 pid=0 DATA len=0
08:07:49 ovpn,debug,packet sent P_ACK kid=0 sid=85af83d1b8d5388b [0 sid=057a848163e6dc1] DATA len=0
08:07:49 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=764183f85cb078d2 pid=3 DATA len=1400
08:07:49 ovpn,debug,packet sent P_ACK kid=0 sid=e7e66686dfba3069 [3 sid=764183f85cb078d2] DATA len=0
08:07:49 ovpn,debug,packet sent P_CONTROL kid=0 sid=e7e66686dfba3069 pid=4 DATA len=7
08:07:49 ovpn,debug <191.11.243.178>: disconnected <TLS failed>
08:07:49 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=057a848163e6dc1 [0 sid=85af83d1b8d5388b] pid=1 DATA len=0
08:07:49 ovpn,debug,packet sent P_ACK kid=0 sid=85af83d1b8d5388b [1 sid=057a848163e6dc1] DATA len=0
08:07:50 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=057a848163e6dc1 pid=2 DATA len=283
08:07:50 ovpn,debug,packet sent P_ACK kid=0 sid=85af83d1b8d5388b [2 sid=057a848163e6dc1] DATA len=0
08:07:50 ovpn,debug,packet sent P_CONTROL kid=0 sid=85af83d1b8d5388b pid=1 DATA len=1400
08:07:50 ovpn,debug,packet sent P_CONTROL kid=0 sid=85af83d1b8d5388b pid=2 DATA len=1400
08:07:50 ovpn,debug,packet sent P_CONTROL kid=0 sid=85af83d1b8d5388b pid=3 DATA len=79
08:07:50 ovpn,debug,packet rcvd P_ACK kid=0 sid=057a848163e6dc1 [1 sid=85af83d1b8d5388b] DATA len=0
08:07:50 ovpn,debug,packet rcvd P_ACK kid=0 sid=057a848163e6dc1 [2 sid=85af83d1b8d5388b] DATA len=0
08:07:50 ovpn,debug,packet rcvd P_ACK kid=0 sid=057a848163e6dc1 [3 sid=85af83d1b8d5388b] DATA len=0
08:07:51 ovpn,info TCP connection established from 187.69.86.246
08:07:51 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=604e73efabe76b17 pid=0 DATA len=0
08:07:51 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=6abd4a94e7175ff0 pid=0 DATA len=0
08:07:51 ovpn,debug,packet sent P_ACK kid=0 sid=604e73efabe76b17 [0 sid=6abd4a94e7175ff0] DATA len=0
08:07:51 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=6abd4a94e7175ff0 [0 sid=604e73efabe76b17] pid=1 DATA len=0
08:07:51 ovpn,debug,packet sent P_ACK kid=0 sid=604e73efabe76b17 [1 sid=6abd4a94e7175ff0] DATA len=0
08:07:51 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=6abd4a94e7175ff0 pid=2 DATA len=283
08:07:51 ovpn,debug,packet sent P_ACK kid=0 sid=604e73efabe76b17 [2 sid=6abd4a94e7175ff0] DATA len=0
08:07:51 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=057a848163e6dc1 pid=3 DATA len=1400
08:07:51 ovpn,debug,packet sent P_ACK kid=0 sid=85af83d1b8d5388b [3 sid=057a848163e6dc1] DATA len=0
08:07:51 ovpn,debug,packet sent P_CONTROL kid=0 sid=85af83d1b8d5388b pid=4 DATA len=7
08:07:51 ovpn,debug <187.68.245.99>: disconnected <TLS failed>
08:07:51 ovpn,debug,packet sent P_CONTROL kid=0 sid=604e73efabe76b17 pid=1 DATA len=1400
08:07:51 ovpn,debug,packet sent P_CONTROL kid=0 sid=604e73efabe76b17 pid=2 DATA len=1400
08:07:51 ovpn,debug,packet sent P_CONTROL kid=0 sid=604e73efabe76b17 pid=3 DATA len=79
08:07:51 ovpn,debug,packet rcvd P_ACK kid=0 sid=6abd4a94e7175ff0 [1 sid=604e73efabe76b17] DATA len=0
08:07:51 ovpn,debug,packet rcvd P_ACK kid=0 sid=6abd4a94e7175ff0 [2 sid=604e73efabe76b17] DATA len=0
08:07:51 ovpn,debug,packet rcvd P_ACK kid=0 sid=6abd4a94e7175ff0 [3 sid=604e73efabe76b17] DATA len=0
08:07:52 ovpn,info TCP connection established from 179.242.106.114
08:07:52 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=a07081491904f25 pid=0 DATA len=0
08:07:52 ovpn,info TCP connection established from 187.68.106.119
08:07:52 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=b13358e4b3b38b8 pid=0 DATA len=0
08:07:52 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=6abd4a94e7175ff0 pid=3 DATA len=1400
08:07:52 ovpn,debug,packet sent P_ACK kid=0 sid=604e73efabe76b17 [3 sid=6abd4a94e7175ff0] DATA len=0
08:07:52 ovpn,debug,packet sent P_CONTROL kid=0 sid=604e73efabe76b17 pid=4 DATA len=7
08:07:52 ovpn,debug <187.69.86.246>: disconnected <TLS failed>
08:07:53 ovpn,info TCP connection established from 191.207.207.17
08:07:53 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=b2a26e7f27ccd6b6 pid=0 DATA len=0
08:07:53 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=39430ecd244e15f pid=0 DATA len=0
08:07:53 ovpn,debug,packet sent P_ACK kid=0 sid=b2a26e7f27ccd6b6 [0 sid=39430ecd244e15f] DATA len=0
08:07:53 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=39430ecd244e15f [0 sid=b2a26e7f27ccd6b6] pid=1 DATA len=0
08:07:53 ovpn,debug,packet sent P_ACK kid=0 sid=b2a26e7f27ccd6b6 [1 sid=39430ecd244e15f] DATA len=0
08:07:53 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=39430ecd244e15f pid=2 DATA len=283
08:07:53 ovpn,debug,packet sent P_ACK kid=0 sid=b2a26e7f27ccd6b6 [2 sid=39430ecd244e15f] DATA len=0
08:07:53 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=7f1defa273ae9a3e pid=0 DATA len=0
08:07:53 ovpn,debug,packet sent P_ACK kid=0 sid=a07081491904f25 [0 sid=7f1defa273ae9a3e] DATA len=0
08:07:53 ovpn,debug,packet sent P_CONTROL kid=0 sid=b2a26e7f27ccd6b6 pid=1 DATA len=1400
08:07:53 ovpn,debug,packet sent P_CONTROL kid=0 sid=b2a26e7f27ccd6b6 pid=2 DATA len=1400
08:07:53 ovpn,debug,packet sent P_CONTROL kid=0 sid=b2a26e7f27ccd6b6 pid=3 DATA len=78
08:07:53 ovpn,debug,packet rcvd P_ACK kid=0 sid=39430ecd244e15f [1 sid=b2a26e7f27ccd6b6] DATA len=0
08:07:53 ovpn,debug,packet rcvd P_ACK kid=0 sid=39430ecd244e15f [2 sid=b2a26e7f27ccd6b6] DATA len=0
08:07:53 ovpn,debug,packet rcvd P_ACK kid=0 sid=39430ecd244e15f [3 sid=b2a26e7f27ccd6b6] DATA len=0
08:07:53 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=5c44ebdd1f7ba649 pid=0 DATA len=0
08:07:53 ovpn,debug,packet sent P_ACK kid=0 sid=b13358e4b3b38b8 [0 sid=5c44ebdd1f7ba649] DATA len=0
08:07:53 ovpn,info TCP connection established from 200.9.126.102
08:07:53 ovpn,debug,packet sent P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=6c9b801e3dee9d65 pid=0 DATA len=0
08:07:53 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=c588edb238e228d pid=0 DATA len=0
08:07:53 ovpn,debug,packet sent P_ACK kid=0 sid=6c9b801e3dee9d65 [0 sid=c588edb238e228d] DATA len=0
08:07:53 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=c588edb238e228d [0 sid=6c9b801e3dee9d65] pid=1 DATA len=0
08:07:53 ovpn,debug,packet sent P_ACK kid=0 sid=6c9b801e3dee9d65 [1 sid=c588edb238e228d] DATA len=0
08:07:54 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=c588edb238e228d pid=2 DATA len=283
08:07:54 ovpn,debug,packet sent P_ACK kid=0 sid=6c9b801e3dee9d65 [2 sid=c588edb238e228d] DATA len=0
08:07:54 ovpn,debug,packet sent P_CONTROL kid=0 sid=6c9b801e3dee9d65 pid=1 DATA len=1400
08:07:54 ovpn,debug,packet sent P_CONTROL kid=0 sid=6c9b801e3dee9d65 pid=2 DATA len=1400
08:07:54 ovpn,debug,packet sent P_CONTROL kid=0 sid=6c9b801e3dee9d65 pid=3 DATA len=79
08:07:54 ovpn,debug,packet rcvd P_ACK kid=0 sid=c588edb238e228d [1 sid=6c9b801e3dee9d65] DATA len=0
08:07:54 ovpn,debug,packet rcvd P_ACK kid=0 sid=c588edb238e228d [2 sid=6c9b801e3dee9d65] DATA len=0
08:07:54 ovpn,debug,packet rcvd P_ACK kid=0 sid=c588edb238e228d [3 sid=6c9b801e3dee9d65] DATA len=0
Exiver
Re: Problem with certificate backup for SSTP
Thu May 02, 2019 3:05 pm
Im not sure if you read what i have written or if you just skim through my messages. Right now i will try it once more, if you keep ignoring me i will not answer anymore. This sounds harsh - im sorry for that but its my free time and what we are doing here is wasting my and your time. No one wants that.
Once again: You are only posting the server sided logs. We need to see the client side as well. The server seems to be *not* responsible for terminating that connection. So it doesnt help to ONLY see the server side logs!
Please post the output of
* Main VPN-Router: /system identity print
* Backup VPN-Router: /system identity print
schnitzelchen
Thu May 02, 2019 3:27 pm
Why do you post ovpn logs. Please show us the sstp logs. SSTP and OpenVPN are to different protocols!
Exiver
Thu May 02, 2019 4:06 pm
Original post was about sstp (other author), kadety uses openvpn.
kadety
Thu May 02, 2019 5:40 pm
Sorry for my fault.
See de Client log.
10:51:25 ovpn,info vpn-agetop-ovpn: initializing...
10:51:25 ovpn,info vpn-agetop-ovpn: connecting...
10:51:28 ovpn,debug,packet sent P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=09dc552a8bc68cb pid=0 DATA len=0
10:51:30 ovpn,debug,packet rcvd P_CONTROL_HARD_RESET_SERVER_V2 kid=0 sid=c6d8f98385412b0 pid=0 DATA len=0
10:51:30 ovpn,debug,packet sent P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 sid=09dc552a8bc68cb [0 sid=c6d8f98385412b0] pid=1 DATA len=0
10:51:30 ovpn,debug,packet sent P_CONTROL kid=0 sid=09dc552a8bc68cb pid=2 DATA len=283
10:51:30 ovpn,debug,packet rcvd P_ACK kid=0 sid=c6d8f98385412b0 [0 sid=09dc552a8bc68cb] DATA len=0
10:51:30 ovpn,debug,packet rcvd P_ACK kid=0 sid=c6d8f98385412b0 [1 sid=09dc552a8bc68cb] DATA len=0
10:51:30 ovpn,debug,packet rcvd P_ACK kid=0 sid=c6d8f98385412b0 [2 sid=09dc552a8bc68cb] DATA len=0
10:51:30 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=c6d8f98385412b0 pid=1 DATA len=1400
10:51:30 ovpn,debug,packet sent P_ACK kid=0 sid=09dc552a8bc68cb [1 sid=c6d8f98385412b0] DATA len=0
10:51:30 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=c6d8f98385412b0 pid=2 DATA len=1400
10:51:30 ovpn,debug,packet sent P_ACK kid=0 sid=09dc552a8bc68cb [2 sid=c6d8f98385412b0] DATA len=0
10:51:30 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=c6d8f98385412b0 pid=3 DATA len=79
10:51:30 ovpn,debug,packet sent P_ACK kid=0 sid=09dc552a8bc68cb [3 sid=c6d8f98385412b0] DATA len=0
10:51:31 ovpn,debug,packet sent P_CONTROL kid=0 sid=09dc552a8bc68cb pid=3 DATA len=1400
10:51:31 ovpn,debug,packet sent P_CONTROL kid=0 sid=09dc552a8bc68cb pid=4 DATA len=1162
10:51:31 ovpn,debug,packet rcvd P_ACK kid=0 sid=c6d8f98385412b0 [3 sid=09dc552a8bc68cb] DATA len=0
10:51:31 ovpn,debug,packet rcvd P_ACK kid=0 sid=c6d8f98385412b0 [4 sid=09dc552a8bc68cb] DATA len=0
10:51:31 ovpn,debug,packet rcvd P_CONTROL kid=0 sid=c6d8f98385412b0 pid=4 DATA len=7
10:51:31 ovpn,debug,packet sent P_ACK kid=0 sid=09dc552a8bc68cb [4 sid=c6d8f98385412b0] DATA len=0
10:51:31 ovpn,debug vpn-ovpn: disconnected <peer disconnected>
10:51:31 ovpn,info vpn-ovpn: terminating... - peer disconnected
10:51:31 ovpn,info vpn-ovpn: disconnected
Identity MK
[admin@RB-DTF-VPN's_NEW] > /system resource print
             uptime: 33m33s
            version: 6.44.2 (stable)
         build-time: Apr/01/2019 12:47:57
   factory-software: 6.35.2
        free-memory: 1662.0MiB
       total-memory: 1952.0MiB
                cpu: tilegx
          cpu-count: 16
      cpu-frequency: 1200MHz
           cpu-load: 1%
     free-hdd-space: 418.9MiB
    total-hdd-space: 512.0MiB
  architecture-name: tile
         board-name: CCR1016-12G
           platform: MikroTik
[admin@RB-DTF-VPN's_NEW] > /system identity print
resource  reboot  reset-configuration
             uptime: 18m50s
        free-memory: 1758.2MiB
                cpu: tilegx
          cpu-count: 16
           cpu-load: 0%
     free-hdd-space: 321.9MiB
           platform: MikroTik
kadety
Thu May 02, 2019 5:51 pm
I noticed that in the certificate in the main MK is the CA.
see main MK
Bun in Production MK does not contain
See backup MK
Can this fail?
Exiver
Fri May 03, 2019 12:56 pm
Thank you for your input, i think everything looks good here.
The following link is interesting for you:
viewtopic.php?t=88372
Did you set a CRL while creating these certificates? If yes, can you try it without CRL?
kadety
Mon May 06, 2019 5:33 pm
Resolved. Created the certificate without CLR and was solved.
@Exiver
Thanks for your help and your dedication to solving.
Exiver
Mon May 06, 2019 5:43 pm
Glad to hear that it worked for you!
Users browsing this forum: No registered users and 111 guests
