info24hs
mikrotik wrong username or password
Fri Feb 15, 2019 11:27 pm
when i open winbox and connect in host the mikrotik show me "wrong username or password" i don't changed the password or username, restart but don't have success.
sorry my english
Cristiano
joegoldman
Long time Member
Long time Member
Re: mikrotik wrong username or password
Sat Feb 16, 2019 5:10 am
Was it old RouterOS version? If so its likely been hacked. Good news is, being old version you can use the same hack to re-gain access - but once its been compromised you should take config export, make sure no bad config is in there, and do a fresh net-install.
pacman88
Sat Feb 16, 2019 1:32 pm
this issue keeps happening to me when my winbox version is to old for the used RouterOS version - just try to update winbox before you do anything else.
@mikrotik:
please add a more usable error message because even though it happened to me a couple of times I am regularly confused for some time before I figure it out again.
BR
Alex
nescafe2002
Long time Member
Long time Member
Sat Feb 16, 2019 1:56 pm
WinBox v3.18 doesn't connect to RB with empty password out-of-the box.
Just login via WebFig / SSH / telnet and set a password (may even be empty).
WinBox login w/o password seems to works fine..
pacman88
Sat Feb 16, 2019 2:32 pm
i can't confirm this - i am pretty sure I did exactly that last week
BR
Alex
nescafe2002
Long time Member
Long time Member
Sat Feb 16, 2019 3:00 pm
You are correct :)
Users browsing this forum: Baidu [Spider], bastys, CZFan, fleg, Google [Bot], sindy, tippenring and 144 guests
